    [Plugin] SunTool - new Mar 2009
    49 Posts 26 Posters 44.3k Views 26 Watching
      SunTools
      mattg (and others having problems with SunPath visualization)
      (I hope) I fixed this bug....download an updated version of STbeta1.rbs and replace the existing file in Plugins/SunTools. Let me know if it worked!
      http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/STbeta1.rbs
      Guedi
      • W Offline
        watkins
        Dear Guedi,
        Shalom Aleichem, and thanks for making your sun tool available to the Forum.
        Do you have any tutorial videos showing your plugin in action? Anything on YouTube?
        Kind regards,
        Bob
          SunTools
          Bob,
          Sorry no videos yet. Maybe someone in the forum can prepare one? 😉
          A --very short-- help file is available here:
          http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/sunTools_help.pdf
          Guedi
          • MALAISEM Offline
            MALAISE
            Hi Guedi
            Interesting Plugin, but how to get a password ? I didn't see any link on the thread.
            Regards
            MALAISE
              SunTools
              MALAISE
              Register at:
              http://tx.technion.ac.il/~arrguedi/SunTools/download.html
              (make sure that you write your email correctly!!!)
              You will receive an email with the password for installation.
              Hope it helps,
              Guedi
              • MALAISEM Offline
                MALAISE
                Done, Thank you Guedi 😄
                MALAISE
                • EdsonE Offline
                  Edson
                  another plugin that does not run on macs... 😞
                  http://www.mahfuz.arq.br
                    Whenever that plugin is installed I hear a 'beep' from my speakers everytime SU loads. Are you using the Beep method in your code? If so, could you please remove it as it's rather annoying. Especially when I debug my own scripts and hear that beep every time.
                      shirazbj
                      "SunPath/Choose a day" is operated differently with other setting.
                      After click SunPath button, I only got one orange line along an axis.Nothing else happen after i click the OK button to close the pop-up setting window.
                        SunTools
                        shirazbj: see my previous post about this subject:
                        ".....download an updated version of STbeta1.rbs and replace the existing file in Plugins/SunTools. ..."
                        This will fix your problem!
                        thomthom: sorry, yes it beeps when SunTools is loaded. I'll remove this beep in the next version.
                        Guedi
                          Thanks.
                            rv1974
                            Sorry for dumb question but what exactly "target tool" does?
                            In my case the viewer position jumps under the ground (at the same time I get a lot of "Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>" in the ruby panel). May be something is wrong?
                              SunTools
                              rv1974:
                              Not a dumb question at all!
                              This tools allows the analysis of solar access in one point (inside or outside buildings).
                              It presents a view of how your point sees the sky (and the sun), in a way that you can asses in one unique view when that point is lighted (directly) by the sun during the whole year.
                              First, draw the path of the sun using the SunPath Tools.
                              Second choose Target Tool:
                              --Look at >> will define the point on the sky that you are looking at. It will be the center of the screen. To start just leave the default [December 12:00], you can rotate your view afterward to see different parts of the sky (see help file).
                              --Select the point for analysis >> just prepare in advance a point in the space that you would like to check. Inside a building it can be a seating position, if you want to check glare sources; outside buildings it can be an open space, or a solar system....
                              That's it. Let me know if it was clear enough.
                              Guedi
                                rv1974
                                Ooops I accidentally skipped the help file on the download page . that's why.. May be you should integrate it into setup.exe?
                                  SunTools
                                  IT IS integrated in the setup.exe. Look at Plugins/SunTools.
                                  Guedi
                                    rv1974
                                    I meant may be it should pop up after installation (or I missed it 😄Anyway many thanks!
                                    Another thing. Guedi do you have plans to make the interactive sun (ie moving sun dummy would affect su shadows, thomething like in 3ds max ?)
                                      SunTools
                                      A new version of SunTools Plugin (V2.0) for SketchUp is available now.
                                      The new version incorporates the calculation and visualization of Visible / Obstructed Sky from any point in a project (exterior/interior), and improvements of existing features as suggested by users.
                                      Plug-in Features
                                      • SunPATH: visualization (month and year)
                                      • SunPOS: Sun Position for a date and time
                                      • SunVIEW: Axonometric views from the Sun
                                      • SunPENETRATION: Analyze Sun Penetration/Access in any specific analysis point.
                                        New!
                                      • SkyVIEW: Calculate Sky Solid Angle (SSA) and % of visible sky / Visualize Visible/Obstructed sky from any point in your project
                                      V2.0 of the plug-in can be downloaded after registration from: http://tx.technion.ac.il/~arrguedi/SunTools/download.html
                                      A short documentation file can be viewed at: http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/sunTools_helpV2.pdf
                                      ** A Mac version of the plug-in will be available next. 👍
                                      Enjoy.
                                      Guedi Capeluto
                                      arrguedi@technion.ac.il
                                      • kenK Offline
                                        ken
                                        Hello
                                        Well I installed the new version of SunTool 2.0 and I get the following plugin starting each time I start Sketchup. Anyone else with this problem.
                                        Ken
                                          Me too. Disabled it till it's fixed... Tried to limit it loading via an enclosing ruby but that fails - it's a compiled rbs...
                                            SunTools
                                            Ken and TIG (maybe others with the same issue).
                                            Thanks for the feedback,
                                            It seems like a conflict of names, I'll fix it today, and put an updated version for download.
                                            Guedi
                                            • 1 / 3
