ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
[Plugin] SunTool - new Mar 2009
49 Posts 26 Posters 40.2k Views
  • F Offline
    facer
    Check out free plugin that shows suns path, months, hours etc:
    http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/STdwnld.htm
    Works on SketchUp7 and for SketchUp6 (In INSTALL process have to direct it to SketchUp 6/plugin - as noted in SunTool Help file)
      DonVid
      Greetings:
      The installation calls for a password?
      DonVid
        bianhai
        Thanks! It's good suntools! 👍
        DonVid,you registration after the password e-mail.
          SunTools
          Hello ALL
          Thanks for using SunTools, I'll be happy to receive your feedback and suggestions.
          Enjoy,
          Guedi
            mattg
            Hey Guedi,
            the tool that plots the path of the sun around an object doesn't seem to be working whilst all the other tools are.
            Have you had any problems with this tool before?
            Im using Sketchup 7
              sunlu4039
                SunTools
                mattg (and others having problems with SunPath visualization)
                (I hope) I fixed this bug....download an updated version of STbeta1.rbs and replace the existing file in Plugins/SunTools. Let me know if it worked!
                http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/STbeta1.rbs
                Guedi
                • W Offline
                  watkins
                  Dear Guedi,
                  Shalom Aleichem, and thanks for making your sun tool available to the Forum.
                  Do you have any tutorial videos showing your plugin in action? Anything on YouTube?
                  Kind regards,
                  Bob
                    SunTools
                    Bob,
                    Sorry no videos yet. Maybe someone in the forum can prepare one? 😉
                    A --very short-- help file is available here:
                    http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/sunTools_help.pdf
                    Guedi
                      MALAISE
                      Hi Guedi
                      Interesting Plugin, but how to get a password ? I didn't see any link on the thread.
                      Regards
                      MALAISE
                        SunTools
                        MALAISE
                        Register at:
                        http://tx.technion.ac.il/~arrguedi/SunTools/download.html
                        (make sure that you write your email correctly!!!)
                        You will receive an email with the password for installation.
                        Hope it helps,
                        Guedi
                          MALAISE
                          Done, Thank you Guedi 😄
                          MALAISE
                          • E Offline
                            Edson
                            another plugin that does not run on macs... 😞
                            http://www.mahfuz.arq.br
                              Whenever that plugin is installed I hear a 'beep' from my speakers everytime SU loads. Are you using the Beep method in your code? If so, could you please remove it as it's rather annoying. Especially when I debug my own scripts and hear that beep every time.
                                shirazbj
                                "SunPath/Choose a day" is operated differently with other setting.
                                After click SunPath button, I only got one orange line along an axis.Nothing else happen after i click the OK button to close the pop-up setting window.
                                  SunTools
                                  shirazbj: see my previous post about this subject:
                                  ".....download an updated version of STbeta1.rbs and replace the existing file in Plugins/SunTools. ..."
                                  This will fix your problem!
                                  thomthom: sorry, yes it beeps when SunTools is loaded. I'll remove this beep in the next version.
                                  Guedi
                                    Thanks.
                                      rv1974
                                      Sorry for dumb question but what exactly "target tool" does?
                                      In my case the viewer position jumps under the ground (at the same time I get a lot of "Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>" in the ruby panel). May be something is wrong?
                                        SunTools
                                        rv1974:
                                        Not a dumb question at all!
                                        This tools allows the analysis of solar access in one point (inside or outside buildings).
                                        It presents a view of how your point sees the sky (and the sun), in a way that you can asses in one unique view when that point is lighted (directly) by the sun during the whole year.
                                        First, draw the path of the sun using the SunPath Tools.
                                        Second choose Target Tool:
                                        --Look at >> will define the point on the sky that you are looking at. It will be the center of the screen. To start just leave the default [December 12:00], you can rotate your view afterward to see different parts of the sky (see help file).
                                        --Select the point for analysis >> just prepare in advance a point in the space that you would like to check. Inside a building it can be a seating position, if you want to check glare sources; outside buildings it can be an open space, or a solar system....
                                        That's it. Let me know if it was clear enough.
                                        Guedi
                                          rv1974
                                          Ooops I accidentally skipped the help file on the download page . that's why.. May be you should integrate it into setup.exe?
                                          • 1 / 3
                                          1 / 3
