    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 446.6k Views 154 Watching
    • C
      cyan.archnet
      THANK YOU!, will definitely give this awesome plugin a try!
        AcesHigh
        where can i get the house model displayed on the PDF tutorial? I really like that house and would like to study a bit of american architectural conventions.
        • david_hD
          david_h
          Gracias Senor Zorro. How can our village ever repay you? 💚
          • C
            chango70
            Quick one. I've deleted the old zorro ruby from plugins folder. How come under Tools menu I see 2 zorros?
            • B
              bubbalove
              I'm seeing the same thing Chango70...
              "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
              • C
                chango70
                Its not just Zorro. I've deleted a redundent obj importer (can't remember which) yet it still shows up in my menu?!?
                  "main_menu.add_item("Zorro")" must be "main_menu.add_item("Zorro2")"
                  • GaieusG
                    It may have been Jim's obj importer (at least that's the only one I know of)
                    • schorradtS
                      schorradt
                      I added a Feature to your old Version (1.0) to automatic fill faces cut
                      Sketchup::set_status_text("Draw cut line, Push SHIFT to: Fill-Face-Automatic", SB_PROMPT)
                      maybe you can added in your current Version? 😄 its nice to have
                      here is the Code.Snipped:
                      if (@key=="shift")
                        ents.each {|e|
                         if e.typename == "Edge" then
                         sel.toggle e
                         else
                         sel.remove e
                          self.makeface sel
                      def makeface ins
                          ss = ins
                          total_items = ss.count      # Total count of all selected entities.
                          x = 0                       # faces-added accumulator
                          z = 0                       # loop count
                          notAnEdge = 0               # Accumulator for non-Edges
                          ss.each {|e|
                            if e.typename == "Edge" then  # find_faces only works on edges.
                               x += e.find_faces          # This creates faces if they can created. Returns # faces created.
                            else notAnEdge+=1             # Keep track of selections that were not an edge.
                            z+=1                          # bump loop counter
                      http://www.henryschorradt.de/
                      • W
                        Whaat
                        Thanks! I actually experimented with this feature, as well. However, I found that half the time, the faces that were automatically created were reversed, which became quite annoying. I suppose I could give the user the option if a certain key is pressed (as you have shown). The shift key would not work since it used for inference locking.
                        • schorradtS
                          schorradt
                          Here is my modifed Version of Zorro 1.0.
                          with Icons 😄
                          Plz use it...
                          and please forgive me, that I did without asking changed.
                          my Changes:
                          • Icon and Cursor
                          • Press: Shift -> Fill Faces to Cut
                          • Automatic Switch zu perspectiv-view-mode
                          Old modifed Zorro-Tool
                          • plot-parisP
                            plot-paris
                            Amazing!!!
                            in the past Zorro.rb has been a really cool toy (and quite an addictive one at that). but now with its parallel-projection capabilities and especially it's section-cut function Zorro is a valuable and indispensable tools (one of those 'how did we manage to live without it'-tools).
                            absolutely fantastic, accurate and extremely fast! I love it!!!
                            • C
                              chango70
                              LOL thats it!
                              • C
                                chango70
                                So how do u get rid of it then?
                                • GaieusG
                                  I don't know. I have a fairly freash install of Windows (and all that follows) so my Plugins folder is still pretty virgin (about 3 or 4 new plugins ever since).
                                  Ask Jim maybe.
                                    AcesHigh
                                    I dont know what is happening but Zorro 2 is constantly failing to make any cuts here.
                                    in fact, sometimes it ABSOLUTELY refuses to cut anything... even simple models, be them grouped or completely exploded. It starts creating the line, but I click the other end of the line but the line doesnt goes away... it like if I was not clicking.
                                    • W
                                      Whaat
                                      Open the Ruby Console Window and tell me what error message you are getting. Thanks
                                      • K
                                        kwistenbiebel
                                        Did you delete the old zorro ruby from the plugins folder?
                                        That solved the issues I had.
                                        • BurkhardB
                                          Burkhard
                                          Nice icon schorradt, but it does not work in parallel view ( on mac )
                                          http://www.ia-plus.de
                                          • schorradtS
                                            schorradt
                                            yes i know 😄 the parallel mode is a problem.
                                            but i hope to a better version in Zorro 2 ... with my Icon and Cursor 😄
                                            and the feature to find faces in Cut ... very nice.
                                            • 15
                                            • 16
                                            • 2 / 16
