    KT fast start 4Architects (Kerkythea render engine)
    extensions
    64 Posts 27 Posters 48.3k Views 27 Watching
    • P
      PRSS
      Hi Majid!
      I really appreciate and thankful for the efforts and time spent by people like you in helping others.
      Great!
      Thanks once again
      With best regards
      PRSS
        rcossoli
        thank you very much, great contribution, the truth that you agradesco lot because I use kerkythea and it is always good to have tutorials to improve work
        THREEDIMENSIONSWEB dot COM
        • E
          Ecuadorian
          Thank you, Majid.
          I'm preparing a video tut for Youtube on the same subject (KT for architects), and I'll post a link to your pdf as an incredibly good reference.
          -Miguel Lescano
          • daleD
            dale
            Although I haven't had a chance to sit down with it I can tell by first glance that it answers some of the questions I have.
            Thanks for all the effort on this.
            • soloS
              Thanks majid.
              You make it difficult for me to find reasons not to give KT a try with such valuable tutorials like this.
              • david_hD
                david_h
                I had played with KT a while back and I didn't really get it. (big surprise there) I ve got KT07 on my machine now but I haven't had the chance (or the courage I guess) to take it on again. I guess I need to give it a second look.
                D
                  stanmarsh
                  Thank you majid
                  • C
                    cadward
                    Thanks Majid....this answers a lot of questions not explained by KT documentation. Your effort is greatly appreciated.
                    • L
                      linea
                      Thanks ever so much Majid. There is hope for me yet!
                      • majidM
                        majid
                        D
                        dear david I myself started whit KT07 , but strongely encourage you to use KT echo 2008, most easiest and faster/simplest version.
                        @solo said:
                        Thanks majid.
                        thanx dear solo , I haven't covered anythins and even all the mateials I've read are not so tight ( but simplified for beginners ). BTW I think whit an artist eye you have , soon we will see some great renders 😄.
                        I strongly need your feedbacks for next editions. 🎉
                        • majidM
                          majid
                          now i uploaded the material test scene whit some preset light and cameras . so you can easily test your materials over it .
                          • N
                            notareal
                            @solo said:
                            Thanks majid.
                            😮 Welcome, there is always room for one.
                            • IdahoJI
                              IdahoJ
                              Thank you for the wonderful resource majid. I'm moving from POVray to Kerkythea and your guide is helping "smooth out the learning curve".
                              Cheers.
                              "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
                              • EdsonE
                                Edson
                                hey majid,
                                great initiative. although i do not use KT most of my students do and it will help them a lot. thanks!
                                http://www.mahfuz.arq.br
                                • majidM
                                  majid
                                  I prepared a simple interior scene.
                                  pls see scenes in sketchup , there r some tips there , then export your model to kt.
                                  adjust steel materials and dielectric and also thinGlass materials,
                                  then go to setting-->sun and sky-->next-->choose sky color as white and set intensity to 2.
                                  use render preset 6 and render.
                                  you also may open my kzx file that i've attached and is ready to render and render it.
                                  cheers majid
                                  flat interior.zip
                                  1st render
                                  • majidM
                                    majid
                                    dear Edson.which render engine do u use? as i am a freeware user, i've used KT for a long while. ( i tried pov-ray but confused by errors, also it was the same whit indigo). and i think it is fast and easy enough to try it. so pls give it a try .and maybe my tutorial can help you!!!
                                    • EdsonE
                                      Edson
                                      i have been using podium for about a year (run a search under my name in the gallery and you will see a couple of renders i produced with it). it is the one that suits my needs best at the moment. but i have not written KT off. i may give it another try when i have the time.
                                      • E
                                        Ecuadorian
                                        Master Edson, then you are actually a Kerkythea user. You're just using it with a simplified interface.
                                        -Miguel Lescano
                                        • soloS
                                          Majid
                                          I was wondering if we can use your interior model for our 'Render this challenge'?
                                          • majidM
                                            majid
                                            @solo said:
                                            Majid
                                            yes for sure dear solo . i think it's composion needs some work . maybe a ceiling light or something vertical at the left part of the view can help the composition to be more balanced. it would be very nice to see what results would be achieved
                                            • 1 / 4
