    Filetting and Bullnosing Edges
    25 Posts 8 Posters 4.8k Views 8 Watching
      TeamSDA
      Hi ely862me,
      Could you expand on "sds" as we are not sure as to what this acronym is? Also went to you website and you have done some amazing work. Are you achieving all the organic shapes via SketchUp or are you using another program such as Cinema 4D. We use this program in house and have considered round tripping to accomplish complex geometry and texture mapping. Would prefer staying with SketchUp as our modeler and C4D for all animations and final visualization.
      Value your input,
      TeamSDA
        dylan
        SDS is Sub Divide and Smooth
        A commercial script available here with videos
        SDS - Smustard
        http://dmdarchitecture.co.uk/
        • X Offline
          xrok1
          subdivision surfaces ๐Ÿ˜‰
          check it out here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=80&t=17253&st=0&sk=t&sd=a&hilit=subdivide
          and it does say on ely862me's website that all the cars are made with sketchup.
          โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            TeamSDA
            Thank You SketchUcation Community,
            Not sure how we missed this one on the Smustard site as we went their first. Appreciate all your input. We are going to try the Smustard plugin as it looks to be just what we are looking for.
            Have a good one,
            TeamSDA
              TeamSDA
              Hey we have looked at the tool and its training. We are still a little vague on how to use the tool. For example we would like to know if we could use this tool to smooth certain edges of the pod and leave others unsmoothed. Any additional info/resources would be appreciated.
              Thank you,
              TeamSDA
                dylan
                You can use the Crease tool in SDS to keep some edges from being completely smoothed. It may help a little.
                • ely862meE Offline
                  ely862me
                  is quite simple..
                  u first have to make the normal mesh but low poly
                  then the lines u want to be sharpen add another round of lines near them
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                  • X Offline
                    xrok1
                    very nice, that post should be copied to the sds thread. very helpful tip for using sds. thank you.
                    • ely862meE Offline
                      ely862me
                      My pleasure ...
                      Elisei
                      • ely862meE Offline
                        ely862me
                        I ll try to compose a simple tutorial
                        lets make the main body of an electric guitar :
                        1:draw the main shape
                        2:pull it up to achieve the body
                        3:ad the extra lines (i selected the perimeter and copy paste it on blue axis nearby the up and down perimeter )
                        4:remove the extra faces for a proper result
                        5:run sds
                        6:this is what sds made without those extra lines
                        7:if u do need more sharpen corners add another round of extra lines(this time i just made an offset)
                        8:this is the result for 7 after running the sds
                        Pretty cool ha?!!(and i figured it all by myself) ๐Ÿ˜†
                        cheers!!
                        hope it helps
                        Elisei
                        electric quitar.skp
                        • X Offline
                          xrok1
                          hey! you can also do it this way and save about a third of the polys. plus you are sure that the front and back are flat. ๐Ÿ˜„cap.jpg
                          • ely862meE Offline
                            ely862me
                            yeah u can...just on flat areas
                              Tekkybot
                              @ely862me said:
                              is quite simple..
                              man! i own this plugin! i thought subdivide and smooth was just a cool gimic that nobody actauly used how wrong i was. installing now โ˜€
                                TeamSDA
                                Hi Elisei
                                Your input has been quite liberating. We took your advice and built a low poly mesh from scratch then used the sds to smooth it out. We are not as quick as you appear to be, but your advice looks like it will open the door to a lot more creative freedom in sketch up. Below is the new Pod we built using your technique.
                                TeamSDA
                                p.s. Your technique of adding more lines to reduce the amount of smoothing on edges works great. ๐Ÿ‘
                                p.p.s. We know that turning off hidden geometry in the view menu gets rid of all the mesh lines but there are still artifact lines showing up that we would like to get rid of, have you ever had this problem and if so do you have any ideas about how to fix it.
                                JVC Pod.skp
                                • ely862meE Offline
                                  ely862me
                                  select the geometry right click and click on soften/smooth edges (check the soften coplanar too)
                                  • bazB Offline
                                    baz
                                    Hi eliesi,
                                    I downloaded your guitar skp to try this out and it worked perfectly with your model but when I tried it with a different shape I got this...
                                    Any idea what I'm doing wrong?
                                    • ely862meE Offline
                                      ely862me
                                      It looks like you have some internal faces which affects the final result.
                                      Also keep in mind that u MUST make a low poly model(what u have there is more like the final model-the polycount will be enormous), then apply the subdivide.
                                        Baz: are you trying to make a fillet on the edge? In which case you want to look into Fredo's RoundCorner plugin.
                                        • bazB Offline
                                          baz
                                          hi guys, thanks for replies, I must admit, after getting suv8, I havent reloaded this ruby. 'Round corners' does the trick when necessary.
                                          Happy Christmas and a prosperous New Year, everyone.
                                          Baz
