    Need help makeing screw edge
    26 Posts 9 Posters 5.0k Views 9 Watching
      If the problem is that FollowMe twists, then you could try this plugin: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16465
      • B
        Blah11
        this is a great plugin though I have another problem now, it does this when I do it,
        http://i228.photobucket.com/albums/ee18/Troopermanaic/1-4.jpg
        Whats up with all those menus on the right? I didn't get those when I installed the plugin.
          Hm.. it looks like it's twisting 180 degrees. How is your line built? multiple curves? I'm wondering if the normals are flipped for each segment.
          I'd try to weld all the lines making up the path and try then.
          If that fails, Try to use the tool only one of your segments that does work, and then copy the extruded segment afterwards.
          And you might want to mention this to the author of the plugin. He might tell why.
          The buttons on the right is not part of the plugin. That some kind of organizer plugin of some sort.
          • B
            Blah11
            didn't work, looks like the problem is that the box isn't going around the loop following the lines instead it wants to stay upright and when it gets close to the sides it glitches. on the right is one segment.
            http://i228.photobucket.com/albums/ee18/Troopermanaic/8.jpg
              Hmmm. yea. What happens when you use the regular FollowMe?
              Can you post the model? Or the parts that's causing problems?
              • B
                Blah11
                what happens in the regular follow me tool is that if you follow the entire loop then the shape starts to turn a little kinda like this
                http://www.korthalsaltes.com/foto/twisted_rectangular_prism.jpg
                but extremely small so that by the time you end the loop it seems that you can see the bottom end.
                • B
                  Blah11
                  OH that worked Jeff thanks. Will upload a few shots in the gallery when I'm done ill leave this post here for anyone else who wants to make screws and bolts.
                  • jeff hammondJ
                    weird.. i just tried it and i ended up with similar results..
                    then, i tried it with the helix laying flat instead of sideways and it worked.. so yeah, draw the helix and threads Then rotate it vertically
                    screw.skp
                    [EDIT] oh, i should add that i used 1001bit's extrude tool for that skp.. i also did the same thing with FAK.rb though and both acted in similar manners regarding the vertical/horizontal orientation.
                    • jeff hammondJ
                      and i might point this out before you get too much further into the model..
                      the threads are going the wrong way in this picture (well, not necessarily 'wrong' but opposite of the standard)
                      remember: righty tighty, lefty loosey 😄
                      • B
                        Blah11
                        that is going to the Right think about turning counterclockwise thats how it goes.
                        • jeff hammondJ
                          hmm.. i'm gonna have to disagree with that.. (well, sort of).
                          you're right, the way you have it drawn is to turn it counter-clockwise in order to tighten it.. usually, you turn a screw counter-clockwise if you want to loosen it.
                          • B
                            Blah11
                            oh yeah your right.
                            • david_hD
                              david_h
                              always remember. . .Lefty-Loosie! Righty-Tighty! 🤣
                              • Z
                                ziggy7
                                That is just a general rule of thumb, there are many items and bolts out there (especially in the automotive world) that are the opposite due to a rotation of a part and not wanting it to un-thread during operation.
                                • david_hD
                                  david_h
                                  yes. . .this is true. I just like saying lefty-looie.
                                  • takesh hT
                                    takesh h
                                    What's happening here is very logical.
                                    You are using a Ruby that keeps a section profile always "upright standing".
                                    Imagine what the profile could do when the path is also vertical...
                                    And look carefully Blah 11, you are not getting your threads right at any points of the spiral except at the bottom (as in the 3rd image).
                                    The solution for the problem is, I assume, to make the reference path stand up and then re-apply the ruby.
                                    Hope the images will explain it better.
                                      remus
                                      Well spotted takesh 👍
                                      • jeff hammondJ
                                        i'm not really following this.. what do you mean by 'you are not getting your threads right at any points of the spiral except at the bottom' ?
                                        is that in reference to the original post or the state of the thread when you made your post? as far as i can figure, the threads are correct at all points of the spiral (i'm talking about the .skp in the 8th post of the thread).. are you saying something is wrong with that that i'm not noticing?
                                        • GaieusG
                                          It's about "Follow me and keep" plugin, Jeff. As it works,it will always keep the profile straight along the Z axis so you have the correct results (in this case) if you follow a spiral wound up along the Z axis.
                                          • takesh hT
                                            takesh h
                                            Oh this is a solved problem... sorry I didn't see the solution has been posted. Missed your model in post #8.
                                            I saw the image in post #11 and thought it's an ongoing problem.
                                            I was refering to blah11's quoted image in post #11.
                                            While I was looking at Jeff's model, an odd thought came down to me.
                                            This whole thing can be done without using Ruby - I'll explain.
                                            BTW you can do it as elements horizontally lying down (as in the image in post#11) with this method.
                                            A spiral with a single turn will do the job. This can be created by rotating a top face of a cylinder and multipy it vertically.
                                            Copy the spiral to match dimensions of the thread needed. Draw a cylinder with the same number of edges as the spirals and create faces between them. Erase unneeded faces.  Select faces that's to be the top of teeth, resize them gripping edge midpoint, in one dimension (width only), from center.
                                            Voila
                                            Now multiply the created geometry verticaly as many times as you need.
