    Hardware recommendations
    409 Posts 97 Posters 191.3k Views 97 Watching
    • C
      chango70
      Is there a way for you to compare sketchup perfomance between windows 7 and Vista?
        robsc
        i think the video card demonstrated the largest difference in performance, but my feeling is that win 7 is MUCH more stable than vista, and considerably faster. btw i did a clean install and it took not much more than 1 hour to accomplish robsc
        • C
          chango70
          Just done a quick test with my new i7 Core 920 CPU desktop (2.67GHz x 4 Stock overclocked to 3.00GHz x 4) running the same VRay rendering against my T9500 2.6GHz x2 Core Duo laptop.
          i7 Cores managed to finish the rendering just under 3 minutes, while the Core duo took 14 minutes. Thats almost 5x the speed!!!
          It turns out the multi threading on i7 Cores gets working as 2 cpus per core making VRay run like as if I had 8 cores. ๐Ÿ˜ฎ
          Superb results, I recommend it to anyone.
          • C
            chango70
            I believe that now the i7 Cores are released there is no reason other than cost to go AMD anymore. The benchmarks are amazing! The slowest i7 Core 920 is faster than the fastest last generation Quad (the QX9775)which is incredable! Plus they apparently can overclock relatively easily according to Tom's Hardware (http://www.tomshardware.co.uk/). It was worth the wait. Now I am going to specify a system with the following hardware:
            Intel Core i7-920 2.66Ghz
            6Gb DDR3 Ram
            WD velociRaptor 10000Rpm HD
            Samsung 1TB Spinpoint 7200rpm HD
            Asus P6T Desluxe Intel X58 Motherboard
            Quadro FX 1700 Graphics Card
            That should do the trick ๐Ÿ˜„ for modelling and rendering
            Any improvement welcome.
              remus
              looks jealous
              • GaieusG
                I have a (fairly "old") Intel Pentium 4 processor in my laptop and it's 3.8 GHz but it was from the time when multi core was still in an experimental stage and this single core processor was made to be able to perform dual threading (I think this is called "hyperthreading" in the HW world). It's really handy because in fact it is a single core (with quite high clock speed) so SU can run at high speed on it but when it comes to applications which are capable of multi threading (ie. rendering), it works as a dual core.
                First I didn't know this and I was surprised to see that in the Task manager I have two CPU's displayed and when rendering with IDX Renditioner, it was apparent that two different, independent sets of rows were being processed in the image at the same time.
                I am not a HW guru so I learn something new every day.
                • C
                  chango70
                  I just did the same test against my friend's 2x Xeon Quad Mac Pro found out this rig is about 25% faster. Considering his cost around ยฃ2200 and mine around ยฃ1500. I'd say I had a deal.
                  Gaieus, yes i heard about the Pentium 4 multi threading. I heard for some reason they axed it on the Duo Core processors. Maybe it was too good value for money?
                  • GaieusG
                    I don't know. I'm just feeling lucky now
                    • AnssiA
                      Anssi
                      The new i7 processor has hyperthreading again. If I understand right, it can also split a demanding task among multiple cores doing something like hyperthreading in reverse...
                      Anssi
                      • C
                        caddict
                        For the record, I have just had to retire my 600MHz Toshiba laptop from active service.
                        With its 128MB memory and 11GB harddrive running Windows 2000 and with an on-board video chip, it bravely powered SU6 through many a client presentation. (Granted, the model would often break up into wireframe if view changes were too rapid)
                        Now that I have shifted to SU7, and SU6 cannot open models made in version 6, when I tried to install SU7 on the old girl, I was met with the fatal message "Operating System not Supported".
                        So there you go. Progress. Still, she had to go sometime.
                        Although I am thinking that I could easily revert back to SU6 without really noticing, seeing that version 7 was hardly a quantum leap.
                        • plot-parisP
                          plot-paris
                          well, at least now you have an excuse to buy a monster! (may I suggest something like the 18.1" screen
                          Acer Aspire 8920, that weighs 4.8 kg and hardly deserves the title of 'laptop'?) ๐Ÿ˜„
                          • C
                            caddict
                            I've started saving already
                            • T
                              tomasz
                              [attachment=0:3anrpjzn]<!-- ia0 -->acer-aspire-8920.jpg<!-- ia0 -->[/attachment:3anrpjzn]
                              I am also looking for a laptop suitable for SU. You can buy cheaper and not so heavy Acer with same or probably better graphics card. It won't be 18" screen, but who wants to carry a 5kg and/or kill a flying-by bird with a swing of a screen.
                              • plot-parisP
                                plot-paris
                                I do! I do!!! and as a matter of fact, I am writing this with the bespoken beast on my lap, listening to 'Air' by Johann Sebastian Bach from it's in-built 5.1 Cinematic Surround Sound speaker system (with subwoofer - in a laptop!).
                                (and, admittedly, my shoulders are still sore from carying it during my travel from London to the south of Germany two days ago ๐Ÿ˜‰ )
                                • AnssiA
                                  Anssi
                                  Jakob,
                                  Does it make much noise? I have an older 17" Acer Aspire, and i am otherwise quite fond of it, but it churns away like a bulldozer (not quite but...). I envy my daughter's IMac-it has no fans at all!
                                  Anssi
                                  • plot-parisP
                                    plot-paris
                                    it definitely has a fan running, especially when running renders of course. but I think it is not too loud - and for it's monstrous size appropriate ๐Ÿ˜‰
                                    • EddyNLE
                                      EddyNL
                                      Guys,
                                      I've got this museum piece:
                                      AMD Sempron 2400+
                                      1,75 Ghz, 512 MB
                                      ASUS Radeon 9600 128MB
                                      I'm looking to buy a new desktop because I can't run any large SU models.
                                      What's the most important issue for 3d performance like SketchUp and Kerky?
                                      • Dual core? RAM? Or the videocard?
                                      • Any suggestions?
                                      Thanks, Ward
                                      viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                                        remus
                                        For sketchup you want a fast clock speed (number of cores doesnt effect SU performance.) Good processors to look at are the intel core 2 duo and if your feeling up to a bit of overclocking, the intel core 2 quad. Youll also need a graphics card with decent openGL support, the quadro cards are generally pretty good for this, although a bit pricey.
                                        For kerky you want lots of RAM and a processor with lots of cores, although youll need a 64 bit OS if you want to have more than 4GB of ram.
                                        On balance, id say go with a core 2 quad processor and 4gb of ram. A pretty standard combination thats also pretty powerful.
                                        • EddyNLE
                                          EddyNL
                                          Thanks for the quick reply Remus!
                                          Would this be any good?
                                          Intel E5200 Core 2 Duo
                                          Geforce 9300 512mb
                                          4096mb / 4GB DDR2 800Mhz
                                          500GB 7200rpm
                                          AMD Phenom X3 8650+
                                          Geforce 8300 HDMI, DVI
                                          750GB 7200rpm
                                            remus
                                            The top setup looks good ๐Ÿ‘ Dont know enough about AMD to tell you whether the other choice of processor is a good one, though.
                                            With regards to the 8300 graphics card, it seems there have been a couple of minor issues with it and SU: http://groups.google.com/group/SketchUp/web/graphics-card-feedback?hl=en Probably worth investigating, just in case.
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
