    [Plugin] Center on Origin UPDATE May 23, 2013
    35 Posts 18 Posters 46.0k Views 18 Watching
    • Chris FullmerC Offline
      Center on Origin
      Description: Center a group or component on the model origin.
      Usage: Activate this tool from Plugins>Chris Fullmer Tools>Center on Origin. It only works with groups and components, and you can only center one at a time. It does not rotate or change the scale of the object.
      History
      1.0 - 2009-04-29
      • First release
        1.1.0 2013-23-2013
        • Extension Class Compatibility
      This is a request from this thread. Todd at smustard.com also has a very similar script that moves geometry to the origin, but it works slightly different. It does not center it on the origin. This one works the way it does because it was a special request.
      (no audio on this video. 14 seconds long)
      [flash=640,575:1k3bvtug]http://www.chrisfullmer.com/forums/center_on_origin.swf[/flash:1k3bvtug]
      1450
      v1.1.0
        Khai
        ooh I wanted this as well 😄
          It was a while that you have not create a new plug 😉
            lucifer1101
            very nice little toy, thanks for the contribution...
            Some of my 3d
            • Bob JamesB Offline
              Bob James
              Very useful, Chris, thanks for taking the time to create it. 👍
                I have literally been forcing myself to not write any, after the earlier innundation of scripts. I do have some ideas, and even one really cool one started, but I told myself I can't do more until I graduate (in like 2 or 3 weeks now!). Yeah, I need to focus on school for a little bit. Then I'll get back up and running on rubies again probably 😄
                Thanks for positive feedback.
                  And here's another option. If you want it to reset the component rotation and scale, edit the ruby file in a plain text editor (like notepad for example) and after the line:
                  if comp.typename == "Group" || comp.typename == "ComponentInstance"
                  add the two following lines:
                  t = Geom::Transformation.new comp.transformation = t
                  • MALAISEM Offline
                    MALAISE
                    Strangely , I taught similar 🤣
                    Thanks Chris
                    MALAISE
                      raduteo
                      And this is why SU is the best, works fabulously, thank you!
                      • bagateloB Offline
                        bagatelo
                        Is there possible to make change on this script to only move to origin axes X and Y, not Z?
                        • TIGT Online
                          Edit the script and change the line
                          vector = point.vector_to [0,0,0]
                          to read
                          vector = point.vector_to [0,0,point.z]
                          It will then not change the Z -value of the translation... 🤓
                          • bagateloB Offline
                            bagatelo
                            Thanks, it works well. But if I want to move base of object to zero on Z axes? Thanks anyway.
                            • TIGT Online
                              So having now got the idea - Edit the script and change the line
                              to read
                              vector = point.vector_to [point.x,point.y,0]
                              It will then not change the X/Y values but will set the Z-value of the translation to zero......
                                rootbender
                                Hello,
                                The "Center on Origin" script only works correctly when the drawing axes are at (0,0,0).
                                However, it is possible to move the drawing axes with Tool -> Axes to somewhere else
                                that is not (0,0,0).
                                How can center a selection to the currently set origin, which may not be at (0,0,0) ?
                                Thanks.
                                  Jim
                                  Unfortunately, there is no access to the Origin of the moved Axes from Ruby.
                                  • E Offline
                                    eph
                                    Very cool!
                                    I know this is old stuff already, but would it be complicated to move everything to center (eventually while keeping Z-height), including hidden geometry, section cuts and most of all the Camera views..?
                                    Would be very grateful 😄
                                    • H Offline
                                      haimat
                                      Thanks for this great plugin, that's exactly what I was looking for 😄
                                      • genma saotomeG Offline
                                        genma saotome
                                        I'm having some difficulty using this plug in on nested components that were created with a copy/paste/scale = -1. I was hoping to try a few of the edits cited in this thread but the ruby is a .rbz; My editor tells me its been locked up and uneditable... is there another way to get to the source?
                                          The .rbz is just a zip file. Rename it to .zip and then unzip it. Inside there are regular .rb files that you can edit for your own personal use.
                                          • charly2008C Offline
                                            charly2008
                                            Hi Chris,
                                            I installed the new update but now get an error message.
                                            Charly
