[Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
"you need to activate the script via the menu Windows->Preferences->Extension."
link
Daniel S -
Thanks. I just did it that way. It works very well now. Very nice plugin.
Ah yeah, that also. Sorry, I didn't remember.
Ok OK, I was using some time tos and in deed it is great.. it is just lately it doesnt work on my SU....
mainly offset is just doing annoying beepand thats all, no offset ni nada...
Please help me with that,
Could you turn on the Ruby Console and advise on any error message you would see (best would be to copy them and post the result on the forum).
By the way, which version of SU do you use, and on which OS?
And what did you do 'lately' with SU (upgrade?).Thanks
Fred
ohh, well, this is what is written there:
when I select face:
Error: #<NoMethodError: undefined method
+' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~3/Plugins/MatchboxPlugin/Population.rb:174:in
C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:617:incompute_active_loops' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:569:in
construct_contour_loops'
C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:214:incheck_initial_selection' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:1425:in
activate'
C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:66:inselect_tool' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:66:in
launch_offset'
C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/LoaderOnSurface.rb:108:inmanage_command' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/LoaderOnSurface.rb:108:in
call'
C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/LibTraductor_20.rb:572:inadd_command' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/LibTraductor_20.rb:572:in
call'
and when I don't select..
C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:282:invirtual_selection' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:1656:in
onMouseMove'I am using SU7 right now, but in 6 i was not function as well....
thanks alot
Nankyo -
nanyo: Try removing the MatchboxPlugin. I think I remember reading somewhere that I modified some of the base ruby classes which lead to errors in other plugins. From your errors it appears that it's coming from that plugin.
wowo so simple and work ) thanks alo alot
muchisima gracias !!!!
now I can offset, lets partythanks thomthom,
next time i will try to read those messages...
Have fun. -
HI, where can i donwnload this script? Sorry a newbie here. Thanks.
At the bottom of the original post. First page on this thread.
Thank you so.
Just construction points? You can try native Su tool! GO to Edit menu / Delete guides.
You can also copy this code below in the ruby console... It will delete all construction points in the selection.Sketchup.active_model.selection.each{|e|e.erase! if e.class==Sketchup;;ConstructionPoint}
Hi Fredo!
I suppose you will move your menus in "Fredo collection" in your next TOS update, like freescale plugin ?
That would be cool, and also your push pull plugin!
Excellent plugin, as always, sir! Thank you... -
Matt,
good tip: it is something I had forgotten.. > but the construction lines and points, they are all deleted from the overall model. Something we want not to be each time.
@matt666 said:
You can also copy this code below () in the ruby console... It will delete all construction points in the selection.
This is just the good code: construction lines remain and every construction point inside selection are removed. Would you please make it as a .rb dear Matt? (I'm complet ignorant upon this ). It would be so greatfull!
:-)simon -
Thank you, Thank you, Thank you, Fredo!!!! (insert Happy Dance Here!)
At last I can do what I've been trying to do since I first found SketchUp (modeling planets for exterior sci-fi scenes)This plug-in is MADE of 100% AWESOME!
Nathryc
You are the Gustave Eiffel and Pierre Bezier of SketchUp. Merci Beaucoup from the USA!
What will you do to top this achievement?
Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up
no such file to load -- /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rbError Loading File bezierspline.rb no such file to load -- /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb
I downloaded the plugin into /Library/Application Support/Google SketchUp 7/SketchUp/Plugins; and I didn't change the name of the folder, but it is named: ToolsOnSurface_131-1
what should I do??[/quote]
@kus said:
Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up.
what should I do??
Kus,
Seems you had a problem with the unzip operation.
For Tools on Surface you must have only 2 elements in the Sketchup Plugins folder:- a small file: ZLoader_OnSurface.rb
- a folder: TOS_Dir_13, with other rb files in it (and some subfolders).
I suggest you check your files and redo the Unzip, with a Select All and then Extract, to make sure your preserve the folder hierarchy when unzipping.
Hey, I've followed the quickcards installment guide but upon opening Sketchup it isn't running Tools On Surface, I'm not given any loading error or anything, it simply doesn't run, any help?
