    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 88.5k Views 43 Watching
    • Chris FullmerC
      I thought about that option, but I couldn't decide on a starting value. I'm having some VCB display issues which are making my VCB experience rather trying. Hopefully I'll get it worked out (I feel a new newbie ruby question thread coming on shortly).
      • Chris FullmerC
        Oops, I think that I don't have it set up to accept clicking on nothing. I think it gets confused and does whatever it feels like doing. Thanks for finding that John, look good πŸ˜„
        • JClementsJ
          JClements
          Chris, keep it as a "Feature".
          • JClementsJ
            JClements
            Chris, I got this unexpected "cool" result.
            I drew a cone-shape and turned on hidden edges.
            Used the draw vertical line to Normal.
            After doing a few lines I started clicking on white space and and hitting the Return Key.
            Since the cursor is clicking on white space its registering to elevation zero on the X-Y plane and drawing a line back to a common vertex [Edit(the end-point of the last line drawn as a "normal")[/Edit]]. See red lines.
            Try it and see what happens.
            Normal drawing.skp
              Nope. No way to create new top level menus in SU.
              • Chris FullmerC
                SCRIPT UPDATED
                All right, I got the VCB integrated now, and it is soo much better! No more prompts, just click click click. When you enter a new value into the VCB and hit enter it will change the length of the previously drawn line.
                I also updated the video to reflect these changes (but if you're already familiar with the tool, it shouldn't be that hard to get working).
                Thanks for the suggestions.
                Oh yeah, there is a known bug where the undo counts every line change as a separate undo command. So if you use the vcb to change the length of a line multiple times, each change will get its own undo. Sorry, its turned out to be trickier than I thought to fix this in this script but I have some ideas to fix it if its a big problem.
                  Seems quasi perfect πŸ˜„
                    jmmad
                    Thxs a lot Chris for this plugin
                    Really usefull
                    Get Upa !
                    • Chris FullmerC
                      UPDATED (again)
                      Just in case you were'nt sick of updating this script, I thought I'd make yet another update to it today!
                      This is the new Visual Graphic User Interface Edition. Or in other words, I added a toolbar.
                      These are (1)Vertical lines of the same length. (2)Vertical lines with the same elevation. (3)An N (for Normal) and 3 lines coming off of its normals.
                      Also, I made it so it registers with the extension manager. (Go to Preferences>Extensions and you'll see "3 Line Tools" listed. You can uncheck it and it won't be in your Plugins menu the next time you run SketchUp.) Hope these frequent updates aren't obnoxious.
                      • L
                        linea
                        Superb.Thanks
                        • Jean-FrancoJ
                          Jean-Franco
                          Thanks so much Chris.
                          What a plugin !
                          And how fast you are in updating it in order to follow our needs and demands !
                          Seen this way Ruby scripting seems so easy ...
                          Unfortunately it's not. Or at least for me. πŸ‘
                          Jean-Franco
                          • Jean-FrancoJ
                            Jean-Franco
                            Just a remark concerning the 3rd script "normal lines".
                            After the normal line to a surface is drawn, if you change the spacial orientation of this surface, the line don't follow this change. Seems your line don't stick to the surface, right ?
                            Another one. I'm using Sketchup 6.0 free. I've decimal and mm selected as units.
                            When I start your script, the first lenght equals 2540 mm. Of course I can change it in the VCB. But is it possible and where to change it? Lets say to 100 or 1000 ?
                            Jean-Franco
                            • P
                              Panga
                              Really nice improvements Chris. Thanks πŸ˜‰
                                Suggestion πŸ˜„ Maybe for another script or another line inside
                                Does it possible to make the same but for an ordinary "curve"?
                                • EdsonE
                                  Edson
                                  chris,
                                  when i think this script has been perfected to a fault you come with an upgrade to make it even better. THANKS!
                                  http://www.mahfuz.arq.br
                                  • B
                                    Bones
                                    Thanks! Nice plugin , it's very handy - nice one! 😎
                                    • Chris FullmerC
                                      That is exactly how I feel about this script - all it does is draw a vertical line! A script that draws a vertical line should not be upgraded a dozen times and should certainly never need to make it up to a version 2.0! They're just sinple lines.
                                      But then again, I also agree that each upgrade has somehow made it even better. So thanks for being patient with the upgrades. And thanks for all the compliments. I wouldn't hasve thought so many people would find this thing so useful (though the normal line mode is pretty cool I think). THanks!
                                      • Paul RussamP
                                        Paul Russam
                                        Evey time I think to myself "The best think about Sketchup is how beautifully simple it is" somebody comes along and makes it more beautiful and simpler.
                                        Thanks for this its one of those things you didn't know you wanted until it appeared.
                                        Paul Russam
                                        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                                        • EdsonE
                                          Edson
                                          perfect!
                                            Hey! When did this hit version 2? With a toolbar?
                                            Nice one.
                                            I just realised I was doing some really weird stuff to draw lines normal to angled edges. Then some of my old grey slapped me around with a trout reminding me about this plugin.
                                            • 3 / 6
