    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
      BorgMan
      While I'm late, I still want to show my appreciation for the fact that you gave out this script for free, Fredo. It's really a nice piece of programming, and the way it's integrated within the SU toolribbon makes it feel very natural. If Google's watching this, they'd do good to just add the plugin to SU7; why waste time on something that's already there while you can make the next version even better?
      More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
      You've gotta love Slivers.
      • plot-parisP Offline
        plot-paris
        Coen, you are putting Fredo under pressure, aren't you? ๐Ÿ˜„
        • F Offline
          flyashy
          I'm sure you are tired of all the people thanking you, but I have to thank you for putting this script up.
          It's quite simply brilliant and now an essential part of sketchup for me.
          Thank you again.
          Ashy
            bellwells
            Fredo,
            Can you please include inference locking to the Vector Push/Pull mode? Holding Shift to lock inference doesn't seem to work for me.
            Also, why is the toolbar labeled NUL Transformation? Perhaps Joint Push Pull is better. After all, that is the name of the plug-in and its current name may be a bit confusing when new users look for it in their toolbars menu.
            As always thanks!
            This never occurred to me, Coen. Thanks, I've changed my toolbar label.
            Ron
              Jim57
              Joint Push Pull Question
              by Jim57 on Wed Nov 26, 2008 10:50 pm
              I'm offsetting a curved shape on the wall of a cylinder, then insetting the inner panel with Joint Push Pull. It spans 8 facets of the cylinder, and the outer curve has 20 line segments. I made sure all the vertexes of the curve lined up with the edges of the facets, to simplify the work.
              When I type in an amount for JPP (.125") the VBS shifts to: "Elts **** / **% **.**sec" (where the asterisks are numbers rapidly ascending until they hit somewhere around Elts 1200 / 100% 55 sec, when the processing is over. If I can manage to offset the surface accurately to 1/8" on my trackpad, it hardly takes any time.
              My question is, why the difference? What does "Elts" mean?
              Thanks,
              Jim
              • fredo6F Offline
                "Elts" means essentially faces to be processed.
                I am not clear about what is exactly the problem you highlight.
                  Jim57
                  The tool does the job, it's not a problem like that.
                  If I type in a number the processing takes about a minute, but if I can move the cursor the exact amount it's almost instantaneous. I'm curious about why the difference.
                  Thanks,
                  Jim
                    In regards to the context menu; it'd be nice if it only displayed the menu entries when you have face entities selected. No need for it to appear when you've only got lines, groups and/or components etc selected. When a user, like me, have a few plugins installed the context menu quickly fill up.
                      skiprender
                      I downloaded the plugin and used it to extrude a concrete base and 2 walkways, but when I used the joint push pull and then tried to stamp a small box on it, it crashed. Every time. Is there a fix for this? I enclosed the file
                      walks on topo.skp
                      • fredo6F Offline
                        Skiprender
                        Yes it bugsplats, even when you remove the vertical border to the offset surface. Difficult to tell whether this comes from JPP or from the Sandbox Stamp tool, which may not like the generated surface (in particular the triangles in the angles). This is the first time such a bug is signaled, so I don't know too much what can be done. I'll think about it however.
                        PS: If you just want to draw the rectangle (or any shape) on the curved surface, you may want to try with ToolsOnSurface.
                        • fredo6F Offline
                          I have no explanation, because whether you drag the mouse or enter a number in the VCB, you end up in a stage where you still need to double-click or to press enter to start the JPP process. So there should be no difference actually!
                          I am interested to have a model where the difference can be perceived.
                          • H Offline
                            haynesc
                            hi fredo ... would itbe possible for you to rewrite JPP so that it loads into your fredo collection folder? so that its a bit tidier ?
                            thanks
                            • fredo6F Offline
                              thanks
                              I will rework Joint Push Pull at some point.
                              In between, here is an updated version where menus are put in a submenu Joint Push Pull (both main and selection context menu).
                              I also integrated the bit of code for toolbar remanence on Mac.
                              Can someone test it before I update the main post. Thanks.
                              to drop into the Sketchup Plugins folder
                              • jeff hammondJ Offline
                                tested on mac.
                                the submenus work in both the main and context menus
                                the tools work
                                toolbar works and remembers it's status
                                thanks!
                                  putnik
                                  tested on Windows XP SP3, SketchUp Pro 7 (latest)
                                  everything works (as per previous post)
                                  great plugin. Fredo6 for president.
                                  http://keshas.info
                                    Daniel S
                                    Works well here too.
                                    And then you need to reassign your shortcuts ๐Ÿ˜‰.
                                    Daniel S
                                    • H Offline
                                      haynesc
                                      thanks
                                      • BepB Offline
                                        Bep
                                        I have a question regarding joint push pull.
                                        It is illustated by the skp file.
                                        example.skp
                                        I hope that i am doing something wrong, or that some of my settings are wrong.
                                        It would be great if the desired outcome whould be possible
                                        greetings ,
                                        Bep van Malde
                                        "History is written by the winners"
                                        • fredo6F Offline
                                          [attachment=0:1jxqs3h2]<!-- ia0 -->example.skp<!-- ia0 -->[/attachment:1jxqs3h2]
                                          greetings ,
                                          Bep van Malde
                                          Bep,
                                          I think you simply touch some of the limitations of JPP. I am afraid this is a pure geometrical problem.
                                          Try to Push pull individually the faces by 2 cm, and then see how they can be connected 'jointly'. You'll see that there is no good solution.
                                            mpowell1234567890
                                            Hi, every time I try to use joint push-pull in sketchup, it creates a bugsplat and terminates sketchup 7. Is there a way to fix it?
                                            • 18
                                            • 19
                                            • 5 / 19
