    KT fast start 4Architects (Kerkythea render engine)
    extensions
    64 Posts 27 Posters 44.2k Views 27 Watching
    • E Offline
      Ecuadorian
      Thank you, Majid.
      I'm preparing a video tut for Youtube on the same subject (KT for architects), and I'll post a link to your pdf as an incredibly good reference.
      -Miguel Lescano
      • daleD Offline
        dale
        Although I haven't had a chance to sit down with it I can tell by first glance that it answers some of the questions I have.
        Thanks for all the effort on this.
        • soloS Offline
          Thanks majid.
          You make it difficult for me to find reasons not to give KT a try with such valuable tutorials like this.
          • david_hD Offline
            david_h
            I had played with KT a while back and I didn't really get it. (big surprise there) I ve got KT07 on my machine now but I haven't had the chance (or the courage I guess) to take it on again. I guess I need to give it a second look.
            D
              stanmarsh
              Thank you majid
                cadward
                Thanks Majid....this answers a lot of questions not explained by KT documentation. Your effort is greatly appreciated.
                  linea
                  Thanks ever so much Majid. There is hope for me yet!
                  • majidM Online
                    majid
                    D
                    dear david I myself started whit KT07 , but strongely encourage you to use KT echo 2008, most easiest and faster/simplest version.
                    @solo said:
                    Thanks majid.
                    thanx dear solo , I haven't covered anythins and even all the mateials I've read are not so tight ( but simplified for beginners ). BTW I think whit an artist eye you have , soon we will see some great renders 😄.
                    I strongly need your feedbacks for next editions. 🎉
                    • majidM Online
                      majid
                      now i uploaded the material test scene whit some preset light and cameras . so you can easily test your materials over it .
                      • N Offline
                        notareal
                        @solo said:
                        Thanks majid.
                        😮 Welcome, there is always room for one.
                        • IdahoJI Offline
                          IdahoJ
                          Thank you for the wonderful resource majid. I'm moving from POVray to Kerkythea and your guide is helping "smooth out the learning curve".
                          Cheers.
                          "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
                          • EdsonE Offline
                            Edson
                            hey majid,
                            great initiative. although i do not use KT most of my students do and it will help them a lot. thanks!
                            http://www.mahfuz.arq.br
                            • majidM Online
                              majid
                              I prepared a simple interior scene.
                              pls see scenes in sketchup , there r some tips there , then export your model to kt.
                              adjust steel materials and dielectric and also thinGlass materials,
                              then go to setting-->sun and sky-->next-->choose sky color as white and set intensity to 2.
                              use render preset 6 and render.
                              you also may open my kzx file that i've attached and is ready to render and render it.
                              cheers majid
                              flat interior.zip
                              1st render
                              • majidM Online
                                majid
                                dear Edson.which render engine do u use? as i am a freeware user, i've used KT for a long while. ( i tried pov-ray but confused by errors, also it was the same whit indigo). and i think it is fast and easy enough to try it. so pls give it a try .and maybe my tutorial can help you!!!
                                • EdsonE Offline
                                  Edson
                                  i have been using podium for about a year (run a search under my name in the gallery and you will see a couple of renders i produced with it). it is the one that suits my needs best at the moment. but i have not written KT off. i may give it another try when i have the time.
                                  • E Offline
                                    Ecuadorian
                                    Master Edson, then you are actually a Kerkythea user. You're just using it with a simplified interface.
                                    -Miguel Lescano
                                    • soloS Offline
                                      Majid
                                      I was wondering if we can use your interior model for our 'Render this challenge'?
                                      • majidM Online
                                        majid
                                        @solo said:
                                        Majid
                                        yes for sure dear solo . i think it's composion needs some work . maybe a ceiling light or something vertical at the left part of the view can help the composition to be more balanced. it would be very nice to see what results would be achieved
                                          rcossoli
                                          i can?
                                          this is my version, I made some changes in the textures and lighting, but it is practically the same scene,i can or may be better off?
                                          THREEDIMENSIONSWEB dot COM
                                          • majidM Online
                                            majid
                                            rcossoli, you encoraged me to do some more renders whit different light settings , your light setting is really good. congrats!
                                            • 1 / 4
