    Need help makeing screw edge
    26 Posts 9 Posters 4.3k Views 9 Watching
    • jeff hammondJ Offline
      hmm.. i'm gonna have to disagree with that.. (well, sort of).
      you're right, the way you have it drawn is to turn it counter-clockwise in order to tighten it.. usually, you turn a screw counter-clockwise if you want to loosen it.
        Blah11
        oh yeah your right.
        • david_hD Offline
          david_h
          always remember. . .Lefty-Loosie! Righty-Tighty! 🀣
          • Z Offline
            ziggy7
            That is just a general rule of thumb, there are many items and bolts out there (especially in the automotive world) that are the opposite due to a rotation of a part and not wanting it to un-thread during operation.
            • david_hD Offline
              david_h
              yes. . .this is true. I just like saying lefty-looie.
              • takesh hT Offline
                takesh h
                What's happening here is very logical.
                You are using a Ruby that keeps a section profile always "upright standing".
                Imagine what the profile could do when the path is also vertical...
                And look carefully Blah 11, you are not getting your threads right at any points of the spiral except at the bottom (as in the 3rd image).
                The solution for the problem is, I assume, to make the reference path stand up and then re-apply the ruby.
                Hope the images will explain it better.
                  remus
                  Well spotted takesh πŸ‘
                    i'm not really following this.. what do you mean by 'you are not getting your threads right at any points of the spiral except at the bottom' ?
                    is that in reference to the original post or the state of the thread when you made your post? as far as i can figure, the threads are correct at all points of the spiral (i'm talking about the .skp in the 8th post of the thread).. are you saying something is wrong with that that i'm not noticing?
                      It's about "Follow me and keep" plugin, Jeff. As it works,it will always keep the profile straight along the Z axis so you have the correct results (in this case) if you follow a spiral wound up along the Z axis.
                      • takesh hT Offline
                        takesh h
                        Oh this is a solved problem... sorry I didn't see the solution has been posted. Missed your model in post #8.
                        I saw the image in post #11 and thought it's an ongoing problem.
                        I was refering to blah11's quoted image in post #11.
                        While I was looking at Jeff's model, an odd thought came down to me.
                        This whole thing can be done without using Ruby - I'll explain.
                        BTW you can do it as elements horizontally lying down (as in the image in post#11) with this method.
                        A spiral with a single turn will do the job. This can be created by rotating a top face of a cylinder and multipy it vertically.
                        Copy the spiral to match dimensions of the thread needed. Draw a cylinder with the same number of edges as the spirals and create faces between them. Erase unneeded faces.  Select faces that's to be the top of teeth, resize them gripping edge midpoint, in one dimension (width only), from center.
                        Voila
                        Now multiply the created geometry verticaly as many times as you need.
                          Blah11
                          OK its not the best but I am proud of my accomplishment heres a preview of the screw edge
                          http://i228.photobucket.com/albums/ee18/Troopermanaic/1111.jpg
                          I knew it would be valuable for me to come to this forum. Now is there a plugin that can turn things inside out? I would much rather do that instead of making the other edge which is a pain.
                          • takesh hT Offline
                            takesh h
                            Look what you got there Blah, it's already reversed!
                            I mean, it's a matter of which way you extend these thread surfaces as a volume, introverted or extroverted.
                            Or am I missing something?
                            Just group them and make a copy in the place.
                            Keep modeling one of them as an internal volume, and the other as an external volume.
                              Blah11
                              I wasn't thinking when I modeled it I hollowed the inside, I guess it doesn't matter I found a different way to do the 2nd part anyway thanks,
                              • gillesG Offline
                                gilles
                                http://www.crai.archi.fr/rubylibrarydepot/ruby/screw1_5.rb
                                try this.
                                • 2 / 2
