    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
    • fredo6F
      I have no explanation, because whether you drag the mouse or enter a number in the VCB, you end up in a stage where you still need to double-click or to press enter to start the JPP process. So there should be no difference actually!
      I am interested to have a model where the difference can be perceived.
      • H
        haynesc
        hi fredo ... would itbe possible for you to rewrite JPP so that it loads into your fredo collection folder? so that its a bit tidier ?
        thanks
        • fredo6F
          thanks
          I will rework Joint Push Pull at some point.
          In between, here is an updated version where menus are put in a submenu Joint Push Pull (both main and selection context menu).
          I also integrated the bit of code for toolbar remanence on Mac.
          Can someone test it before I update the main post. Thanks.
          to drop into the Sketchup Plugins folder
          • jeff hammondJ
            tested on mac.
            the submenus work in both the main and context menus
            the tools work
            toolbar works and remembers it's status
            thanks!
            • P
              putnik
              tested on Windows XP SP3, SketchUp Pro 7 (latest)
              everything works (as per previous post)
              great plugin. Fredo6 for president.
              http://keshas.info
                Daniel S
                Works well here too.
                And then you need to reassign your shortcuts ๐Ÿ˜‰.
                Daniel S
                • H
                  haynesc
                  thanks
                  • BepB
                    Bep
                    I have a question regarding joint push pull.
                    It is illustated by the skp file.
                    example.skp
                    I hope that i am doing something wrong, or that some of my settings are wrong.
                    It would be great if the desired outcome whould be possible
                    greetings ,
                    Bep van Malde
                    "History is written by the winners"
                    • fredo6F
                      [attachment=0:1jxqs3h2]<!-- ia0 -->example.skp<!-- ia0 -->[/attachment:1jxqs3h2]
                      greetings ,
                      Bep van Malde
                      Bep,
                      I think you simply touch some of the limitations of JPP. I am afraid this is a pure geometrical problem.
                      Try to Push pull individually the faces by 2 cm, and then see how they can be connected 'jointly'. You'll see that there is no good solution.
                        mpowell1234567890
                        Hi, every time I try to use joint push-pull in sketchup, it creates a bugsplat and terminates sketchup 7. Is there a way to fix it?
                        • BepB
                          Bep
                          [attachment=0:2u6jklv3]<!-- ia0 -->example.skp<!-- ia0 -->[/attachment:2u6jklv3]
                          greetings ,
                          Bep van Malde
                          Bep,
                          Thanks for answering ,its a pitty this dos not work ๐Ÿ˜ข (yet)
                          Bep
                          • P
                            pr0
                            I know that this question doesn't concern the joint push pull plugin - however i've noticed that certain geometry can be push - pulled in a very visual and intuitive way when concerning pure geometry. Is it possible to do the same with 3d splines? Except instead of push - pulling them you would offset them? Fredo and Chris Fullmer are probably the masters concerning sketchup plugins - so i was wondering Fredo, do you think it would be possible to create? here's the link to the forum where there are visual examples. Thanks in advance.
                            404 Not Found
                            (www.sketchucation.com)
                            -Sam
                              dondanev
                              hvala puno ako ko razume thanx
                                rv1974
                                Hi Fredo!
                                I thought about some enhacement of the single face JPP. It should respect the adjacent faces (AB and CD keep their directions while BC is moving forward (example 2)). It works in revit and I think it would be great especially in architectiral practice.
                                P.S. Basicly instead of single BC face there could be any number of faces- it's all about vicinity treatment.
                                Thanks in advance
                                  JaViXP
                                  I have translated this plugin into Spanish, how can I change the default language?
                                  "Giving up is way harder than trying"
                                  JaViXP's Rendering
                                  • fredo6F
                                    Normally you'll get the spanish version if your Windows or Mac system is in spanish.
                                    To force the language, just create a file LibTraductor.def(or edit it if it already exists), and make sure the one line code is:
                                    TRADUCTOR_DEFAULT = "ES"
                                      JaViXP
                                      It displays an error for me, could you please do it? (JPP text is below)
                                      Thanks ๐Ÿ˜„
                                      JPP Text.txt
                                      JaViXP's Rendering
                                        magpie
                                        many thanks again fredo!
                                        • P
                                          Patrickpr
                                          Hy
                                          What is this?
                                          LibTraductor.def, an optional configuration file allowing override of language
                                          i Have the german version
                                          I can that not install ๐Ÿ˜ข ๐Ÿ˜ข ๐Ÿ˜ข
                                          • fredo6F
                                            @patrickpr said:
                                            Hy
                                            What is this?
                                            Patrick,
                                            Unfortunately, JointPushPull is an old script and the translation must be done in the code of the script itself (line 29 to 168 of jointpushpull.rb).
                                            The convention is to add the strings in the existing lists as "|DE| the text", being careful to put a \ before any accentuated or special character (and also careful with the Ruby syntax). Usually, I do it myself, based on translation provided by contributors in text files.
                                            PS: I plan a refresh of JPP one of these days, based on LibFredo6. Then the translation can be done in an easier way, like in FredoScale or HoverSelect, and in much more languages.
                                            • 18
                                            • 19
                                            • 5 / 19
