    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 184.8k Views 83 Watching
    • free agentF
      free agent
      +100 this would be amazing
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
      • GaieusG
        +101!
        It's a cool plugin already now (although has some limitations like the Follow me can also have with concave curves) but a rounded corner (preferably an "option" vs the pointy one) would indeed be a great improvement!
          @daniel s said:
          With the holdiays, I am just resuming some work on my scripts. Indeed, I will try to fix issues with Round Edge (and maybe develop the spheric / elliptic option).
          Fredo, When you say to develop the spheric / elliptic option do you mean something like the attachment image?
          [attachment=0:1hhs0yf5]<!-- ia0 -->roundedges.jpg<!-- ia0 -->[/attachment:1hhs0yf5]
          That would be a huge improvement ๐Ÿ˜„
          Thank you again for this amazing must-have tool...
          Daniel S
          How did you do that?
          • free agentF
            free agent
            Bonzai3d...?
              jmmad
              SU needs and can catch up with bonzai3d
              Fredo this ruby + other transformation like twist and bend would be really great.
              Get Upa !
              • free agentF
                free agent
                Funny(and sad) that Sketchup on version 7 needs to catchup with a beta release... interestingly bonzai 3d shares a render engine with modo (assuming that it has the same render engine as FormZ)
                • O
                  Oaht
                  Thanks for your superb plugin. This will save a lot of time!!!
                  • B
                    BorgMan
                    It would be great if the Round Edges tool would work like that Bonzai3D image. I've had so much models which use complex shapes that totally effed up when I unleashed the RE tool on them, after which I had to manually retrace the outlines to make them work properly...
                    More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                    You've gotta love Slivers.
                    • G
                      gio
                      Can you tell me more about this, please?
                      Do you have a link?
                      It would really be a great news!
                      Ciao, Gio
                      • N
                        numerobis
                        (www.bonzai3d.com)
                        (btw. google is your friend ๐Ÿ˜‰ )
                        • X
                          xrok1
                          hi fredo, great script once more. ๐Ÿ˜ฒ
                          did you ever figure out how to overcome this type of thing?
                          โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                          • T
                            TeamSDA
                            Hey Fredo
                            This is a great script we are having difficulties with its performance due to a high number of edges. We are currently working on how to extrude letters from .dwg files and we want to bevel the edges of the letters but they are made up of many edges and the script gets bogged down with the task. ๐ŸŽ‰
                            Team SDA
                            Here is the file we are currently working on.
                            Logo Tests.skp
                            • X
                              xrok1
                              did you try sds on that as you did with the other project?
                              • T
                                TeamSDA
                                Yes but we are having issues with extra lines showing up and the process is a little time consuming. Was hoping for a tool that was a little more simple in it's approach.
                                Team SDA
                                • X
                                  xrok1
                                  i think the follow me tool would be your best option there.
                                  • X
                                    xrok1
                                    draw a face on the top edge perpendicular like this:face.jpg
                                    select top face then followme tool then click on the drawn arc, then close the top face:follow.jpg
                                    • fredo6F
                                      Team SDA
                                      If it is just to round the top and bottom faces, then I suggest you use xrok simple method with Follow me.
                                      RoundEdge is more intended to handle the rounding of corners where you apply it to 3 or more edges.
                                      The current method is not performing fast, I agree. The script was actually experimental and I did not rework on it recently. Obviously, this is not the right tool for a serial usage. Sorry for that.
                                      • T
                                        TeamSDA
                                        Thank you all for your input. Looks like the follow me tool will work well for us on simple geometry. We hope that in the future someone will develop a commercial grade bull-nosing and filleting (edge smoothing) script with capabilities similar to what is depicted in the attached video.
                                        Team SDA
                                        Here is what we accomplished using the follow me tool on the edges of the letters. We also found that we could use it to make fillets on the bottom of the letters.
                                        A Bull-nosing plugin with these capabilities would be ideal.
                                        • X
                                          xrok1
                                          i would suggest that before you pushpull your letters you clean up the edges, there's no reason to have all those faces on the sides. better yet why don't you just use the SU 3Dtext tool?
                                            Daniel S
                                            Team SDA
                                            That video looks familiar to me.
                                            And the Original Source. A good place for script ideas ๐Ÿ˜›
                                            Daniel S
                                            • 6 / 9
