    [Obsolete] BZ__Arc for BezierSpline 1.2
    54 Posts 31 Posters 27.7k Views 31 Watching
    • Chris FullmerC Offline
      I like that Fredo is now making plugins for his plugins πŸ˜„
      • W Offline
        watkins
        Dear Fredo,
        I just tried your plugin. Brilliant! It does pipe runs beautifully when used with pipe along path.
        Thanks once again!
        Kind regards,
        Bob
          gaganraj
          everytime i try to leave SU....i just get dragged back.
          i'm unable to download the icons. For some reason there is no download link?
          • boofredlayB Offline
            boofredlay
            Context click on the image itself and save as...
              jmmad
              Fredo6
              what i like most of your script BezierSpilne is that the endpoints are intelligent and editable, you can move those points and the equation result for the geometry is auto updated, you can set the number of edges etc...
              So i have 3 request that i think it would be very useful.
              1.-Would it be possible to transform a normal set of SU lines to an editble polyline or bezier?
              2.-And to transform a BZ polyline to BZ Arc or any other Bezier and back?
              EDITED: ive notice you had those 2 option πŸ˜„. I should go to my oculist.
              When i go from BZ arc to Polyline would it be possible to get the primitive geometry and nont the points that make the arc?
              Ill try to explain this request...this i think it's more complex.
              Ive notice in your BZ plug in when you PushPull a closed BZ Spline or polyline surface, the BZ lines are copy, then you can edit the top and the bottom and edit somehow the geometry of the volume with the BZ edit command.
              But if i move a point in the top BZ polyline the point on the bottom polyline does not follow because its not related to the bottom spline.
              3.-Could it be posible to relate points between 2 or more "BZ polylines" maybe by an invisible vertex? So when you drag that vertex the the 2 or more beziers are modified at the same time. So if you have a volume made of an extruded BZ_Arc or spline you move this vertex and the geometry follows and not only the lines but the volume itself is updated. This will give more control over volumes just as you did with the 2d lines. With your talent you gave endpoints in SU properties that can be edited. Maibe that could be done with volumes.
              So this "inteligent vertex and endpoints could tell how the visible geometry should be.
              Uff... this is hard to explain for me.
              I hope you can follow mi idea.
              Get Upa !
              • CadFatherC Offline
                CadFather
                ..and icons if needed.
                EDIT: strange my bezier tools have completely stopped working on SU7
                  dtrarch
                  Super useful and thanks a bunch. β˜€
                  A really helpful road layout tool that will be used a lot.
                  Question please. πŸ˜•
                  What does offset reference ?
                  Arc radius ? Arc segment ? or ?
                  Thx again
                  dtr
                  • fredo6F Offline
                    Offset is the distance from the corner to the start of the arc.
                    You will notice that when the length of one of the segments defining the corner is not superior to twice the offset value, no round corner is generated.
                      dtrarch
                      Thanks for the reply and again the really useful tool.
                      dtr
                        CadFather
                        Hi Fredo, i could be wrong but it seems BZ 1.2 only works with the default su7 installation
                        if i have SU installed in a different folder the tool will start but it will not draw a line upon clicking..
                        (i have multiple copies of SU one for working, one for experimentation)
                        • david_hD Offline
                          david_h
                          Cool Plugin. thanks.
                          D
                          πŸ‘
                          PS. I think we need a smilie emoticon of hands clapping in thunderous applause for just these types of occasions.
                          πŸ˜„
                          • fredo6F Offline
                            You are right. BezierSpline asumes it is located in the default Sketchup Plugin folder.
                            For FreeScale and LibFredo6 I have arranged to support alternate folders however, provided you configure Sketchup for an alternate folder (via script acting on $:).
                            When I refresh Bezierspline, it should work.
                            • N Offline
                              numerobis
                              @thomthom said:
                              "Sketchup Fredo Edition" πŸ‘ πŸ˜„ πŸ‘
                              +1 πŸ’š
                              Thank You very much Master Fredo!
                              Really Useful! 😎
                                putnik
                                Moderators, shouldn't Fredo's name be highlighted in a different colour on this forum, or something, like the names of other people who distinguished themselves in some way? He obviously is some kind of demigod at the very least but has an appearance of a mortal.
                                http://keshas.info
                                • X Offline
                                  xrok1
                                  maybe in neon 🀣
                                    CadFather
                                    Thanks Fredo, is there no way to make it folder independent? or perhaps specified in a txt file?
                                    • soloS Offline
                                      On my machine if one enables the sound every time you hover your mouse over his name you get a choir like "halelujia" sound clip. πŸ˜‰
                                        CadFather
                                        that's amazing - i've got aretha franklin's 'Fredoo'
                                        • I Offline
                                          ideas_arte
                                          Thank you very much..! Fredo.. πŸ‘
                                          • FrederikF Offline
                                            Frederik
                                            Off topic
                                            I assume that it's only mods who can get direct access into a user profile, when clicking the username... πŸ˜•
                                            Being a "regular mortal" nothing happens when pointing on a username... 😞
                                            Cheers
                                            Kim Frederik
                                            • 2 / 3
