    Hardware recommendations
    409 Posts 97 Posters 208.7k Views 97 Watching
    • K
      kwistenbiebel
      @j3nsen said:
      @chango70 said:
      I believe that now the i7 Cores are released there is no reason other than cost to go AMD anymore. The benchmarks are amazing! The slowest i7 Core 920 is faster than the fastest last generation Quad (the QX9775)which is incredable! Plus they apparent can overclock relatively easily according to Tom's Hardware (http://www.tomshardware.co.uk/). It was worth the wait. Now I am going to specify a system with the following hardware:
      Intel Core i7-920 2.66Ghz
      6Gb DDR3 Ram
      WD velociRaptor 10000Rpm HD
      Samsung 1TB Spinpoint 7200rpm HD
      Asus P6T Desluxe Intel X58 Motherboard
      Quadro FX 1700 Graphics Card
      That should do the trick 😄 for modelling and rendering
      Any improvement welcome.
      WOAOW!!! 😮
      Yeah well, a super rig like that won't do you any good when using Sketchup.
      Sketchup will still perform like your grandmothers software.
      I don't even understand we even have this thread going.
      Sketchup 7 is the same slow bug splatting beast as SU 6, no matter what rig you have.
      (SU crashes about 20 times a day on my 8 core PC on mildly complex models).
      Sadly, there is absolutely no use in getting a monster PC to run Sketchup.
      Period.
      • bigstickB
        bigstick
        I'm inclined to agree. SU is not multi-core enabled, and as discussed elsewhere, there aren't too many benefits from making it multi-core. Graphics support is the most important thing though I think. Some cards give reasonable performance, others not. Get a good recommendation for one of these.
        If you are buying a new PC, make sure its performance is tuned to your other apps, other than the proviso regarding graphics card support mentioned above.
        • AnssiA
          Anssi
          For SU use I would at the moment put processor clock speed above the number of cores. If you are switching from a single-core Pentium IV you will not be happy unless the new CPU has the same or faster rate than your old one. Generally I would recommend speeds over 3 GHz.
          Anssi
          • C
            chango70
            @kwistenbiebel said:
            6Gb DDR3 Ram
            WOAOW!!! 😮
            Period.
            You are ofcourse absolutely right. However it does help out other applications like Rhino a great deal. I have to say there is a noticeable increase in ability to handle more complex geometry but it is still slow handling lots of high detail trees. I guess there is no getting around the fact that Sketchup IS a slow program...
            • L
              linea
              20 times a day?! Seriously? I have a Toshiba Satellite intel centrino dual core laptop, Nvidia Go 7600 card, 2 Gig of Ram. I'm not building high poly stuff but I build some fairly heavy models and only see a crash about once a week.
              • K
                kwistenbiebel
                It does.
                My modeling itself isn't always that high poly, but the extra props I introduce in my models (trees,furniture, etc...) and also the textures, make my files hugh in just a minute.
                Also, I am using render software and Sketchup needs to do the export. On larger scenes, it will crash if you're not careful.
                It is about what purpose you use Sketchup for.
                • brodieB
                  brodie
                  Kwist, out of curiosity what sort of file sizes are you talking about?
                  -Brodie
                  • C
                    Charlie__V
                    Hello all,
                    Anyone running an Nvidia GeForce 8700MGT with hardware acceleration enabled ?
                    I searched and found that an older driver for the 8800 allows for HA, but no such driver for the 8700.
                    EDIT:
                    Well for those interested....looks like I may have solved/answered my own question.
                    Seems I had a combination of option settings selected that were causing me grief.
                    In the Nvidia control panel I needed to have the image setting set to Let 3D app Decide
                    And in SU preferences....Open GL....Capabilities....use an option with Anti Alias set to 0x
                    SLI Enabled/Disableddoes not seem to make a difference.
                    Above settings are with Dell driver 176.78_Dec21_2008
                    TIA.....
                    best,
                    Charlie
                    Specs:
                    Dell
                    XPS M1730, Intel Core 2 Extreme X9000(2.8GHz, 800Mhz 6M L2 Cache)
                    NVIDIA SLI Dual GeForce 8700MGT with 512MB GDDR3
                    4GB, DDR2, 667MHz
                    320GB 7200RPM Hard Drive
                    OS: XP Pro SP3
                      robsc
                      hi, all; I've just had good luck installing windows 7 on my computerputer and installing an Nvidia 9500 gt card. SU runs swell now, and I'd like to add my data to the aforementioned hardware survey. Unfortunately Windows7 beta is not one of the operating systems listed in the drop-down. Would the suthor please care to expand this menu so that i might further share this info? thanks, robsc
                      • C
                        chango70
                        Is there a way for you to compare sketchup perfomance between windows 7 and Vista?
                          robsc
                          i think the video card demonstrated the largest difference in performance, but my feeling is that win 7 is MUCH more stable than vista, and considerably faster. btw i did a clean install and it took not much more than 1 hour to accomplish robsc
                          • C
                            chango70
                            Just done a quick test with my new i7 Core 920 CPU desktop (2.67GHz x 4 Stock overclocked to 3.00GHz x 4) running the same VRay rendering against my T9500 2.6GHz x2 Core Duo laptop.
                            i7 Cores managed to finish the rendering just under 3 minutes, while the Core duo took 14 minutes. Thats almost 5x the speed!!!
                            It turns out the multi threading on i7 Cores gets working as 2 cpus per core making VRay run like as if I had 8 cores. 😮
                            Superb results, I recommend it to anyone.
                            • C
                              chango70
                              I believe that now the i7 Cores are released there is no reason other than cost to go AMD anymore. The benchmarks are amazing! The slowest i7 Core 920 is faster than the fastest last generation Quad (the QX9775)which is incredable! Plus they apparently can overclock relatively easily according to Tom's Hardware (http://www.tomshardware.co.uk/). It was worth the wait. Now I am going to specify a system with the following hardware:
                              6Gb DDR3 Ram
                                remus
                                looks jealous
                                • GaieusG
                                  I have a (fairly "old") Intel Pentium 4 processor in my laptop and it's 3.8 GHz but it was from the time when multi core was still in an experimental stage and this single core processor was made to be able to perform dual threading (I think this is called "hyperthreading" in the HW world). It's really handy because in fact it is a single core (with quite high clock speed) so SU can run at high speed on it but when it comes to applications which are capable of multi threading (ie. rendering), it works as a dual core.
                                  First I didn't know this and I was surprised to see that in the Task manager I have two CPU's displayed and when rendering with IDX Renditioner, it was apparent that two different, independent sets of rows were being processed in the image at the same time.
                                  I am not a HW guru so I learn something new every day.
                                  • C
                                    chango70
                                    I just did the same test against my friend's 2x Xeon Quad Mac Pro found out this rig is about 25% faster. Considering his cost around £2200 and mine around £1500. I'd say I had a deal.
                                    Gaieus, yes i heard about the Pentium 4 multi threading. I heard for some reason they axed it on the Duo Core processors. Maybe it was too good value for money?
                                    • GaieusG
                                      I don't know. I'm just feeling lucky now
                                      • AnssiA
                                        Anssi
                                        The new i7 processor has hyperthreading again. If I understand right, it can also split a demanding task among multiple cores doing something like hyperthreading in reverse...
                                        Anssi
                                        • C
                                          caddict
                                          For the record, I have just had to retire my 600MHz Toshiba laptop from active service.
                                          With its 128MB memory and 11GB harddrive running Windows 2000 and with an on-board video chip, it bravely powered SU6 through many a client presentation. (Granted, the model would often break up into wireframe if view changes were too rapid)
                                          Now that I have shifted to SU7, and SU6 cannot open models made in version 6, when I tried to install SU7 on the old girl, I was met with the fatal message "Operating System not Supported".
                                          So there you go. Progress. Still, she had to go sometime.
                                          Although I am thinking that I could easily revert back to SU6 without really noticing, seeing that version 7 was hardly a quantum leap.
                                          • plot-parisP
                                            plot-paris
                                            well, at least now you have an excuse to buy a monster! (may I suggest something like the 18.1" screen
                                            Acer Aspire 8920, that weighs 4.8 kg and hardly deserves the title of 'laptop'?) 😄
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
