    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 412.4k Views 154 Watching
    • W Offline
      Whaat
      @schorradt said:
      I added a Feature to your old Version (1.0) to automatic fill faces cut
      Thanks! I actually experimented with this feature, as well. However, I found that half the time, the faces that were automatically created were reversed, which became quite annoying. I suppose I could give the user the option if a certain key is pressed (as you have shown). The shift key would not work since it used for inference locking.
      • schorradtS Offline
        schorradt
        Here is my modifed Version of Zorro 1.0.
        with Icons 😄
        Plz use it...
        and please forgive me, that I did without asking changed.
        my Changes:
        • Icon and Cursor
        • Press: Shift -> Fill Faces to Cut
        • Automatic Switch zu perspectiv-view-mode
        Old modifed Zorro-Tool
        http://www.henryschorradt.de/
        • plot-parisP Offline
          plot-paris
          Amazing!!!
          in the past Zorro.rb has been a really cool toy (and quite an addictive one at that). but now with its parallel-projection capabilities and especially it's section-cut function Zorro is a valuable and indispensable tools (one of those 'how did we manage to live without it'-tools).
          absolutely fantastic, accurate and extremely fast! I love it!!!
            chango70
            @gaieus said:
            It may have been Jim's obj importer (at least that's the only one I know of)
            LOL thats it!
              chango70
              So how do u get rid of it then?
                I don't know. I have a fairly freash install of Windows (and all that follows) so my Plugins folder is still pretty virgin (about 3 or 4 new plugins ever since).
                Ask Jim maybe.
                  AcesHigh
                  I dont know what is happening but Zorro 2 is constantly failing to make any cuts here.
                  in fact, sometimes it ABSOLUTELY refuses to cut anything... even simple models, be them grouped or completely exploded. It starts creating the line, but I click the other end of the line but the line doesnt goes away... it like if I was not clicking.
                  • W Offline
                    Whaat
                    Open the Ruby Console Window and tell me what error message you are getting. Thanks
                      kwistenbiebel
                      Did you delete the old zorro ruby from the plugins folder?
                      That solved the issues I had.
                      • BurkhardB Offline
                        Burkhard
                        Nice icon schorradt, but it does not work in parallel view ( on mac )
                        http://www.ia-plus.de
                          schorradt
                          yes i know 😄 the parallel mode is a problem.
                          but i hope to a better version in Zorro 2 ... with my Icon and Cursor 😄
                          and the feature to find faces in Cut ... very nice.
                            bellwells
                            Dale, when I click on a section cut and select the "Slice Model at Section" nothing happens. I've read the tutorial, but I can't figure out what I'm doing wrong. I only have Zorro2.rb in my Plugins folder so it can't be a conflict with the original one.
                            What a great feature this section option is!! I can't wait to get it working.
                            Ron
                            • Chris FullmerC Offline
                              After you do that Ron, try deleting the section plane. Your model should stay cut in half. I guess that is the desired functionality.
                                AcesHigh
                                Error: #<ArgumentError: Points are not planar>
                                C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273:in add_face' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273:in cut_geometry'
                                C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:107:in `onLButtonUp'
                                  bellwells
                                  Hi Chris, I tried that but...no luck. I zorro sliced a cube, activated the section cut tool, selected "Slice Model at Section" and erased said section cut, but nothing. I'll keep fiddling around.
                                  Edit: When I erase the section cut the model goes back to being "whole". The section cut always stays normal to the model surface not the Zorro cut.
                                  Ron
                                    bellwells
                                    The Slice Section feature does not work for me. I've even deleted and reinstalled.....no worky. Am I the only one with this problem?
                                    Ron
                                      Have you tried removing all other plugins except the new zorro?
                                        bellwells
                                        I hadn't thought to do this, but this didn't work either. Funny, I've never had any problems whatsoever installing and using plugins. I'm obviously doing something wrong.
                                        I've invoked the slice-model option with the section cut plane inside and outside the model. I've tried grouping.....I've tried it with both drinking beer and not drinking beer....I've tried everything. Argggg...
                                        Ron
                                          So the option to slice the model (or whatever its called) does show up though, right? Try opening the ruby console and the running the slice. See if any error messages come up in the ruby console. If they do, post them here. BTW, what version of SU are you using this on?
                                          • BurkhardB Offline
                                            Burkhard
                                            [quote="bellwells"].. I zorro sliced a cube, activated the section cut tool, selected "Slice Model at Section" and erased said section cut, but nothing. quote]
                                            Try the simple way...leave Zorro and use just the Sketchup sectionplane. Select the plane after the end position and run the script. For me it has nothing to do with zorro 😉
                                            • 15
                                            • 16
                                            • 3 / 16
