    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • jeff hammondJ Offline
      yeah, i see what you're saying..
      i guess this was just an easy one to do with the move tool but i could see how it could get very frustrating with more faces to select.
        jmmad -- i agree there are some amazing plugins being created these days..
        but let's not forget about sketchup's native tools
        [flash=600,405:2i21shh9]http://www.youtube.com/v/plAb63jVXbw&hl=en&fs=1&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:2i21shh9]
        [edit] after a second look at your example image, maybe this isn't what you're trying to achieve
        • fredo6F Offline
          NEW VERSION 2.0c
          See details in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
          You also need to download LibFredo6 3.1c
          • massimoM Offline
            massimo Moderator
            Fredo, i have upgraded your amazing free scale tool. I have noticed a strange behaviour. When you use, for example, the scale tool the model has a sort of instantaneous jump and then return to his proper size. Is that normal? Thanks.
            • fredo6F Offline
              You're right. No clue what it is.
              I put back the previous version in the main posts.
              TO ALL: Please go back to version level b of FreeScale and LibFredo6 if ever you dowloaded the c version
              • boofredlayB Offline
                boofredlay
                LibFredo6 3.1c as well?
                • fredo6F Offline
                  Did any one notice the flickering in 2.0b?
                  • fredo6F Offline
                    Actually the flickering effect was already in version 2.0b. Strange that I did not notice (and none until Massimo).
                    • massimoM Offline
                      massimo Moderator
                      True Fredo. But the very strange thing is that i did not notice the flickering (in "b" version i mean) until i went back from "c" to "b" version.
                        Jackson
                        Absolutely amazing plugin Fredo, words fail me for this incredible achievement and generosity- such a useful and well-designed ruby! Donation is on its way as soon as pay day arrives.
                        Jackson
                        • fredo6F Offline
                          Coen,
                          I added the native Protractor feature in the (c) releases of LibFredo6 and FreeScale.
                          Any other feature with the protractor that I do not know about?
                          • fredo6F Offline
                            NEW VERSION 2.0c NOW RELEASED
                            PS: the reason of the dealy was a small flickering effect when manipulating the deformation box. Actually, it was in version b already. It is hopefully fixed now.
                            • McGyverM Offline
                              McGyver
                              Brilliant,intuitive and simply fantastic... this should have come with SU to begin with.... heck google should beg you to make stuff for them! You are the Ruby-Master!! Thanks a million!!
                              [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
                              • david_hD Offline
                                david_h
                                For some strange reason the Radial Bend feature just stopped working? everything else seems fine. Or maybe I am not using it right? Any ideas?
                                  remus
                                  Your not trying it on a highly grouped/compenented model by any chance? As far as i can tell things start to go funny when youve got more than 2 levels of groups.
                                  • fredo6F Offline
                                    David,
                                    What is the exact problem:
                                    • does it crash or bug splat?
                                    • Do you see the protractor and can you use it?
                                    • do you see the wireframe?
                                    • bagateloB Offline
                                      bagatelo
                                      I liked that plugin a lot, this is saving a lot of my time. But...
                                      I don't know if I will get to explain the problem of behavior of the plugin that doesn't please me, but I will try.
                                      My displeasure is regarding the Icon "Stretching with Box by matching an origin and the target." After it is chosen the plan where Stretch should happen, I cannot use a relationship of distance among distant objects as it could use the command MOVES common of Sketchup. I need to draw a line or object to the close origin point and the close target point to make Stretch. It would be interesting if it went as in the command it MOVES of the sketchup, where I can use points of it distances wanted distant of the object that desire to make Stretch.
                                      • fredo6F Offline
                                        NEW VERSION 2.0d
                                        It fixes a major bug introduced in 2.0c for the target mode of Scale, Stretch, Shear, and also for setting the dimensions via the dialog box. Sorry for inconvenience.
                                        So it is strongly advised to upgrade.
                                        As a bonus, you'll get the Korean translation by Couque D`asse.
                                        All details are in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                                        Note: You will also need to download LibFredo6 3.1d
                                        • utilerU Offline
                                          utiler
                                          'Thanks Fredo' seems so insignificant!!!
                                          Just Curious...
                                          • david_hD Offline
                                            david_h
                                            Fredo. . .
                                            Downloaded the latest version and the bending works now. But the Icons don't show up on the tool bar. I had them before just fine . . .now I don't.
                                            I just didn't get a chance to mention it. I had this problem with 2.0c as well.
                                            DO they icons png's belong in their own subfolder?
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 56
                                            • 57
                                            • 31 / 57
