    [Plugin] Skin.rb
    237 Posts 66 Posters 182.2k Views 66 Watching
      architectboy
      Hello, friends, long time no see. Lament no longer over the fact that this script is not in development. I've recently gotten back to working on this script and have a new version for you all.
      The loooong awaited upgrade
      • V Offline
        Voder Vocoder
        Darrel,
        I'm delighted to see you back, and I'm excited that there's a new version. Would you mind explaining a bit about the new options?
        Thanks for this.
        ~Voder
          remus
          Oooh, what a nice surprise.
          • ToboboT Offline
            Tobobo
            Thanks Mate
            Toby
            Philippians 4:13
            • W Offline
              watkins
              Dear Darrel,
              I note that the new script adds something extra. Do you have a User Guide document to explain how best to use this script?
              Kind regards,
              Bob
                maxosmedia
                SU crash!!! ๐Ÿ˜ž Without tears and comments
                (SU 6.4.245, MacOS 10.4.11)
                Previous versions Skin.rb work perfect
                  architectboy
                  Skin.rb was originally designed to only "skin", or connect, the sides, but it became evident that it sometimes should "prep", or prepare the sides for skinning by splitting the edges. I came up with two methods for skinning the sides and two methods for preparing the sides. I used to have a button for each method, but now I have one skin button and the settings dialog sets what methods skin.rb uses. I hope that you can figure it out. If someone can explain it better than me, please do.
                  • V Offline
                    Voder Vocoder
                    ...it became evident that it sometimes should "prep", or prepare the sides for skinning by splitting the edges.
                    Darrel,
                    It's not obvious to me what the benefit of prepping is. The granularity of the resulting shape is still determined by the original edges, is it not?
                    Thanks,
                    ~Voder
                      architectboy
                      Voder, prepping the edges creates the effect that the edges are connected, not just the vertices.Example1.jpgExample2.jpg
                        these icons have disapeared?
                        • ToboboT Offline
                          Tobobo
                          Darrel,
                          Thanks for the script but it crashed sketch up and i'm not sure what all the settings mean?
                          Toby
                          Philippians 4:13
                            Cool Darrel, works just fine with my machine. Thanks for coming back. A lot of us were indeed quite curious where you could be. ๐Ÿ˜‰
                            Nice options, too! ๐Ÿ‘
                            • kmeadK Offline
                              kmead
                              Good day.
                              I am a MacOS user and unfortunately, version 23 does not appear to work any longer. V22 does, so I don't know what the issue is. It doesn't crash SU but doesn't do anything beyond have the buttons toggle and change color. Nothing untoward happens just no change in state of the model.
                              Mac OSX v10.5.5 MacBook Pro 2.33, 3gb Ram, 256 ATI X1600
                              The earlier versions have worked fine until this point.
                              Many thanks.
                              Karl
                              I created Dilbertville, sorry about that...
                                architectboy
                                Pilou, thank you for the test case. I used it in debugging this version. Hopefully this fixes the problems you guys have been having. The test case still takes my computer several minutes to sort through those 61000 entities and to delete 9000 edges, I don't get how your computer could do it in three seconds ๐Ÿ˜• .
                                Version 2.4
                                  3 seconds again for the function "Clean selection" with your new version 2.4 ๐Ÿ˜Ž
                                  My comput has 5 years old so with up to date machine that will be instantaneous!
                                  Of course I select all the model before launch the Clean Selection!
                                  Only edges on "flat" faces are erased!
                                  That is I suppose the normal use of the function "Clean Selection"?
                                  Maybe I have not calculate tools like your "sort" on my comput processor?
                                  That maybe explain the 3 seconds result?
                                  (for other manipulations like move copy etc...my comput with this model is go down on its knees! ๐Ÿ˜‰
                                  Model by Steph3D
                                  PS Existing before 2 icones (rectangle with little red points) for divide in same numbers edges of facets : are they disapeared?
                                    Seems your 23 works less than the 22! โ“
                                    With the 22 "Clean Selection" (on my very old computer) works fine in 3 seconds โ˜€
                                    With the 23 no result after one minute! ๐Ÿ˜ฎ
                                    (select the all with triple click !
                                    Model by Steph3D
                                    test.zip
                                      maxosmedia
                                      Error Loading File skin.rb
                                      undefined method `[]' for nil:NilClass
                                      MacOSX 10.4 SU6.4.245
                                      • kmeadK Offline
                                        kmead
                                        I am seeing the same error with the 2.4 version of the plugin under MacOSX 10.5.5
                                          architectboy
                                          Hmmm, it doesn't do that on my computer. Let's see if this fixes it.
                                          Version 2.5
                                          • plot-parisP Offline
                                            plot-paris
                                            weird. the plugin works for me, when I use the toolbar (buttons). but it doesn't react at all, if I try to launch the skin command from the tools-menu... its a pity, because I just assigned a shortcut for the old version. and now I can't use a keyboard shortcut anymore ๐Ÿ˜ž
                                            • 11
                                            • 12
                                            • 7 / 12
