    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 184.8k Views 83 Watching
    • free agentF
      free agent
      Funny(and sad) that Sketchup on version 7 needs to catchup with a beta release... interestingly bonzai 3d shares a render engine with modo (assuming that it has the same render engine as FormZ)
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
      • O
        Oaht
        Thanks for your superb plugin. This will save a lot of time!!!
        • B
          BorgMan
          It would be great if the Round Edges tool would work like that Bonzai3D image. I've had so much models which use complex shapes that totally effed up when I unleashed the RE tool on them, after which I had to manually retrace the outlines to make them work properly...
          More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
          You've gotta love Slivers.
          • G
            gio
            Can you tell me more about this, please?
            Do you have a link?
            It would really be a great news!
            Ciao, Gio
            • N
              numerobis
              (www.bonzai3d.com)
              (btw. google is your friend ๐Ÿ˜‰ )
              • X
                xrok1
                hi fredo, great script once more. ๐Ÿ˜ฒ
                did you ever figure out how to overcome this type of thing?
                โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                • T
                  TeamSDA
                  Hey Fredo
                  This is a great script we are having difficulties with its performance due to a high number of edges. We are currently working on how to extrude letters from .dwg files and we want to bevel the edges of the letters but they are made up of many edges and the script gets bogged down with the task. ๐ŸŽ‰
                  Team SDA
                  Here is the file we are currently working on.
                  Logo Tests.skp
                  • X
                    xrok1
                    did you try sds on that as you did with the other project?
                    • T
                      TeamSDA
                      Yes but we are having issues with extra lines showing up and the process is a little time consuming. Was hoping for a tool that was a little more simple in it's approach.
                      Team SDA
                      • X
                        xrok1
                        i think the follow me tool would be your best option there.
                        • X
                          xrok1
                          draw a face on the top edge perpendicular like this:face.jpg
                          select top face then followme tool then click on the drawn arc, then close the top face:follow.jpg
                          • fredo6F
                            Team SDA
                            If it is just to round the top and bottom faces, then I suggest you use xrok simple method with Follow me.
                            RoundEdge is more intended to handle the rounding of corners where you apply it to 3 or more edges.
                            The current method is not performing fast, I agree. The script was actually experimental and I did not rework on it recently. Obviously, this is not the right tool for a serial usage. Sorry for that.
                            • T
                              TeamSDA
                              Thank you all for your input. Looks like the follow me tool will work well for us on simple geometry. We hope that in the future someone will develop a commercial grade bull-nosing and filleting (edge smoothing) script with capabilities similar to what is depicted in the attached video.
                              Team SDA
                              Here is what we accomplished using the follow me tool on the edges of the letters. We also found that we could use it to make fillets on the bottom of the letters.
                              A Bull-nosing plugin with these capabilities would be ideal.
                              • X
                                xrok1
                                i would suggest that before you pushpull your letters you clean up the edges, there's no reason to have all those faces on the sides. better yet why don't you just use the SU 3Dtext tool?
                                  Daniel S
                                  Team SDA
                                  That video looks familiar to me.
                                  And the Original Source. A good place for script ideas ๐Ÿ˜›
                                  Daniel S
                                  • T
                                    TeamSDA
                                    To: xrok1 ๐Ÿ‘
                                    The text is an example of brand specific text and thank you for all your helpful input.
                                    To: Daniel S ๐Ÿ‘
                                    The video is from a post you made, just wanted to reach out again to the ruby script community. Thanks for the link.
                                    Thank You All,
                                    Team SDA
                                    • onidarbeO
                                      onidarbe
                                      Can't it be more like a real quarter circle ?
                                      Can't it remove the corners instead ?
                                      see the attached jpg...
                                      Thanks.
                                        driven
                                        Hi fredo,
                                        still trying all you great stuff,
                                        have you heard of issues with this on the mac. it's locked up sketchup a couple of times and never worked properly even on simple stuff, still using SU followme. I've uninstalled at the moment because SU itself has started glitching and I even had to re-boot (I think it's called) for the first time in 18mths.
                                        Freescale is working great.
                                        actually should I have it in the BZ_DIR_12 folder with the others or out on its own????
                                        cheers again
                                        • fredo6F
                                          @driven said:
                                          Hi fredo,
                                          I am not aware of specific issues on Mac with BzRoundEdge script. Did it work at least one or do you get a bugsplat or freeze right away?
                                          No confusion. BZ_DIR_12 folder belongs to the BezierSpline plugin, which is unrelated with RoundEdge.
                                          As a general Rule, never unbundle files from folders. Always unzip with SelectAll to make sure the folder hierarchy is reconstructed in the Sketchup Plugin directory.
                                            driven
                                            The bug slat/freeze happens during processing, and at first I thought it was due to my not waiting before starting my next step
                                            however, I now think it's a conflict with something else (either Podium or BezSpline)
                                            I'll try a complete fresh instal of SU and add a couple of new folders directly in HD>Lib>AppSuport>SU>(myrubyfolder and parkedrubyfolder)
                                            this make it easy to switch between rubies to see if I can find conflict (if it's still there)
                                            I was also trying to apply this to model , so I'll try it at component level and just smooth the end result...
                                            another thing is I find finding you scripts on this site, can you put up a Fredo6 [plugin]link in your signiture or somewhere?
                                            thanks for reply
                                            • 6 / 9
