    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 446.6k Views 154 Watching
    • MALAISEM
      MALAISE
      Hi Whaat
      Some difficulties using Zorro2. No cutting effects, the white (feather 😆 ) arrow is gluing to the cut line.
      Let's see my previous post.
      MALAISE 😄
        derryatlanta
        Thanks so much, Whaat.
        Superb job developing and packaging this ruby. I look forward to checking it out today.
        Cheers,
        Nigel
        Stop your grinnin' and drop your linen
          sepo
          Thanks for the really good and useful plugin. Is there any chance to have closed section when using with SU section tool.
            materialdb
            THATS What I've been looking for! Thanks a lot!
            free vismat materials: http://www.material-db.com
            • C
              craigbic
              Awesome plugin! The ability to slice along a section cut face is FANTASTIC! Been waiting for something like that for a while now. Thank you so much!
              Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
              • jim smithJ
                jim smith
                Thank you, again, Dale great tool!
                "Out of clutter find simplicity,
                from discord find harmony,
                In the middle of difficulty lies opportunity"
                Albert Einstein
                • C
                  cyan.archnet
                  THANK YOU!, will definitely give this awesome plugin a try!
                    AcesHigh
                    where can i get the house model displayed on the PDF tutorial? I really like that house and would like to study a bit of american architectural conventions.
                    • david_hD
                      david_h
                      Gracias Senor Zorro. How can our village ever repay you? 💚
                      • C
                        chango70
                        Quick one. I've deleted the old zorro ruby from plugins folder. How come under Tools menu I see 2 zorros?
                        • B
                          bubbalove
                          I'm seeing the same thing Chango70...
                          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                          • C
                            chango70
                            Its not just Zorro. I've deleted a redundent obj importer (can't remember which) yet it still shows up in my menu?!?
                              "main_menu.add_item("Zorro")" must be "main_menu.add_item("Zorro2")"
                              • GaieusG
                                It may have been Jim's obj importer (at least that's the only one I know of)
                                • schorradtS
                                  schorradt
                                  I added a Feature to your old Version (1.0) to automatic fill faces cut
                                  Sketchup::set_status_text("Draw cut line, Push SHIFT to: Fill-Face-Automatic", SB_PROMPT)
                                  maybe you can added in your current Version? 😄 its nice to have
                                  here is the Code.Snipped:
                                  if (@key=="shift")
                                    ents.each {|e|
                                     if e.typename == "Edge" then
                                     sel.toggle e
                                     else
                                     sel.remove e
                                      self.makeface sel
                                  def makeface ins
                                      ss = ins
                                      total_items = ss.count      # Total count of all selected entities.
                                      x = 0                       # faces-added accumulator
                                      z = 0                       # loop count
                                      notAnEdge = 0               # Accumulator for non-Edges
                                      ss.each {|e|
                                        if e.typename == "Edge" then  # find_faces only works on edges.
                                           x += e.find_faces          # This creates faces if they can created. Returns # faces created.
                                        else notAnEdge+=1             # Keep track of selections that were not an edge.
                                        z+=1                          # bump loop counter
                                  http://www.henryschorradt.de/
                                  • W
                                    Whaat
                                    Thanks! I actually experimented with this feature, as well. However, I found that half the time, the faces that were automatically created were reversed, which became quite annoying. I suppose I could give the user the option if a certain key is pressed (as you have shown). The shift key would not work since it used for inference locking.
                                    • schorradtS
                                      schorradt
                                      Here is my modifed Version of Zorro 1.0.
                                      with Icons 😄
                                      Plz use it...
                                      and please forgive me, that I did without asking changed.
                                      my Changes:
                                      • Icon and Cursor
                                      • Press: Shift -> Fill Faces to Cut
                                      • Automatic Switch zu perspectiv-view-mode
                                      Old modifed Zorro-Tool
                                      • plot-parisP
                                        plot-paris
                                        Amazing!!!
                                        in the past Zorro.rb has been a really cool toy (and quite an addictive one at that). but now with its parallel-projection capabilities and especially it's section-cut function Zorro is a valuable and indispensable tools (one of those 'how did we manage to live without it'-tools).
                                        absolutely fantastic, accurate and extremely fast! I love it!!!
                                        • C
                                          chango70
                                          LOL thats it!
                                          • C
                                            chango70
                                            So how do u get rid of it then?
                                            • 15
                                            • 16
                                            • 2 / 16
