    Printing to scale
    40 Posts 15 Posters 25.9k Views 15 Watching
    • ChiefwoodworkerC
      Chiefwoodworker
      Zootsuit,
      I agree with you completely about this being a bug and one that Google needs to fix. Printing is basic and should not be this difficult whether a simple 3D drawing package or a word editor.
      However, you can make it work. I may not have been clear about fitting the model into the window. First zoom to extents as you did. Now if there is too much unused drawing space on the top/bottom or sides, resize the window from either horizontal or vertical direction until there is no wasted drawing space. Sometimes the tool icons make this difficult and you have to rearrange them to allow you to get rid of the wasted space. But stick with it and you will succeed.
      I am defending Google. This printing thing is a mess and stumps almost everyone. But you can make it work with patience.
      If you want to share the .skp file I will take a look and see what I can do.
      Joe....
      http://www.srww.com
      • Z
        Zootsuit
        Joe
        The main issue I had was that I had to print out at scale 1:1 as I was using the print out to make card models of an architectural site. Using any different scale just so it would fit on the page would not have helped me in this case. As my entire model plan was exactly the same size as an A3 piece of paper, and my printer was set up to A3 I could not understand why I could not enter the print dimensions as A3 (420,297) and also keep the scale at 1:1 in the Print Preview dialogue box. To keep to 1:1 scale meant the paper size dimension changed in the dialogue box and I had to print on oversized paper - A2- which was a bit of a waste.
        Following your advice I checked, then unchecked the 'use model extents box', which did help to an extent, but the page dimensions remained slightly too large. It seems to be more a matter of adjusting and trial and error, which can be frustrating when working to a deadline!
        Anyway thanks for your advice, once Ive got the model finished I'll try to post an image! Ive been using the unfold plugin to convert my Sketchup model into a 3D card model . Aside from the printing issues, it has proved much quicker than working by hand and produced some excellent results!
          RomanJB
          This is a bad design. There is no way to directly set the extent of the model (size and extent of the canvas).
          Changing the drawing area window size causes panning of the drawing. As a result it is impossible to align precisely the edges of the printed page to the edges of the model. One cannot use 100% of the printed page.
          It would require infinite patience to achieve it by using window resize and pan, which are interdependent.
          • X
            xrok1
            can you not save as pdf, then print tiled if necessary.
              redinhawaii
              Okay, could someone please tell me the "infinite wisdom" of the sketchup crew to create a "print to scale" monster as this?
              Was anyone awake at there developers meetings?
              This non ability to print to scale is not only frustrating, it clearly limits the potential of this program, in MHO.
              Aloha
              red
              p.s. tried the PDF thing too, it also was "not to scale"
              does anyone have any suggestions besides this trial and error method?
              Is layout any better?
              Or do I have to export to a real CAD program?
              • X
                xrok1
                you need to go to camera and select parallel projection then select one of the preset views front, back, top .... not IsoCapture.JPG
                then go to print preview; check use model extents and make sure scale is 1 & 1
                if that dosn't work for you ????????????????
                • C
                  Charlie__V
                  @zootsuit said:
                  When I try to print to scale, i.e 1mm in sketchup = 1m on page, Sketchup positions the image in the corner of the page so it's spread accross 4 or more pages . My model is a simple 2d plan and the entire dimensions are 210 x297 i.e. A4.
                  Does anyone know how to centre the image on 1 page without losing the correct scale? If i try to type in the page dimensions (120,297) the print dialog box changes the scale as I type! Why is this happening?
                  Many Thanks
                  Zoot,
                  Is this a typo......or is the model actually larger than the sheet you are trying to print to.
                  If so........
                  Best,
                  C
                    redinhawaii
                    Thanks for the feedback,
                    the model is an architectural model,
                    if my print scale was 1 to 1 I would need 5402 pages!!!
                    I want to "print to scale".
                    I have tried 1"in drawing" to 8' in the "in model"
                    it does not translate to printable scale.
                    this seems not only odd but impractical.
                    any other insights?
                    thanks again for your time and experience
                    aloha
                    red
                    p.s. I did try to "send to Layout"..followed the "new tips" info but my "sketchup Model"
                    info menu does not highlight the supposed choices as mentioned in the tip?
                    this is so nonintuitive...
                    • X
                      xrok1
                      any other insights?
                      aloha
                      red
                      try 1" to 96" instead, who knows, might help. 😲
                      i made an 8" by 8" face in SU then printed it 1"print = 8"model and it printed exactly 1" sq. so its a mystery.
                      PS i just tried it with an 8' sq. face as well and it worked, both with 96" and 8' typed in the model scale box?
                      how far of is your result?
                        redinhawaii
                        Okay, I did finally figure out the Model scale issue in Layout, I had to click on the import within the template.
                        now how do I get the background grey color out of the Sketchup Import?
                        When I print straight from sketchup it does not print, when I import to LayOut,
                        I get this background color.
                        any insights?
                        thanks
                        aloha
                        red
                        • X
                          xrok1
                          go to styles and turn off the ground and sky, and make the background color white 😄 before you send to layout.
                          • GaieusG
                            Also, in LO > Tray > SU Model > Styles, uncheck Background colour an have only your model displayed. (Note that I have the grid on to show that there isn't any background colour and you can see what's "underneath".)
                              redinhawaii
                              Thanks,
                              you guys are the best.
                              much appreciated.
                              aloha
                              red
                              • K
                                kaos
                                Gidday
                                Have been searching for the holy grail on printing to scale , read lots of posts and on this matter it seems sketch up really falls short.
                                At times i have a need, particularly with simple 2d drawings with School students, to print their drawing to scale. Sometimes 1:1 for a template or say 1:5 for an orthographic view ( its required documentation).
                                The 3d modeling is fine and can deal with the model being sized by the zoom extents tool and fitting to a page.
                                Has there been any progress? , are using free version on Mac
                                thanks
                                • Chris FullmerC
                                  It does print to scale just fine - under one major limitation 😄
                                  It only will print to scale when you are one of the default SketchUp views. Including Iso, Top, Bottom, Left, Right, Front , and Back.
                                  Set the view mode to parallel projection, flip to a standard view and thn go print. You have to turn off "Fit To Page" then it will allow you to print to scale.
                                  Another option that works very well (once you get used to it) is to do your printing from LayOut. It also lets you print to scale, and might even be more well adapted to it.
                                  Hope that helps,
                                  • Chris FullmerC
                                    ok, so letse work through this step by step.
                                    First, you are able to actually enter a desired scale in the print options box?
                                    That is a big hurdle.
                                    What scale do you want to print at? You enter 1" in the printout equals 8' in sketchup and that will make it print at 1" = 8' architectural scale.
                                    So if you had a box that was 8' x 8', it would print out at 1" x 1" in paper.
                                    Try that and see how it works out,
                                    • K
                                      kaos
                                      Thanks for the response
                                      I have sent an image of my Mac document setting box (no particular settings entered)
                                      Have tried many many options as suggested by lots of posts and sketch up help
                                      I can't believe this problem exists given how prolific Sketch up is
                                      I am using a Mac,sketch up 7 free version.FIT TO PAGE IS OFF ,PARALLEL VIEW IS SELECTED,USUALLY FRONT VIEW,TRY TO ENTER A SCALE LIKE 1:5, 1:10 but wont let me enter this. Page size changes when scales are entered. I am used to setting say A4 page ,a particular scale ,page orientation and then print in Vector Works which i use normally for 2D drawings
                                      • GaieusG
                                        What I know of the Mac is that setting printing up is totally different from PC. There is not only a print setup but also a document setup dialog and this is all I can help since I should be able to see to proceed from here. Here is what the Guide says about printing on Mac:
                                        http://download.sketchup.com/sketchuphelp/gsu6_mac/Content/K-Input_and_Output/Printing/IO-Print.htm
                                        • Chris FullmerC
                                          Wow! that is different than the PC print setup. That explains a few things.
                                          So if you try to set in drawing to 10mm and in model to 1000mm, that doesn't work? Does it not allow you to change those settings?
                                          • P
                                            pmiller
                                            Print quality setup and document setup dialogue are only available on the pro version according to this guide.
