    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 430.7k Views 154 Watching
    • david_hD
      david_h
      Gracias Senor Zorro. How can our village ever repay you? 💚
      • C
        chango70
        Quick one. I've deleted the old zorro ruby from plugins folder. How come under Tools menu I see 2 zorros?
        • B
          bubbalove
          I'm seeing the same thing Chango70...
          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
          • C
            chango70
            Its not just Zorro. I've deleted a redundent obj importer (can't remember which) yet it still shows up in my menu?!?
              "main_menu.add_item("Zorro")" must be "main_menu.add_item("Zorro2")"
              • GaieusG
                It may have been Jim's obj importer (at least that's the only one I know of)
                • schorradtS
                  schorradt
                  I added a Feature to your old Version (1.0) to automatic fill faces cut
                  Sketchup::set_status_text("Draw cut line, Push SHIFT to: Fill-Face-Automatic", SB_PROMPT)
                  maybe you can added in your current Version? 😄 its nice to have
                  here is the Code.Snipped:
                  if (@key=="shift")
                    ents.each {|e|
                     if e.typename == "Edge" then
                     sel.toggle e
                     else
                     sel.remove e
                      self.makeface sel
                  def makeface ins
                      ss = ins
                      total_items = ss.count      # Total count of all selected entities.
                      x = 0                       # faces-added accumulator
                      z = 0                       # loop count
                      notAnEdge = 0               # Accumulator for non-Edges
                      ss.each {|e|
                        if e.typename == "Edge" then  # find_faces only works on edges.
                           x += e.find_faces          # This creates faces if they can created. Returns # faces created.
                        else notAnEdge+=1             # Keep track of selections that were not an edge.
                        z+=1                          # bump loop counter
                  http://www.henryschorradt.de/
                  • W
                    Whaat
                    Thanks! I actually experimented with this feature, as well. However, I found that half the time, the faces that were automatically created were reversed, which became quite annoying. I suppose I could give the user the option if a certain key is pressed (as you have shown). The shift key would not work since it used for inference locking.
                    • schorradtS
                      schorradt
                      Here is my modifed Version of Zorro 1.0.
                      with Icons 😄
                      Plz use it...
                      and please forgive me, that I did without asking changed.
                      my Changes:
                      • Icon and Cursor
                      • Press: Shift -> Fill Faces to Cut
                      • Automatic Switch zu perspectiv-view-mode
                      Old modifed Zorro-Tool
                      • plot-parisP
                        plot-paris
                        Amazing!!!
                        in the past Zorro.rb has been a really cool toy (and quite an addictive one at that). but now with its parallel-projection capabilities and especially it's section-cut function Zorro is a valuable and indispensable tools (one of those 'how did we manage to live without it'-tools).
                        absolutely fantastic, accurate and extremely fast! I love it!!!
                        • C
                          chango70
                          LOL thats it!
                          • C
                            chango70
                            So how do u get rid of it then?
                            • GaieusG
                              I don't know. I have a fairly freash install of Windows (and all that follows) so my Plugins folder is still pretty virgin (about 3 or 4 new plugins ever since).
                              Ask Jim maybe.
                                AcesHigh
                                I dont know what is happening but Zorro 2 is constantly failing to make any cuts here.
                                in fact, sometimes it ABSOLUTELY refuses to cut anything... even simple models, be them grouped or completely exploded. It starts creating the line, but I click the other end of the line but the line doesnt goes away... it like if I was not clicking.
                                • W
                                  Whaat
                                  Open the Ruby Console Window and tell me what error message you are getting. Thanks
                                  • K
                                    kwistenbiebel
                                    Did you delete the old zorro ruby from the plugins folder?
                                    That solved the issues I had.
                                    • BurkhardB
                                      Burkhard
                                      Nice icon schorradt, but it does not work in parallel view ( on mac )
                                      http://www.ia-plus.de
                                      • schorradtS
                                        schorradt
                                        yes i know 😄 the parallel mode is a problem.
                                        but i hope to a better version in Zorro 2 ... with my Icon and Cursor 😄
                                        and the feature to find faces in Cut ... very nice.
                                        • B
                                          bellwells
                                          Dale, when I click on a section cut and select the "Slice Model at Section" nothing happens. I've read the tutorial, but I can't figure out what I'm doing wrong. I only have Zorro2.rb in my Plugins folder so it can't be a conflict with the original one.
                                          What a great feature this section option is!! I can't wait to get it working.
                                          Ron
                                          • Chris FullmerC
                                            After you do that Ron, try deleting the section plane. Your model should stay cut in half. I guess that is the desired functionality.
                                            • 15
                                            • 16
                                            • 2 / 16
