    [Plugin] Skin.rb
    237 Posts 66 Posters 205.7k Views 66 Watching
      maxosmedia
      Error Loading File skin.rb
      undefined method `[]' for nil:NilClass
      MacOSX 10.4 SU6.4.245
      • kmeadK
        kmead
        I am seeing the same error with the 2.4 version of the plugin under MacOSX 10.5.5
        I created Dilbertville, sorry about that...
          architectboy
          Hmmm, it doesn't do that on my computer. Let's see if this fixes it.
          Version 2.5
          • plot-parisP
            plot-paris
            weird. the plugin works for me, when I use the toolbar (buttons). but it doesn't react at all, if I try to launch the skin command from the tools-menu... its a pity, because I just assigned a shortcut for the old version. and now I can't use a keyboard shortcut anymore 😞
            • F
              fakircho
              Hi it is working for me fine. I am finding it a bit inconsistent when i give more than two
              profiles to "Skin". It usually gets it right at the end after asking "is the connection done right"? 😄
              but if i undo i notice that it does it in stages, two profiles at a time.
              That is ok but is it possible to have it do the whole "skin" as one operation if you have selected more than two profiles, instead of being asked to confirm each step? Please see attached. That would be great
              • O
                otb designworks
                I, too, am getting this error on start up. Mac 10.5.5, also.
                Cheers, Chuck
                OTB Designworks is on Youtube
                • B
                  BTM
                  Using the Skin rb., running SU7 on Mac OSX 10.5.5, The plugin works almost not at all. The only action working is the one that cleans up the unnecessary edges. It will only work from the toolbar too. Also, I don't know if it's supposed to be like this, but there are no icons in the skin toolbar.
                  • olisheaO
                    olishea
                    this is exactly the ruby ive been looking for. thank you so much. I've been wanting to 'skin' between faces for a long time.
                    oli
                      AcesHigh
                      I think the problem with this plugin, in the way that it DOES NOT achieves the same result as true loft commands in other software, is that the Skin plugin SEEMS to try to achieve the transformation directly... from one shape to the other... maybe there is ONE partial step in the middle.
                      Analize visually the image below... watch as it seems there is a VERY GRADUAL MORPHING between one shape and the other. Its like if the LOFT command created some 10 intermediate profiles between each ORIGINAL profile. Then, after creating lots of intermediate profiles, it does "sking" the model.
                      When seeing the pictures of the SKIN plugin in this thread, I guess (but I cant be sure) that one ONE intermediate is create, half the way between the two original profiles.
                      I wonder if the author agrees with me, and if he thinks its POSSIBLE to better simulate a LOFT command, by making Sketchup draw a number of intermediate profiles, who morph in shape between the two original profiles (the number of intermediate profiles maybe could be selected in a dialog box?)
                      Easier said than done 😄
                        AcesHigh
                        hmmm... btw, the plugin is not working at all here at my PC... ive just downloaded 2.5... last time I used the plugin was a long time ago (many versions ago)...
                        • F
                          fakircho
                          Thank you AcesHigh, i have been moaning about this for years 😉
                          We need a proper Loft tool full stop. I did start a thread a while ago but nothing so far.
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13272&p=98352&hilit=loft&sid=bcc844a9806886b037dad1618e96f9ad#p98352
                          I see you use C4D 😄
                            AcesHigh
                            actually, I dont. I found that image on google 😄
                            • F
                              fakircho
                              Now that i look at it again i think i did that image in c4d ages ago to show what i want in Sketchup 😉
                              If i am not mistaken i posted it on the old forum ❓
                                AcesHigh
                                lol... yes, I found it on a Sketchup forum where a guy was asking for a LOFT plugin... 😆 😆 😆
                                how funny that it was YOU, and then years later, you are still asking for the loft plugin, and I post YOUR image and you thought it was mine 😆 😆 😆 😆
                                • F
                                  fakircho
                                  Nice one man 😄 that is funny 😆 😆 😆
                                  • L
                                    lightburn
                                    umm, Where do I sign to join in your "petition" for a loft tool? 🎉 That would be a great addition to all the fine tools we have now. 😄
                                      AcesHigh
                                      problem is that the Skin tool is not working in my Sketchup. I opened the Ruby console and NOTHING appears when I try to use the Skin command!
                                      • MarianM
                                        Marian
                                        Try an older version of it, many of the newer ones don'y work for me either.
                                          sojourner
                                          I have tried several versions of this and get no results. 23, 24, and 25 seem to do nothing, ruby console is blank. versions earlier give:
                                          Error: #<NoMethodError: undefined method collect' for nil:NilClass> C:/Program Files/Google/Google SketchUp 7/Plugins/skin22.rb:166:in skin'
                                          I take it this is a SU 7 problem?
                                          • MarianM
                                            Marian
                                            It works for me in su7 but dunno what version it is. if you used one of the earlier versions and didn't work probably some other plugin is interfer.
                                            • 11
                                            • 12
                                            • 7 / 12
