    [Plugin] Center on Origin UPDATE May 23, 2013
    35 Posts 18 Posters 47.4k Views 18 Watching
    • Chris FullmerC Offline
      It was a while that you have not create a new plug 😉
      I have literally been forcing myself to not write any, after the earlier innundation of scripts. I do have some ideas, and even one really cool one started, but I told myself I can't do more until I graduate (in like 2 or 3 weeks now!). Yeah, I need to focus on school for a little bit. Then I'll get back up and running on rubies again probably 😄
      Thanks for positive feedback.
        And here's another option. If you want it to reset the component rotation and scale, edit the ruby file in a plain text editor (like notepad for example) and after the line:
        if comp.typename == "Group" || comp.typename == "ComponentInstance"
        add the two following lines:
        t = Geom::Transformation.new comp.transformation = t
        • MALAISEM Offline
          MALAISE
          Strangely , I taught similar 🤣
          Thanks Chris
          MALAISE
            raduteo
            And this is why SU is the best, works fabulously, thank you!
            • bagateloB Offline
              bagatelo
              Is there possible to make change on this script to only move to origin axes X and Y, not Z?
                Edit the script and change the line
                vector = point.vector_to [0,0,0]
                to read
                vector = point.vector_to [0,0,point.z]
                It will then not change the Z -value of the translation... 🤓
                • bagateloB Offline
                  bagatelo
                  Thanks, it works well. But if I want to move base of object to zero on Z axes? Thanks anyway.
                    So having now got the idea - Edit the script and change the line
                    to read
                    vector = point.vector_to [point.x,point.y,0]
                    It will then not change the X/Y values but will set the Z-value of the translation to zero......
                      rootbender
                      Hello,
                      The "Center on Origin" script only works correctly when the drawing axes are at (0,0,0).
                      However, it is possible to move the drawing axes with Tool -> Axes to somewhere else
                      that is not (0,0,0).
                      How can center a selection to the currently set origin, which may not be at (0,0,0) ?
                      Thanks.
                        Jim
                        Unfortunately, there is no access to the Origin of the moved Axes from Ruby.
                        • E Offline
                          eph
                          Very cool!
                          I know this is old stuff already, but would it be complicated to move everything to center (eventually while keeping Z-height), including hidden geometry, section cuts and most of all the Camera views..?
                          Would be very grateful 😄
                          • H Offline
                            haimat
                            Thanks for this great plugin, that's exactly what I was looking for 😄
                            • genma saotomeG Offline
                              genma saotome
                              I'm having some difficulty using this plug in on nested components that were created with a copy/paste/scale = -1. I was hoping to try a few of the edits cited in this thread but the ruby is a .rbz; My editor tells me its been locked up and uneditable... is there another way to get to the source?
                                The .rbz is just a zip file. Rename it to .zip and then unzip it. Inside there are regular .rb files that you can edit for your own personal use.
                                • charly2008C Offline
                                  charly2008
                                  Hi Chris,
                                  I installed the new update but now get an error message.
                                  Charly
                                    Oh that's not good 😞
                                    I'll have to work on testing this one tomorrow. I'm not sure what has gone wrong, but I'm pretty sure it'll be easy enough to find. Thanks Charly,
                                      charly2008
                                      No reason, I have to thank you. Another note, in Sketchup 2013 it works fine.
                                        Do you have any of my other scripts installed in 2013?
                                        Also make sure that you deleted the old version that is in SU 8.
                                          charly2008
                                          I have to correct myself, even in "Sketchup 2013," an error message appears.
                                          Yes I have more plugins from you, see picture below.
                                            Hey Charly, the screen shots are useful, but it does not show clf_center_on_orogin.rb listed in the lower screenshot, which I would expect, since you have the folder loaded, and the errors seems to be pertaining to center on origin.
                                            I wonder if you have plugins lost in the Compatibility folders sonwhere. In the plugins folder, at the top do you see "Compatibility Folders" anywhere? See the first screenshot in the following:
                                            Page not found
                                            (www.hanselman.com)
                                            If you have that, click on it, select everything there and MOVE it back into the actual plugins folder.
                                            Then try to restart SU, if you still have issues, take screenshots again and let me see what you have.
                                            Or if you don't have any compatibility folders, could you send me your copy of center on origin? Thanks,
