    Printing to scale
    40 Posts 15 Posters 25.2k Views 15 Watching
      RomanJB
      This is a bad design. There is no way to directly set the extent of the model (size and extent of the canvas).
      Changing the drawing area window size causes panning of the drawing. As a result it is impossible to align precisely the edges of the printed page to the edges of the model. One cannot use 100% of the printed page.
      It would require infinite patience to achieve it by using window resize and pan, which are interdependent.
      • X
        xrok1
        can you not save as pdf, then print tiled if necessary.
          redinhawaii
          Okay, could someone please tell me the "infinite wisdom" of the sketchup crew to create a "print to scale" monster as this?
          Was anyone awake at there developers meetings?
          This non ability to print to scale is not only frustrating, it clearly limits the potential of this program, in MHO.
          Aloha
          red
          p.s. tried the PDF thing too, it also was "not to scale"
          does anyone have any suggestions besides this trial and error method?
          Is layout any better?
          Or do I have to export to a real CAD program?
          • X
            xrok1
            you need to go to camera and select parallel projection then select one of the preset views front, back, top .... not IsoCapture.JPG
            then go to print preview; check use model extents and make sure scale is 1 & 1
            if that dosn't work for you ????????????????
            • C
              Charlie__V
              @zootsuit said:
              When I try to print to scale, i.e 1mm in sketchup = 1m on page, Sketchup positions the image in the corner of the page so it's spread accross 4 or more pages . My model is a simple 2d plan and the entire dimensions are 210 x297 i.e. A4.
              Does anyone know how to centre the image on 1 page without losing the correct scale? If i try to type in the page dimensions (120,297) the print dialog box changes the scale as I type! Why is this happening?
              Many Thanks
              Zoot,
              Is this a typo......or is the model actually larger than the sheet you are trying to print to.
              If so........
              Best,
              C
                redinhawaii
                Thanks for the feedback,
                the model is an architectural model,
                if my print scale was 1 to 1 I would need 5402 pages!!!
                I want to "print to scale".
                I have tried 1"in drawing" to 8' in the "in model"
                it does not translate to printable scale.
                this seems not only odd but impractical.
                any other insights?
                thanks again for your time and experience
                aloha
                red
                p.s. I did try to "send to Layout"..followed the "new tips" info but my "sketchup Model"
                info menu does not highlight the supposed choices as mentioned in the tip?
                this is so nonintuitive...
                • X
                  xrok1
                  any other insights?
                  aloha
                  red
                  try 1" to 96" instead, who knows, might help. 😲
                  i made an 8" by 8" face in SU then printed it 1"print = 8"model and it printed exactly 1" sq. so its a mystery.
                  PS i just tried it with an 8' sq. face as well and it worked, both with 96" and 8' typed in the model scale box?
                  how far of is your result?
                    redinhawaii
                    Okay, I did finally figure out the Model scale issue in Layout, I had to click on the import within the template.
                    now how do I get the background grey color out of the Sketchup Import?
                    When I print straight from sketchup it does not print, when I import to LayOut,
                    I get this background color.
                    any insights?
                    thanks
                    aloha
                    red
                    • X
                      xrok1
                      go to styles and turn off the ground and sky, and make the background color white 😄 before you send to layout.
                      • GaieusG
                        Also, in LO > Tray > SU Model > Styles, uncheck Background colour an have only your model displayed. (Note that I have the grid on to show that there isn't any background colour and you can see what's "underneath".)
                          redinhawaii
                          Thanks,
                          you guys are the best.
                          much appreciated.
                          aloha
                          red
                          • K
                            kaos
                            Gidday
                            Have been searching for the holy grail on printing to scale , read lots of posts and on this matter it seems sketch up really falls short.
                            At times i have a need, particularly with simple 2d drawings with School students, to print their drawing to scale. Sometimes 1:1 for a template or say 1:5 for an orthographic view ( its required documentation).
                            The 3d modeling is fine and can deal with the model being sized by the zoom extents tool and fitting to a page.
                            Has there been any progress? , are using free version on Mac
                            thanks
                            • Chris FullmerC
                              It does print to scale just fine - under one major limitation 😄
                              It only will print to scale when you are one of the default SketchUp views. Including Iso, Top, Bottom, Left, Right, Front , and Back.
                              Set the view mode to parallel projection, flip to a standard view and thn go print. You have to turn off "Fit To Page" then it will allow you to print to scale.
                              Another option that works very well (once you get used to it) is to do your printing from LayOut. It also lets you print to scale, and might even be more well adapted to it.
                              Hope that helps,
                              • Chris FullmerC
                                ok, so letse work through this step by step.
                                First, you are able to actually enter a desired scale in the print options box?
                                That is a big hurdle.
                                What scale do you want to print at? You enter 1" in the printout equals 8' in sketchup and that will make it print at 1" = 8' architectural scale.
                                So if you had a box that was 8' x 8', it would print out at 1" x 1" in paper.
                                Try that and see how it works out,
                                • K
                                  kaos
                                  Thanks for the response
                                  I have sent an image of my Mac document setting box (no particular settings entered)
                                  Have tried many many options as suggested by lots of posts and sketch up help
                                  I can't believe this problem exists given how prolific Sketch up is
                                  I am using a Mac,sketch up 7 free version.FIT TO PAGE IS OFF ,PARALLEL VIEW IS SELECTED,USUALLY FRONT VIEW,TRY TO ENTER A SCALE LIKE 1:5, 1:10 but wont let me enter this. Page size changes when scales are entered. I am used to setting say A4 page ,a particular scale ,page orientation and then print in Vector Works which i use normally for 2D drawings
                                  • GaieusG
                                    What I know of the Mac is that setting printing up is totally different from PC. There is not only a print setup but also a document setup dialog and this is all I can help since I should be able to see to proceed from here. Here is what the Guide says about printing on Mac:
                                    http://download.sketchup.com/sketchuphelp/gsu6_mac/Content/K-Input_and_Output/Printing/IO-Print.htm
                                    • Chris FullmerC
                                      Wow! that is different than the PC print setup. That explains a few things.
                                      So if you try to set in drawing to 10mm and in model to 1000mm, that doesn't work? Does it not allow you to change those settings?
                                      • P
                                        pmiller
                                        Print quality setup and document setup dialogue are only available on the pro version according to this guide.
                                        • GaieusG
                                          That's obsolete (sorry, I should've mentioned). They forgot to change it when SU 6 ❗ came out. It's been available in the free version, too, for more than 2 years now. If you have a look at the currnet ❗ guide for animation export, it also says that it's a
                                          http://sketchup.google.com/crimages/welcome-Plus.jpg
                                          Pro only feature. But it's not.
                                          (Hopefully it will be changed soon).
                                          • Chris FullmerC
                                            Sorry, any chance you could use a format like .jpg or .png? .tiff is not a supported format on PC web browsers (at least not IE or firefox) so I can't see the image. Thanks!
                                            Sorry this is being such a pain,
