    The VUE thread
    extensions
    122 Posts 29 Posters 22.0k Views 29 Watching
    • soloS Offline
      Drive by, turning wheels.
      [flash=425,265:2vn1n888]http://www.youtube.com/watch/v/q4kljK0rCRs[/flash:2vn1n888]
      • Chris FullmerC Offline
        @solo said:
        When you have the PLE I will walk you through the settings as you did for me with Vray on how to get a crisp render.
        Please oh please make this conversation public when you have it. I've had the PLE for about a month now and I've played with it enough to like it, but I still have problems with render quality and I'd like to get up to professional level myself!
        • soloS Offline
          Will do dat!
          Another test, this time animated texture changes.
          [flash=640,480:3jphsn75]http://www.youtube.com/watch/v/0cPfGSnposc[/flash:3jphsn75]
          • soloS Offline
            Heads up to all version 7 users, Vue 7.4 (free) update has been released with many new features.
            -Material Painting and effect-driven material mapping in the Terrain Editor
            -Cross-shadowing on clouds
            -Optional Hide objects from render and disable lights by clicking their icon in World Browser
            -OpenGL sky preview with clouds
            -Realistic MetaCloud preview
            -Dynamic plant display optimization
            -Enhanced Multi-Processor usage for procedural terrains, dynamic EcoSystems and panoramic rendering
            -SketchUp 7 file import
            -Automatic renaming of Standalone, HyperVue- and RenderNode-generated frames if overwriting
            -Improved OpenGL display of transparent objects, lensflare, fog, sky previews, layered ecosystem materials...
            -Optimized memory usage when creating a new scene.
            -Improved the Auto-updating of Vue on MacOS.
            -New algorithms to reduce noise in the shadows projected by spectral clouds.
            -Various optimizations with Macro edition, particularly on MacOS 10.4.
            -Added an option to refresh the sky OpenGL display in the viewport display options.
            -Improved several import modules (3DMF, COB, LWO, VRML).
            -Fixed possible problems when importing animated Collada files on MacOS.
            -Improved Fractal computation in the terrain editor.
            -Improved edition of pre-animated groups.
            -Optimized workflow with Poser objects.
            -Optimized anti flickering technology for animations that include stars.
            -Optimized alpha transparency influence with GI shading.
            -Improved stability when using the Function Editor.
            -Fixed a possible bug when using the "twist" parameter on Vue object.
            -Fixed a possible crash when resetting an atmosphere that contains animated clouds.
            -Improved Network Rendering with RenderCows.
            -Various interface optimizations.
              meh? I just downloaded the PLE and I get 7.0... ?
                I'm trying to import a .skp file into VUE7. The .skp is saved in SU6 format. But I get an error message saying it can't read file.
                Any requirements to the .skp in order for it to import?
                • soloS Offline
                  Hmmm, not sure about the PLE version,cannot find anything on the site so far.
                  Anyway. seen this? Vue used in Terra X movie.
                  http://www.e-onsoftware.com/showcase/spotlights/?page=1
                    I seem to be completely unable to import SU6 files. But SU5 seems to work. With simple test scenes it works fine, but when I try to import a real project I find many things misplaced upon import. Any clue to how to circumvent this?
                      Does VUE not handle nested components/groups?
                      • soloS Offline
                        It does, all my SU models have nested groups and components and it works great with Vue, I however export as .3ds and open up in Vue, I do not use the .skp import.
                          .3ds worked more reliably.
                          • soloS Offline
                            Make sure to UN-check stand alone edges.
                              Can VUE generate terrain from DWG files?
                                What .3ds export settings do you use?
                                • soloS Offline
                                  TT
                                  I'm not sure about .dwg however it can with .dxf and .dem.
                                  regarding my 3ds export:
                                  http://img11.imageshack.us/img11/839/exportdialogue.jpg
                                  (my model units in SU are inches)
                                  • soloS Offline
                                    Another fast and dirty test, I wanted to make sure the main blades and rotor blades spin at different speeds and on their own axis yet linked to helicopters movements.
                                    [flash=600,400:3sylqzrl]http://www.youtube.com/watch/v/ZpoaWdy5Knw[/flash:3sylqzrl]
                                    This is the basic SU model from 3DWH.
                                      craftycurate
                                      Hi Folks ...
                                      I'm a fairly long time Vue user, since v5, and I do almost all of my rendering in Vue. I've also been using Sketchup (SU) for quite a while, and most of the architectural elements in my scenes are built and textured in Sketchup (to create shading domains), imported into Vue as SKP files, and retextured inside Vue.
                                      Some examples on my Renderosity gallery - http://www.renderosity.com/mod/gallery/browse.php?user_id=434993.
                                      I am having a few issues importing SU into Vue Infinite v7.4 which has just added SU7 support, and sometimes simple models don't import for reasons I don't understand. I use the free version of SU, so the other option is OBJ export.
                                      Also, heavily nested groups don't always import well - sometimes objects end up in odd locations, but if everything is exploded first it isn't a problem usually.
                                      Richard
                                      • soloS Offline
                                        Are you running a 64 bit system? as the new 7.4 has great import support for SU7 now on a 32 bit system and not yet supported on 64bit.
                                        Richard out of habit I only use .3ds export which you cannot do due to your SU version. I posted a ticket with E-on as I had a few 'sidebyside' issues with the new update so until that's resolved I'm still using 7.21.
                                          ark
                                          How is the renderspeed i VUE compared to e.g. V-ray or Modo renderengine?
                                          It seems that VUE can make some nice renders!
                                          • soloS Offline
                                            It's difficult to compare them as Vue's advantage is atmospheres and procedural terrains that generally are cumbersome for any render engine, but pretty damn fast with Vue.
                                            Like all render engines speed is also relative to your machine and Vue is optimal on a 64 bit machine with a good GPU and as many cores and ram as possible.
                                            Again one can set up and tweak render settings in Modo and Vray to an extent that they give fantastic results at crippling render times and with Vue it's the same, just play around with your atmosphere settings and you will notice how speeds can change.
                                            So I'd say Vue and Vray are pretty much similar as far as render speeds go (I cannot talk about Modo as I know nothing of it's render speeds) and really contingent on your render settings.
                                            • 3 / 7
