    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 86.8k Views 43 Watching
    • JClementsJ Offline
      JClements
      Chris, I got this unexpected "cool" result.
      I drew a cone-shape and turned on hidden edges.
      Used the draw vertical line to Normal.
      After doing a few lines I started clicking on white space and and hitting the Return Key.
      Since the cursor is clicking on white space its registering to elevation zero on the X-Y plane and drawing a line back to a common vertex [Edit(the end-point of the last line drawn as a "normal")[/Edit]]. See red lines.
      Try it and see what happens.
      Normal drawing.skp
        Nope. No way to create new top level menus in SU.
        • Chris FullmerC Offline
          SCRIPT UPDATED
          All right, I got the VCB integrated now, and it is soo much better! No more prompts, just click click click. When you enter a new value into the VCB and hit enter it will change the length of the previously drawn line.
          I also updated the video to reflect these changes (but if you're already familiar with the tool, it shouldn't be that hard to get working).
          Thanks for the suggestions.
          Oh yeah, there is a known bug where the undo counts every line change as a separate undo command. So if you use the vcb to change the length of a line multiple times, each change will get its own undo. Sorry, its turned out to be trickier than I thought to fix this in this script but I have some ideas to fix it if its a big problem.
            Seems quasi perfect πŸ˜„
              jmmad
              Thxs a lot Chris for this plugin
              Really usefull
              Get Upa !
                UPDATED (again)
                Just in case you were'nt sick of updating this script, I thought I'd make yet another update to it today!
                This is the new Visual Graphic User Interface Edition. Or in other words, I added a toolbar.
                These are (1)Vertical lines of the same length. (2)Vertical lines with the same elevation. (3)An N (for Normal) and 3 lines coming off of its normals.
                Also, I made it so it registers with the extension manager. (Go to Preferences>Extensions and you'll see "3 Line Tools" listed. You can uncheck it and it won't be in your Plugins menu the next time you run SketchUp.) Hope these frequent updates aren't obnoxious.
                  linea
                  Superb.Thanks
                  • Jean-FrancoJ Offline
                    Jean-Franco
                    Thanks so much Chris.
                    What a plugin !
                    And how fast you are in updating it in order to follow our needs and demands !
                    Seen this way Ruby scripting seems so easy ...
                    Unfortunately it's not. Or at least for me. πŸ‘
                    Jean-Franco
                      Jean-Franco
                      Just a remark concerning the 3rd script "normal lines".
                      After the normal line to a surface is drawn, if you change the spacial orientation of this surface, the line don't follow this change. Seems your line don't stick to the surface, right ?
                      Another one. I'm using Sketchup 6.0 free. I've decimal and mm selected as units.
                      When I start your script, the first lenght equals 2540 mm. Of course I can change it in the VCB. But is it possible and where to change it? Lets say to 100 or 1000 ?
                      Jean-Franco
                        Panga
                        Really nice improvements Chris. Thanks πŸ˜‰
                          Suggestion πŸ˜„ Maybe for another script or another line inside
                          Does it possible to make the same but for an ordinary "curve"?
                          • EdsonE Offline
                            Edson
                            chris,
                            when i think this script has been perfected to a fault you come with an upgrade to make it even better. THANKS!
                            http://www.mahfuz.arq.br
                              Bones
                              Thanks! Nice plugin , it's very handy - nice one! 😎
                                That is exactly how I feel about this script - all it does is draw a vertical line! A script that draws a vertical line should not be upgraded a dozen times and should certainly never need to make it up to a version 2.0! They're just sinple lines.
                                But then again, I also agree that each upgrade has somehow made it even better. So thanks for being patient with the upgrades. And thanks for all the compliments. I wouldn't hasve thought so many people would find this thing so useful (though the normal line mode is pretty cool I think). THanks!
                                • Paul RussamP Offline
                                  Paul Russam
                                  Evey time I think to myself "The best think about Sketchup is how beautifully simple it is" somebody comes along and makes it more beautiful and simpler.
                                  Thanks for this its one of those things you didn't know you wanted until it appeared.
                                  Paul Russam
                                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                                  • EdsonE Offline
                                    Edson
                                    perfect!
                                      Hey! When did this hit version 2? With a toolbar?
                                      Nice one.
                                      I just realised I was doing some really weird stuff to draw lines normal to angled edges. Then some of my old grey slapped me around with a trout reminding me about this plugin.
                                        Heehhe, glad you remembered. And I think over last weekend it made the jump to 2.0 when I made the toolbar. That was new. I didn't know that toolbars require some diffferent menu coding than just regular menus. So that was good to learn. I also made it register itself with the plugins extension manager. So I felt like those 2 things really made it a real script that should be a full 2.0. Silly little script,
                                          JClements
                                          Hi Chris:
                                          Just saw your update. Nice going.
                                          The Normals line tool might proof to be helpful in setting up the camera for particular scenes.
                                          1- Draw a "Normals" line
                                          2- Click drag the Position Camera Tool from one endpoint of the Normals line to the other endpoint.
                                          John
                                          • BurkhardB Offline
                                            Burkhard
                                            This script I can use also excellent for light fittings in Su Podium, thanks.
                                            Remember a request I do before. Can a normal set vertical to a line? Just the opposite of this fantastic script ( for ie balustrades or other stuff doing by follow me tool )
                                            ....and I know your workaround Ecuadorian πŸ˜‰ but looking for a better solution.
                                            http://www.ia-plus.de
                                            • 3 / 6
