    Filetting and Bullnosing Edges
    25 Posts 8 Posters 5.3k Views 8 Watching
    • G
      gaganraj
      you can also use subdivide and smooth. run bevels along all the faces very close to the edge. then subdivide.
      • T
        TeamSDA
        Looks great ๐Ÿ‘ xrok1. Could you describe how you used the bezier tool to smooth the edges. Does this require a specific bezier plugin. If so could you please provide a link.
        Thank you
        TeamSDA
        • X
          xrok1
          here is a link to the round edge plugin: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10370&st=0&sk=t&sd=a&hilit=roundedge
          you will need to explode your groups then dblclick the top face and run the plugin. i used 1/4" and 3 segments but it would probably look nicer with about 5.
          please post your results for us!
          โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          • ely862meE
            ely862me
            My option would be sds ..but depends of each one and depends of size
            Pod SDS.skp
            Elisei (sketchupper)
            Come and See EliseiDesign
            • T
              TeamSDA
              Hi ely862me,
              Could you expand on "sds" as we are not sure as to what this acronym is? Also went to you website and you have done some amazing work. Are you achieving all the organic shapes via SketchUp or are you using another program such as Cinema 4D. We use this program in house and have considered round tripping to accomplish complex geometry and texture mapping. Would prefer staying with SketchUp as our modeler and C4D for all animations and final visualization.
              Value your input,
              TeamSDA
                dylan
                SDS is Sub Divide and Smooth
                A commercial script available here with videos
                SDS - Smustard
                http://dmdarchitecture.co.uk/
                • X
                  xrok1
                  subdivision surfaces ๐Ÿ˜‰
                  check it out here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=80&t=17253&st=0&sk=t&sd=a&hilit=subdivide
                  and it does say on ely862me's website that all the cars are made with sketchup.
                  • T
                    TeamSDA
                    Thank You SketchUcation Community,
                    Not sure how we missed this one on the Smustard site as we went their first. Appreciate all your input. We are going to try the Smustard plugin as it looks to be just what we are looking for.
                    Have a good one,
                    TeamSDA
                    • T
                      TeamSDA
                      Hey we have looked at the tool and its training. We are still a little vague on how to use the tool. For example we would like to know if we could use this tool to smooth certain edges of the pod and leave others unsmoothed. Any additional info/resources would be appreciated.
                      Thank you,
                      TeamSDA
                        dylan
                        You can use the Crease tool in SDS to keep some edges from being completely smoothed. It may help a little.
                        • ely862meE
                          ely862me
                          is quite simple..
                          u first have to make the normal mesh but low poly
                          then the lines u want to be sharpen add another round of lines near them
                          • X
                            xrok1
                            very nice, that post should be copied to the sds thread. very helpful tip for using sds. thank you.
                            • ely862meE
                              ely862me
                              My pleasure ...
                              Elisei
                              • ely862meE
                                ely862me
                                I ll try to compose a simple tutorial
                                lets make the main body of an electric guitar :
                                1:draw the main shape
                                2:pull it up to achieve the body
                                3:ad the extra lines (i selected the perimeter and copy paste it on blue axis nearby the up and down perimeter )
                                4:remove the extra faces for a proper result
                                5:run sds
                                6:this is what sds made without those extra lines
                                7:if u do need more sharpen corners add another round of extra lines(this time i just made an offset)
                                8:this is the result for 7 after running the sds
                                Pretty cool ha?!!(and i figured it all by myself) ๐Ÿ˜†
                                cheers!!
                                hope it helps
                                Elisei
                                electric quitar.skp
                                • X
                                  xrok1
                                  hey! you can also do it this way and save about a third of the polys. plus you are sure that the front and back are flat. ๐Ÿ˜„cap.jpg
                                  • ely862meE
                                    ely862me
                                    yeah u can...just on flat areas
                                    • T
                                      Tekkybot
                                      @ely862me said:
                                      is quite simple..
                                      man! i own this plugin! i thought subdivide and smooth was just a cool gimic that nobody actauly used how wrong i was. installing now โ˜€
                                      • T
                                        TeamSDA
                                        Hi Elisei
                                        Your input has been quite liberating. We took your advice and built a low poly mesh from scratch then used the sds to smooth it out. We are not as quick as you appear to be, but your advice looks like it will open the door to a lot more creative freedom in sketch up. Below is the new Pod we built using your technique.
                                        TeamSDA
                                        p.s. Your technique of adding more lines to reduce the amount of smoothing on edges works great. ๐Ÿ‘
                                        p.p.s. We know that turning off hidden geometry in the view menu gets rid of all the mesh lines but there are still artifact lines showing up that we would like to get rid of, have you ever had this problem and if so do you have any ideas about how to fix it.
                                        JVC Pod.skp
                                        • ely862meE
                                          ely862me
                                          select the geometry right click and click on soften/smooth edges (check the soften coplanar too)
                                          • bazB
                                            baz
                                            Hi eliesi,
                                            I downloaded your guitar skp to try this out and it worked perfectly with your model but when I tried it with a different shape I got this...
                                            Any idea what I'm doing wrong?
