    [Plugin] SunTool - new Mar 2009
    49 Posts 26 Posters 43.7k Views 26 Watching
    • MALAISEM Offline
      MALAISE
      Hi Guedi
      Interesting Plugin, but how to get a password ? I didn't see any link on the thread.
      Regards
      MALAISE
        SunTools
        MALAISE
        Register at:
        http://tx.technion.ac.il/~arrguedi/SunTools/download.html
        (make sure that you write your email correctly!!!)
        You will receive an email with the password for installation.
        Hope it helps,
        Guedi
        • MALAISEM Offline
          MALAISE
          Done, Thank you Guedi 😄
          MALAISE
          • EdsonE Offline
            Edson
            another plugin that does not run on macs... 😞
            http://www.mahfuz.arq.br
              Whenever that plugin is installed I hear a 'beep' from my speakers everytime SU loads. Are you using the Beep method in your code? If so, could you please remove it as it's rather annoying. Especially when I debug my own scripts and hear that beep every time.
                shirazbj
                "SunPath/Choose a day" is operated differently with other setting.
                After click SunPath button, I only got one orange line along an axis.Nothing else happen after i click the OK button to close the pop-up setting window.
                  SunTools
                  shirazbj: see my previous post about this subject:
                  ".....download an updated version of STbeta1.rbs and replace the existing file in Plugins/SunTools. ..."
                  http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/STbeta1.rbs
                  This will fix your problem!
                  thomthom: sorry, yes it beeps when SunTools is loaded. I'll remove this beep in the next version.
                  Guedi
                    Thanks.
                      rv1974
                      Sorry for dumb question but what exactly "target tool" does?
                      In my case the viewer position jumps under the ground (at the same time I get a lot of "Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>" in the ruby panel). May be something is wrong?
                        SunTools
                        rv1974:
                        Not a dumb question at all!
                        This tools allows the analysis of solar access in one point (inside or outside buildings).
                        It presents a view of how your point sees the sky (and the sun), in a way that you can asses in one unique view when that point is lighted (directly) by the sun during the whole year.
                        First, draw the path of the sun using the SunPath Tools.
                        Second choose Target Tool:
                        --Look at >> will define the point on the sky that you are looking at. It will be the center of the screen. To start just leave the default [December 12:00], you can rotate your view afterward to see different parts of the sky (see help file).
                        --Select the point for analysis >> just prepare in advance a point in the space that you would like to check. Inside a building it can be a seating position, if you want to check glare sources; outside buildings it can be an open space, or a solar system....
                        That's it. Let me know if it was clear enough.
                        Guedi
                          rv1974
                          Ooops I accidentally skipped the help file on the download page . that's why.. May be you should integrate it into setup.exe?
                            SunTools
                            IT IS integrated in the setup.exe. Look at Plugins/SunTools.
                            Guedi
                              rv1974
                              I meant may be it should pop up after installation (or I missed it 😄Anyway many thanks!
                              Another thing. Guedi do you have plans to make the interactive sun (ie moving sun dummy would affect su shadows, thomething like in 3ds max ?)
                                SunTools
                                A new version of SunTools Plugin (V2.0) for SketchUp is available now.
                                The new version incorporates the calculation and visualization of Visible / Obstructed Sky from any point in a project (exterior/interior), and improvements of existing features as suggested by users.
                                Plug-in Features
                                • SunPATH: visualization (month and year)
                                • SunPOS: Sun Position for a date and time
                                • SunVIEW: Axonometric views from the Sun
                                • SunPENETRATION: Analyze Sun Penetration/Access in any specific analysis point.
                                  New!
                                • SkyVIEW: Calculate Sky Solid Angle (SSA) and % of visible sky / Visualize Visible/Obstructed sky from any point in your project
                                V2.0 of the plug-in can be downloaded after registration from: http://tx.technion.ac.il/~arrguedi/SunTools/download.html
                                A short documentation file can be viewed at: http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/sunTools_helpV2.pdf
                                ** A Mac version of the plug-in will be available next. 👍
                                Enjoy.
                                Guedi Capeluto
                                arrguedi@technion.ac.il
                                • kenK Offline
                                  ken
                                  Hello
                                  Well I installed the new version of SunTool 2.0 and I get the following plugin starting each time I start Sketchup. Anyone else with this problem.
                                  Ken
                                    Me too. Disabled it till it's fixed... Tried to limit it loading via an enclosing ruby but that fails - it's a compiled rbs...
                                      SunTools
                                      Ken and TIG (maybe others with the same issue).
                                      Thanks for the feedback,
                                      It seems like a conflict of names, I'll fix it today, and put an updated version for download.
                                      Guedi
                                        SunTools
                                        an updated version of the installer can be downloaded now.
                                        Hope this solve the problem. Please let me know.
                                        Guedi
                                        • kenK Offline
                                          ken
                                          @suntools said:
                                          Guedi
                                          New version did the trick, no more loading another script during start up.
                                          Ken
                                            SunTools
                                            Hello Mac Users,
                                            Following the previous announcement, SunTools Plugin for SketchUp is available now also for MAC !!
                                            It can be downloaded after registration from: http://tx.technion.ac.il/~arrguedi/SunTools/download.html
                                            Enjoy!!!
                                            Guedi
                                            • 1 / 3
