    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 181.4k Views 83 Watching
    • N Offline
      numerobis
      (www.bonzai3d.com)
      (btw. google is your friend 😉 )
      • X Offline
        xrok1
        hi fredo, great script once more. 😲
        did you ever figure out how to overcome this type of thing?
          TeamSDA
          Hey Fredo
          This is a great script we are having difficulties with its performance due to a high number of edges. We are currently working on how to extrude letters from .dwg files and we want to bevel the edges of the letters but they are made up of many edges and the script gets bogged down with the task. 🎉
          Team SDA
          Here is the file we are currently working on.
          Logo Tests.skp
          • X Offline
            xrok1
            did you try sds on that as you did with the other project?
              TeamSDA
              Yes but we are having issues with extra lines showing up and the process is a little time consuming. Was hoping for a tool that was a little more simple in it's approach.
              Team SDA
              • X Offline
                xrok1
                i think the follow me tool would be your best option there.
                • X Offline
                  xrok1
                  draw a face on the top edge perpendicular like this:face.jpg
                  select top face then followme tool then click on the drawn arc, then close the top face:follow.jpg
                  • fredo6F Offline
                    Team SDA
                    If it is just to round the top and bottom faces, then I suggest you use xrok simple method with Follow me.
                    RoundEdge is more intended to handle the rounding of corners where you apply it to 3 or more edges.
                    The current method is not performing fast, I agree. The script was actually experimental and I did not rework on it recently. Obviously, this is not the right tool for a serial usage. Sorry for that.
                      TeamSDA
                      Thank you all for your input. Looks like the follow me tool will work well for us on simple geometry. We hope that in the future someone will develop a commercial grade bull-nosing and filleting (edge smoothing) script with capabilities similar to what is depicted in the attached video.
                      Team SDA
                      Here is what we accomplished using the follow me tool on the edges of the letters. We also found that we could use it to make fillets on the bottom of the letters.
                      A Bull-nosing plugin with these capabilities would be ideal.
                      • X Offline
                        xrok1
                        i would suggest that before you pushpull your letters you clean up the edges, there's no reason to have all those faces on the sides. better yet why don't you just use the SU 3Dtext tool?
                          Daniel S
                          Team SDA
                          That video looks familiar to me.
                          And the Original Source. A good place for script ideas 😛
                          Daniel S
                            TeamSDA
                            To: xrok1 👍
                            The text is an example of brand specific text and thank you for all your helpful input.
                            To: Daniel S 👍
                            The video is from a post you made, just wanted to reach out again to the ruby script community. Thanks for the link.
                            Thank You All,
                            Team SDA
                            • onidarbeO Offline
                              onidarbe
                              Can't it be more like a real quarter circle ?
                              Can't it remove the corners instead ?
                              see the attached jpg...
                              Thanks.
                                driven
                                Hi fredo,
                                still trying all you great stuff,
                                have you heard of issues with this on the mac. it's locked up sketchup a couple of times and never worked properly even on simple stuff, still using SU followme. I've uninstalled at the moment because SU itself has started glitching and I even had to re-boot (I think it's called) for the first time in 18mths.
                                Freescale is working great.
                                actually should I have it in the BZ_DIR_12 folder with the others or out on its own????
                                cheers again
                                • fredo6F Offline
                                  @driven said:
                                  Hi fredo,
                                  I am not aware of specific issues on Mac with BzRoundEdge script. Did it work at least one or do you get a bugsplat or freeze right away?
                                  No confusion. BZ_DIR_12 folder belongs to the BezierSpline plugin, which is unrelated with RoundEdge.
                                  As a general Rule, never unbundle files from folders. Always unzip with SelectAll to make sure the folder hierarchy is reconstructed in the Sketchup Plugin directory.
                                    driven
                                    The bug slat/freeze happens during processing, and at first I thought it was due to my not waiting before starting my next step
                                    however, I now think it's a conflict with something else (either Podium or BezSpline)
                                    I'll try a complete fresh instal of SU and add a couple of new folders directly in HD>Lib>AppSuport>SU>(myrubyfolder and parkedrubyfolder)
                                    this make it easy to switch between rubies to see if I can find conflict (if it's still there)
                                    I was also trying to apply this to model , so I'll try it at component level and just smooth the end result...
                                    another thing is I find finding you scripts on this site, can you put up a Fredo6 [plugin]link in your signiture or somewhere?
                                    thanks for reply
                                      driven
                                      thanks for reply
                                      • fredo6F Offline
                                        There is a known conflict with some version of Podium. I don't have the reference but it is documented somewhere in the Ruby discussion forum.
                                        For the freeze, yes, you have to wait until it completes. There is a progress bar showing where it stands. If you click, then you'll get an apparent freeze (but if you wait, it completes).
                                          Pico
                                          Has the pointy corner problem been solved?
                                          Thanx 😄
                                          • fredo6F Offline
                                            Thanx 😄
                                            Do you mean this?
                                            • 6 / 9
