    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
      skylinerz
      HI, where can i donwnload this script? Sorry a newbie here. Thanks.
        At the bottom of the original post. First page on this thread.
          acio
          Thank you so.
          • simon le bonS Offline
            simon le bon
            Hi!
            I'm actually working with arc tool (on surface).
            May be I have missed something. I would like to remove all the construction points in one operation when the drawing is finished but i don't know how to do..
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_toolsOnSurface_a.jpg
            ;-)simon
              Matt666
              Just construction points? You can try native Su tool! GO to Edit menu / Delete guides.
              You can also copy this code below in the ruby console... It will delete all construction points in the selection.
              Sketchup.active_model.selection.each{|e|e.erase! if e.class==Sketchup;;ConstructionPoint}
              Frenglish at its best !
              My scripts
                Matt666
                Hi Fredo!
                I suppose you will move your menus in "Fredo collection" in your next TOS update, like freescale plugin ? ❓
                That would be cool, and also your push pull plugin!
                Sans titre 1.jpgExcellent plugin, as always, sir! 😄 Thank you...
                My scripts
                  simon le bon
                  🙂 Matt,
                  --/ Hope i'm not going too far from this thread /--
                  good tip: it is something I had forgotten.. > but the construction lines and points, they are all deleted from the overall model. Something we want not to be each time.
                  @matt666 said:
                  You can also copy this code below () in the ruby console... It will delete all construction points in the selection.
                  This is just the good code: construction lines remain and every construction point inside selection are removed. Would you please make it as a .rb dear Matt? (I'm complet ignorant upon this ). It would be so greatfull!
                  :-)simon
                  • N Offline
                    Nathryc
                    Thank you, Thank you, Thank you, Fredo!!!! (insert Happy Dance Here!)
                    At last I can do what I've been trying to do since I first found SketchUp (modeling planets for exterior sci-fi scenes)
                    This plug-in is MADE of 100% AWESOME!
                    Nathryc
                      Roger
                      You are the Gustave Eiffel and Pierre Bezier of SketchUp. Merci Beaucoup from the USA!
                      What will you do to top this achievement?
                      http://www.azcreative.com
                        Kus
                        Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up
                        no such file to load -- /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rbError Loading File bezierspline.rb
                        I downloaded the plugin into /Library/Application Support/Google SketchUp 7/SketchUp/Plugins; and I didn't change the name of the folder, but it is named: ToolsOnSurface_131-1
                        what should I do??[/quote]
                        • fredo6F Offline
                          @kus said:
                          Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up.
                          what should I do??
                          Kus,
                          Seems you had a problem with the unzip operation.
                          For Tools on Surface you must have only 2 elements in the Sketchup Plugins folder:
                          • a small file: ZLoader_OnSurface.rb
                          • a folder: TOS_Dir_13, with other rb files in it (and some subfolders).
                          I suggest you check your files and redo the Unzip, with a Select All and then Extract, to make sure your preserve the folder hierarchy when unzipping.
                            Steelyjoe_n
                            Hey, I've followed the quickcards installment guide but upon opening Sketchup it isn't running Tools On Surface, I'm not given any loading error or anything, it simply doesn't run, any help?
                              Steelyjoe_n
                              Nevermind
                              I forgot to check it in preferences, thank you for the program anyway 😄)
                              • N Offline
                                niarfe
                                Fredo!!! I'm becoming your biggest fan!!!
                                thanks a lot!
                                  monkeybss
                                  I seem to have a problem too. I can see the toolbar but the offset doesn't work (Su7,7.0.102470), the line-on surface does, but nothing else seems to work.
                                  I'm not familiar with ruby, but it feels like some setting might be wrong (like a variable in Autocad).
                                  Later..
                                  Just being stupid, I forgot to load in "preferences". Works like a charm!
                                    Arthaxx
                                    • H Offline
                                      hitman47127
                                      thanksssssssssss a lot, 😍 😍 😍
                                      • E Offline
                                        Efrado
                                        Hi FREDO ,Thanks a lot for this Magnificent gift. Following the PDF I was traying to reproduce the "section pie" but I could not .How did you do? Thanks "
                                        • fredo6F Offline
                                          Use the 'Ring' capability of the TOS shapes. In the VCB, you type an length, posititive or negative' followed by 'x', and you get the shape contour with the specificed offset. This is explained in the doc, in the Shapes section (page 9).
                                          Hope this answers your question.
                                          • E Offline
                                            Efrado
                                            As always your Kindness is OUT OF DOUBT ----PRICELESS-----Thank You
                                            • 11
                                            • 31
                                            • 32
                                            • 9 / 32
