    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • N Offline
      nankyo
      Ok OK, I was using some time tos and in deed it is great.. it is just lately it doesnt work on my SU....
      mainly offset is just doing annoying beepand thats all, no offset ni nada...
      Please help me with that,
      πŸ€“
      • fredo6F Offline
        πŸ€“
        Could you turn on the Ruby Console and advise on any error message you would see (best would be to copy them and post the result on the forum).
        By the way, which version of SU do you use, and on which OS?
        And what did you do 'lately' with SU (upgrade?).
        Fred
        • N Offline
          nankyo
          ohh, well, this is what is written there:
          when I select face:
          Error: #<NoMethodError: undefined method +' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~3/Plugins/MatchboxPlugin/Population.rb:174:in +'
          C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:617:in compute_active_loops' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:569:in construct_contour_loops'
          C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:214:in check_initial_selection' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:1425:in activate'
          C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:66:in select_tool' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:66:in launch_offset'
          C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/LoaderOnSurface.rb:108:in manage_command' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/LoaderOnSurface.rb:108:in call'
          C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/LibTraductor_20.rb:572:in add_command' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/LibTraductor_20.rb:572:in call'
          and when I don't select..
          C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:282:in virtual_selection' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TOS_Dir_13/OffsetOnSurface.rb:1656:in onMouseMove'
          I am using SU7 right now, but in 6 i was not function as well....
          πŸŽ‰ πŸŽ‰
          thanks alot
          Nankyo
            nanyo: Try removing the MatchboxPlugin. I think I remember reading somewhere that I modified some of the base ruby classes which lead to errors in other plugins. From your errors it appears that it's coming from that plugin.
            • N Offline
              nankyo
              wowo so simple and work ) thanks alo alot
              muchisima gracias !!!!
              now I can offset, lets party 😎 😎 😍 😍
              thanks thomthom,
              next time i will try to read those messages...
              Have fun.
                skylinerz
                HI, where can i donwnload this script? Sorry a newbie here. Thanks.
                  At the bottom of the original post. First page on this thread.
                    acio
                    Thank you so.
                    • simon le bonS Offline
                      simon le bon
                      Hi!
                      I'm actually working with arc tool (on surface).
                      May be I have missed something. I would like to remove all the construction points in one operation when the drawing is finished but i don't know how to do..
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_toolsOnSurface_a.jpg
                      ;-)simon
                        Matt666
                        Just construction points? You can try native Su tool! GO to Edit menu / Delete guides.
                        You can also copy this code below in the ruby console... It will delete all construction points in the selection.
                        Sketchup.active_model.selection.each{|e|e.erase! if e.class==Sketchup;;ConstructionPoint}
                        πŸ˜‰
                        Frenglish at its best !
                        My scripts
                          Matt666
                          Hi Fredo!
                          I suppose you will move your menus in "Fredo collection" in your next TOS update, like freescale plugin ? ❓
                          That would be cool, and also your push pull plugin!
                          Sans titre 1.jpgExcellent plugin, as always, sir! πŸ˜„ Thank you...
                          My scripts
                            simon le bon
                            πŸ™‚ Matt,
                            --/ Hope i'm not going too far from this thread /--
                            good tip: it is something I had forgotten.. > but the construction lines and points, they are all deleted from the overall model. Something we want not to be each time.
                            @matt666 said:
                            You can also copy this code below () in the ruby console... It will delete all construction points in the selection.
                            This is just the good code: construction lines remain and every construction point inside selection are removed. Would you please make it as a .rb dear Matt? (I'm complet ignorant upon this ). It would be so greatfull!
                            :-)simon
                            • N Offline
                              Nathryc
                              Thank you, Thank you, Thank you, Fredo!!!! (insert Happy Dance Here!)
                              At last I can do what I've been trying to do since I first found SketchUp (modeling planets for exterior sci-fi scenes)
                              This plug-in is MADE of 100% AWESOME!
                              Nathryc
                                Roger
                                You are the Gustave Eiffel and Pierre Bezier of SketchUp. Merci Beaucoup from the USA!
                                What will you do to top this achievement?
                                http://www.azcreative.com
                                  Kus
                                  Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up
                                  no such file to load -- /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rbError Loading File bezierspline.rb
                                  I downloaded the plugin into /Library/Application Support/Google SketchUp 7/SketchUp/Plugins; and I didn't change the name of the folder, but it is named: ToolsOnSurface_131-1
                                  what should I do??[/quote]
                                  • fredo6F Offline
                                    @kus said:
                                    Hi there I would like to make some drawings on a sphere. I downloaded the plugin but when I start up SU this comes up.
                                    what should I do??
                                    Kus,
                                    Seems you had a problem with the unzip operation.
                                    For Tools on Surface you must have only 2 elements in the Sketchup Plugins folder:
                                    • a small file: ZLoader_OnSurface.rb
                                    • a folder: TOS_Dir_13, with other rb files in it (and some subfolders).
                                    I suggest you check your files and redo the Unzip, with a Select All and then Extract, to make sure your preserve the folder hierarchy when unzipping.
                                      Steelyjoe_n
                                      Hey, I've followed the quickcards installment guide but upon opening Sketchup it isn't running Tools On Surface, I'm not given any loading error or anything, it simply doesn't run, any help?
                                        Steelyjoe_n
                                        Nevermind
                                        I forgot to check it in preferences, thank you for the program anyway πŸ˜„)
                                        • N Offline
                                          niarfe
                                          Fredo!!! I'm becoming your biggest fan!!!
                                          thanks a lot!
                                            monkeybss
                                            I seem to have a problem too. I can see the toolbar but the offset doesn't work (Su7,7.0.102470), the line-on surface does, but nothing else seems to work.
                                            I'm not familiar with ruby, but it feels like some setting might be wrong (like a variable in Autocad).
                                            Later..
                                            Just being stupid, I forgot to load in "preferences". Works like a charm!
                                            • 31
                                            • 32
                                            • 8 / 32
