[Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
Wow been busy rendering in Su im so Surprise on whats going on in skechup world!!!
i really need to catchUp!!!
manymany thanks to you fredo!!! i dont know you but your plugin rocks!!!
i know few guys here from podium but not all.. hope to be part of your team.
thanks and regards
jds
I like te tool a lot.. but when I try to use I get a bug splat Avery time...
Is it ma by because I am using 64bit pc???
Hope someone can help
Does it happen with all tools?
Does it happen before, while or after you did the drawing?Any other 64-bits Windows user having the same problem?
I'm on 64bit Vista and I use the script with no problems.
Thanks Fredo...
Your tools are really big help for me when making furniture modelsThanks
wow! that´s real 3D !!!
Hi Fredo
I was late finding this thread and didn't know about this ruby. Awesome!Thanks.
At the moment, I am struggling around all the bugs that the Sketchup API has on Mac.
So unless I release just for Windows.... -
I would be happy with that
great to hear, that you are still on it Fredo. I am looking forward to the new release
As a hint, it will be 27 working days before the release of SU7
And then you can start re-writing the whole script for compatibility issues
thank very much
Big call Fredo!!!!!
Coen,
You can testify that my NDA with big G is as thin as a face in a Sketchup model, that is, I have absolutely no knowledge whatsoever of what is going on and did not sign anything by the way.
I am working on ToolsOnSurface, but actually wanted to clean up and structure a little bit the script so that it is easier to write additional functionality. Part of it was using Web dialog, to avoid the Function keys, another part was to manage the releasing, the proliferation of icons and having a cleaner shared libraries. It just happened that on my way, I had this problem with Web Dialog on Mac, for which I hope to get some help from big G.
Anyway, as an additional hint, let's say that it will be on a Thursday.
Hey, the toolbar not appears.
What happend? The icons.. not work, there aren´t buttons, I just search on Ruby Console...I WANT A SOLUTION!!!!!!!
"you need to activate the script via the menu Windows->Preferences->Extension."
Daniel S
Hi Peeps,
Do I have to delete the old toolbar icons first before I drop the new incons done by Cadfather into the TOS dir?
Thanks,
Jeff -
Fredo I find your script a real Sketchup improvement, thank you for developing it!
It's really interesting the construction line circle. It reminds me a suggestion I've had some time ago
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=3610
The possibility to take a real construction circle you can refernece on it to draw with accurance. For example, now in sketchup I can't draw an arc with given radius tangent to two circles; I can't draw a circle (with a random point center) tangent to another existing one.
Would Such as request be possible to seen developed in your script, sooner or later? Or it's something Sketchup cant support? -
This is possible, and actually only On Surface in the general case (otherwise you need the 2 tangents to be in the same plane).
Will think about it, as this may simply be an adaptation of the Arc tool.
The only issue is that I don't have much time to be very active on my scripts at the moment, so it may take a while.
The alternative is that someone writes a dedicated script for that specific function.Fredo
Thank you verymuch, i love you
