    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • boofredlayB Offline
      boofredlay
      LibFredo6 3.1c as well?
      • fredo6F Offline
        Did any one notice the flickering in 2.0b?
        • fredo6F Offline
          Actually the flickering effect was already in version 2.0b. Strange that I did not notice (and none until Massimo).
          • massimoM Offline
            massimo Moderator
            True Fredo. But the very strange thing is that i did not notice the flickering (in "b" version i mean) until i went back from "c" to "b" version.
              Jackson
              Absolutely amazing plugin Fredo, words fail me for this incredible achievement and generosity- such a useful and well-designed ruby! Donation is on its way as soon as pay day arrives.
              Jackson
              • fredo6F Offline
                Coen,
                I added the native Protractor feature in the (c) releases of LibFredo6 and FreeScale.
                Any other feature with the protractor that I do not know about?
                • fredo6F Offline
                  NEW VERSION 2.0c NOW RELEASED
                  See details in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                  You also need to download LibFredo6 3.1c
                  PS: the reason of the dealy was a small flickering effect when manipulating the deformation box. Actually, it was in version b already. It is hopefully fixed now.
                  • McGyverM Offline
                    McGyver
                    Brilliant,intuitive and simply fantastic... this should have come with SU to begin with.... heck google should beg you to make stuff for them! You are the Ruby-Master!! Thanks a million!!
                    [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
                    • david_hD Offline
                      david_h
                      For some strange reason the Radial Bend feature just stopped working? everything else seems fine. Or maybe I am not using it right? Any ideas?
                        remus
                        Your not trying it on a highly grouped/compenented model by any chance? As far as i can tell things start to go funny when youve got more than 2 levels of groups.
                        • fredo6F Offline
                          David,
                          What is the exact problem:
                          • does it crash or bug splat?
                          • Do you see the protractor and can you use it?
                          • do you see the wireframe?
                          • bagateloB Offline
                            bagatelo
                            I liked that plugin a lot, this is saving a lot of my time. But...
                            I don't know if I will get to explain the problem of behavior of the plugin that doesn't please me, but I will try.
                            My displeasure is regarding the Icon "Stretching with Box by matching an origin and the target." After it is chosen the plan where Stretch should happen, I cannot use a relationship of distance among distant objects as it could use the command MOVES common of Sketchup. I need to draw a line or object to the close origin point and the close target point to make Stretch. It would be interesting if it went as in the command it MOVES of the sketchup, where I can use points of it distances wanted distant of the object that desire to make Stretch.
                            • fredo6F Offline
                              NEW VERSION 2.0d
                              It fixes a major bug introduced in 2.0c for the target mode of Scale, Stretch, Shear, and also for setting the dimensions via the dialog box. Sorry for inconvenience.
                              So it is strongly advised to upgrade.
                              As a bonus, you'll get the Korean translation by Couque D`asse.
                              All details are in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                              Note: You will also need to download LibFredo6 3.1d
                              • utilerU Offline
                                utiler
                                'Thanks Fredo' seems so insignificant!!!
                                Just Curious...
                                • david_hD Offline
                                  david_h
                                  Fredo. . .
                                  Downloaded the latest version and the bending works now. But the Icons don't show up on the tool bar. I had them before just fine . . .now I don't.
                                  I just didn't get a chance to mention it. I had this problem with 2.0c as well.
                                  DO they icons png's belong in their own subfolder?
                                  • jcharltoncarpJ Offline
                                    jcharltoncarp
                                    OK I've Dealt with it
                                    I'm reposting this from the Newbie forum. I've been taking advantage of the current economic down turn, to, amongst other things learn Sketchup. The reason I joined the forum is my interest in Fredo's amazing freescale tool. I'm very new to SketchUcation. A few months into Shetchup, and less than six months back to Mac after an absence since OS 4. I'm using a Mac running Leopard and have been unable to install the downloads correctly in my plugins folder. I was wondering if someone could post a screen shot of the folder hierarchy properly installed? I have been following the posts on the Ruby forum and have tried several ways to do the installation, but no joy. All suggestions gratefully accepted.
                                    John
                                    • jeff hammondJ Offline
                                      they should be in a folder called 'IMAGES_Standard' which is inside the 'FREESCALE_Dir_20' folder.
                                      if you want daniel's icons, they will be in a folder called 'IMAGES_DanielS' which goes in the freescale folder and you activate them via the parameters dialog.
                                      • david_hD Offline
                                        david_h
                                        Success!!! Thanks a lot.
                                        D
                                          Matt666
                                          Hi Fredo!
                                          I just tried your new version (v2.0d), but it seems to bug when I want to move some points...
                                          • Procedure:
                                          • Start scale tool
                                          • Select a cube
                                          • Try to move a corner (with one of your points). Impossible to move any point.* Error message in the ruby console:Sans titre 1.jpg 😉
                                          Frenglish at its best !
                                          My scripts
                                          • fredo6F Offline
                                            Matt,
                                            I don't know what this is, as I cannot reproduce it on my machine.
                                            Just in case, I slighlty modified the code around the "round" function.
                                            Can you try it, and tell if you can reproduce the bug.
                                            to drop in FREESCALE_Dir_20 folder
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 56
                                            • 57
                                            • 13 / 57
