    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • fredo6F
      As a hint, it will be 27 working days before the release of SU7 πŸ˜„ πŸ˜„
      • GaieusG
        And then you can start re-writing the whole script for compatibility issues πŸ˜„
        • T
          tulacong
          thank very much 😍
          • utilerU
            utiler
            Big call Fredo!!!!!
            Just Curious...
            • fredo6F
              Coen,
              You can testify that my NDA with big G is as thin as a face in a Sketchup model, that is, I have absolutely no knowledge whatsoever of what is going on and did not sign anything by the way.
              I am working on ToolsOnSurface, but actually wanted to clean up and structure a little bit the script so that it is easier to write additional functionality. Part of it was using Web dialog, to avoid the Function keys, another part was to manage the releasing, the proliferation of icons and having a cleaner shared libraries. It just happened that on my way, I had this problem with Web Dialog on Mac, for which I hope to get some help from big G.
              Anyway, as an additional hint, let's say that it will be on a Thursday.
              • Y
                yonic
                Hey, the toolbar not appears.
                What happend? The icons.. not work, there arenΒ΄t buttons, I just search on Ruby Console...
                I WANT A SOLUTION!!!!!!!
                  Daniel S
                  "you need to activate the script via the menu Windows->Preferences->Extension."
                  Daniel S
                  • C
                    Click Draw
                    Hi Peeps,
                    Do I have to delete the old toolbar icons first before I drop the new incons done by Cadfather into the TOS dir?
                    Thanks,
                    Jeff
                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                    • G
                      Gjenio
                      Fredo I find your script a real Sketchup improvement, thank you for developing it!
                      It's really interesting the construction line circle. It reminds me a suggestion I've had some time ago
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=3610
                      The possibility to take a real construction circle you can refernece on it to draw with accurance. For example, now in sketchup I can't draw an arc with given radius tangent to two circles; I can't draw a circle (with a random point center) tangent to another existing one.
                      Would Such as request be possible to seen developed in your script, sooner or later? Or it's something Sketchup cant support?
                      • fredo6F
                        This is possible, and actually only On Surface in the general case (otherwise you need the 2 tangents to be in the same plane).
                        Will think about it, as this may simply be an adaptation of the Arc tool.
                        The only issue is that I don't have much time to be very active on my scripts at the moment, so it may take a while.
                        The alternative is that someone writes a dedicated script for that specific function.
                        • T
                          tulacong
                          Thank you verymuch, i love you
                          • Q
                            Qpernick
                            Hello,
                            I am new here. My name is Filip. Nice to meet you.
                            I wonder if this plugin works with Sketchup 7?
                            I unzipping but no Tos-Dir-13 directory is created. Why?
                            • fredo6F
                              The script should work in SU7.
                              For your problem, be careful in Winzip to do a SELECT ALL, and then an EXTRACT in the Sketchup Plugins directory, in order to have Winzip to recreate the folder structure.
                              • Q
                                Qpernick
                                Thanks.I was using bed unzip program. I unpacked it by winzim now and structure of files is ok but still dont have this plugin in sketchup. Any idea?
                                • GaieusG
                                  Hi Qpernick and welcome.
                                  You should activate the toolbar (Surface operations or what) fro the View > Toolbars menu (somewhere at the bottom).
                                  • Q
                                    Qpernick
                                    Hi. No, becouse I couldnt find this there.??
                                      Daniel S
                                      link
                                      Daniel S
                                      • Q
                                        Qpernick
                                        Thanks. I just did it that way. It works very well now. Very nice plugin.
                                        • GaieusG
                                          Ah yeah, that also. Sorry, I didn't remember.
                                          • N
                                            nankyo
                                            Ok OK, I was using some time tos and in deed it is great.. it is just lately it doesnt work on my SU....
                                            mainly offset is just doing annoying beepand thats all, no offset ni nada...
                                            Please help me with that,
                                            πŸ€“
                                            • 31
                                            • 32
                                            • 7 / 32
