    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 184.8k Views 83 Watching
      @daniel s said:
      With the holdiays, I am just resuming some work on my scripts. Indeed, I will try to fix issues with Round Edge (and maybe develop the spheric / elliptic option).
      Fredo, When you say to develop the spheric / elliptic option do you mean something like the attachment image?
      [attachment=0:1hhs0yf5]<!-- ia0 -->roundedges.jpg<!-- ia0 -->[/attachment:1hhs0yf5]
      That would be a huge improvement πŸ˜„
      Thank you again for this amazing must-have tool...
      Daniel S
      How did you do that?
      • free agentF
        free agent
        Bonzai3d...?
        http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          jmmad
          SU needs and can catch up with bonzai3d
          Fredo this ruby + other transformation like twist and bend would be really great.
          Get Upa !
          • free agentF
            free agent
            Funny(and sad) that Sketchup on version 7 needs to catchup with a beta release... interestingly bonzai 3d shares a render engine with modo (assuming that it has the same render engine as FormZ)
            • O
              Oaht
              Thanks for your superb plugin. This will save a lot of time!!!
              • B
                BorgMan
                It would be great if the Round Edges tool would work like that Bonzai3D image. I've had so much models which use complex shapes that totally effed up when I unleashed the RE tool on them, after which I had to manually retrace the outlines to make them work properly...
                More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                You've gotta love Slivers.
                • G
                  gio
                  Can you tell me more about this, please?
                  Do you have a link?
                  It would really be a great news!
                  Ciao, Gio
                  • N
                    numerobis
                    (www.bonzai3d.com)
                    (btw. google is your friend πŸ˜‰ )
                    • X
                      xrok1
                      hi fredo, great script once more. 😲
                      did you ever figure out how to overcome this type of thing?
                      • T
                        TeamSDA
                        Hey Fredo
                        This is a great script we are having difficulties with its performance due to a high number of edges. We are currently working on how to extrude letters from .dwg files and we want to bevel the edges of the letters but they are made up of many edges and the script gets bogged down with the task. πŸŽ‰
                        Team SDA
                        Here is the file we are currently working on.
                        Logo Tests.skp
                        • X
                          xrok1
                          did you try sds on that as you did with the other project?
                          • T
                            TeamSDA
                            Yes but we are having issues with extra lines showing up and the process is a little time consuming. Was hoping for a tool that was a little more simple in it's approach.
                            Team SDA
                            • X
                              xrok1
                              i think the follow me tool would be your best option there.
                              • X
                                xrok1
                                draw a face on the top edge perpendicular like this:face.jpg
                                select top face then followme tool then click on the drawn arc, then close the top face:follow.jpg
                                • fredo6F
                                  Team SDA
                                  If it is just to round the top and bottom faces, then I suggest you use xrok simple method with Follow me.
                                  RoundEdge is more intended to handle the rounding of corners where you apply it to 3 or more edges.
                                  The current method is not performing fast, I agree. The script was actually experimental and I did not rework on it recently. Obviously, this is not the right tool for a serial usage. Sorry for that.
                                  • T
                                    TeamSDA
                                    Thank you all for your input. Looks like the follow me tool will work well for us on simple geometry. We hope that in the future someone will develop a commercial grade bull-nosing and filleting (edge smoothing) script with capabilities similar to what is depicted in the attached video.
                                    Team SDA
                                    Here is what we accomplished using the follow me tool on the edges of the letters. We also found that we could use it to make fillets on the bottom of the letters.
                                    A Bull-nosing plugin with these capabilities would be ideal.
                                    • X
                                      xrok1
                                      i would suggest that before you pushpull your letters you clean up the edges, there's no reason to have all those faces on the sides. better yet why don't you just use the SU 3Dtext tool?
                                        Daniel S
                                        Team SDA
                                        That video looks familiar to me.
                                        And the Original Source. A good place for script ideas πŸ˜›
                                        Daniel S
                                        • T
                                          TeamSDA
                                          To: xrok1 πŸ‘
                                          The text is an example of brand specific text and thank you for all your helpful input.
                                          To: Daniel S πŸ‘
                                          The video is from a post you made, just wanted to reach out again to the ruby script community. Thanks for the link.
                                          Thank You All,
                                          Team SDA
                                          • onidarbeO
                                            onidarbe
                                            Can't it be more like a real quarter circle ?
                                            Can't it remove the corners instead ?
                                            see the attached jpg...
                                            Thanks.
                                            • 6 / 9
