    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 355.6k Views 154 Watching
      Absolutly brilliant and so easy to use! 😎
      Just for quibble "main_menu.add_item("Zorro")" must be "main_menu.add_item("Zorro2")" 😉
        kwistenbiebel
        @whaat said:
        @kwistenbiebel said:
        I draw the cut line by clicking two points but it doesn't cut. (using the updated version)
        Any errors in the Ruby Console?? Did you read the tutorial?
        I deleted the old zorro.rb and now it works.
        Thank you again for this plugin.
        • MALAISEM Offline
          MALAISE
          Hi Whaat
          Some difficulties using Zorro2. No cutting effects, the white (feather 😆 ) arrow is gluing to the cut line.
          Let's see my previous post.
          MALAISE 😄
            derryatlanta
            Thanks so much, Whaat.
            Superb job developing and packaging this ruby. I look forward to checking it out today.
            Cheers,
            Nigel
            Stop your grinnin' and drop your linen
              sepo
              Thanks for the really good and useful plugin. Is there any chance to have closed section when using with SU section tool.
                materialdb
                THATS What I've been looking for! Thanks a lot!
                free vismat materials: http://www.material-db.com
                  craigbic
                  Awesome plugin! The ability to slice along a section cut face is FANTASTIC! Been waiting for something like that for a while now. Thank you so much!
                  Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
                  • jim smithJ Offline
                    jim smith
                    Thank you, again, Dale great tool!
                    "Out of clutter find simplicity,
                    from discord find harmony,
                    In the middle of difficulty lies opportunity"
                    Albert Einstein
                      cyan.archnet
                      THANK YOU!, will definitely give this awesome plugin a try!
                        AcesHigh
                        where can i get the house model displayed on the PDF tutorial? I really like that house and would like to study a bit of american architectural conventions.
                        • david_hD Offline
                          david_h
                          Gracias Senor Zorro. How can our village ever repay you? 💚
                            chango70
                            Quick one. I've deleted the old zorro ruby from plugins folder. How come under Tools menu I see 2 zorros?
                              bubbalove
                              I'm seeing the same thing Chango70...
                              "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                chango70
                                Its not just Zorro. I've deleted a redundent obj importer (can't remember which) yet it still shows up in my menu?!?
                                    It may have been Jim's obj importer (at least that's the only one I know of)
                                    • schorradtS Offline
                                      schorradt
                                      I added a Feature to your old Version (1.0) to automatic fill faces cut
                                      Sketchup::set_status_text("Draw cut line, Push SHIFT to: Fill-Face-Automatic", SB_PROMPT)
                                      maybe you can added in your current Version? 😄 its nice to have
                                      here is the Code.Snipped:
                                      if (@key=="shift")
                                        ents.each {|e|
                                         if e.typename == "Edge" then
                                         sel.toggle e
                                         else
                                         sel.remove e
                                          self.makeface sel
                                      def makeface ins
                                          ss = ins
                                          total_items = ss.count      # Total count of all selected entities.
                                          x = 0                       # faces-added accumulator
                                          z = 0                       # loop count
                                          notAnEdge = 0               # Accumulator for non-Edges
                                          ss.each {|e|
                                            if e.typename == "Edge" then  # find_faces only works on edges.
                                               x += e.find_faces          # This creates faces if they can created. Returns # faces created.
                                            else notAnEdge+=1             # Keep track of selections that were not an edge.
                                            z+=1                          # bump loop counter
                                      http://www.henryschorradt.de/
                                      • W Offline
                                        Whaat
                                        Thanks! I actually experimented with this feature, as well. However, I found that half the time, the faces that were automatically created were reversed, which became quite annoying. I suppose I could give the user the option if a certain key is pressed (as you have shown). The shift key would not work since it used for inference locking.
                                          schorradt
                                          Here is my modifed Version of Zorro 1.0.
                                          with Icons 😄
                                          Plz use it...
                                          and please forgive me, that I did without asking changed.
                                          my Changes:
                                          • Icon and Cursor
                                          • Press: Shift -> Fill Faces to Cut
                                          • Automatic Switch zu perspectiv-view-mode
                                          Old modifed Zorro-Tool
                                          • plot-parisP Offline
                                            plot-paris
                                            Amazing!!!
                                            in the past Zorro.rb has been a really cool toy (and quite an addictive one at that). but now with its parallel-projection capabilities and especially it's section-cut function Zorro is a valuable and indispensable tools (one of those 'how did we manage to live without it'-tools).
                                            absolutely fantastic, accurate and extremely fast! I love it!!!
                                            • 15
                                            • 16
                                            • 2 / 16
