    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • T
      theolwakachangchang
      πŸ˜† πŸ˜†
      hmmmm turns out I found the problem... For some reason I had extracted the files into the tools directory instead of the plugins directory
      • CadFatherC
        CadFather
        πŸ˜’ πŸ˜‰
          renyiandhan
          Amazing!!! Thanks!!!
            agrazdi
            Any news about the double line you mentioned for V1.4 ?
            agrazdi
            • fredo6F
              This will come, but not before end of Sep (actually, it should do more than double, and on any contour). I did not spend a lot of time recently on Rubys, but should try to resume soon, with some work on Web dialogs as well.
              I also solved the question of generating faces when drawing lines on surfaces.
              • B
                BorgMan
                Well that's strange, I'm using the tool right now to offset from a shape on a curved face. However, for some reason it thinks that the object is part of the face too, and thus is offsetting over that face. That's (obviously) not what I want...
                More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                You've gotta love Slivers.
                • fredo6F
                  Not sure I understand the problem.
                  Just in case, there is an option 'Isolate surface when extending' which is mapped on F7 and also available in the contextual menu. This allows ignoring the surrounding surface when you offset.
                  • B
                    BorgMan
                    Thanks Fredo; I'll try that next.
                    I'm getting this error too. Is there anything I forgot to extract?
                    Error Loading File LibOnSurface.rb
                    uninitialized constant SUToolsOnSurface::TOS_DIRError Loading File LoaderOnSurface.rb
                    No such file to load -- /LibTraductor_20.rbError Loading File ShapeOnSurface.rb
                    uninitialized constant SUToolsOnSurface::CODE_Rectangle
                    [EDIT] Hmmm... didn't work. The problem is that in the last screenshot, you can see a blue line that comes through the object (default color). That's the face I want to offset. When I do so, it thinks that that object is the same as the cilinder on which I am trying to offset. This results in a few lines on the cilinder (the grey area), but then all of a sudden the lines makes a strange turn, goes over the object (the default color thing), and when it touches the grey area again, it goes back to the beginning. I want that blue lined face to extrude, not anything else 😐
                      jds
                      Wow been busy rendering in Su im so Surprise on whats going on in skechup world!!!
                      i really need to catchUp!!!
                      manymany thanks to you fredo!!! i dont know you but your plugin rocks!!! πŸ‘
                      i know few guys here from podium but not all.. hope to be part of your team.
                      thanks and regards
                      jds
                      www.santosjdportfolio.blogspot.com
                        dirkkkk
                        I like te tool a lot.. but when I try to use I get a bug splat Avery time...
                        Is it ma by because I am using 64bit pc???
                        Hope someone can help
                        • fredo6F
                          Does it happen with all tools?
                          Does it happen before, while or after you did the drawing?
                          Any other 64-bits Windows user having the same problem?
                          • Chris FullmerC
                            I'm on 64bit Vista and I use the script with no problems.
                            • marleusM
                              marleus
                              Thanks Fredo...
                              Your tools are really big help for me when making furniture models
                              Thanks πŸ‘
                              Markus Sillander
                              Vantaa, Finland
                              I'm on FormFonts now
                              http://www.formfonts.com
                              • U
                                urs0815
                                wow! thatΒ΄s real 3D !!!
                                • L
                                  linea
                                  Hi Fredo
                                  I was late finding this thread and didn't know about this ruby. Awesome!Thanks.
                                  • fredo6F
                                    At the moment, I am struggling around all the bugs that the Sketchup API has on Mac.
                                    So unless I release just for Windows....
                                    • plot-parisP
                                      plot-paris
                                      I would be happy with that πŸ˜„
                                      great to hear, that you are still on it Fredo. I am looking forward to the new release
                                      • fredo6F
                                        As a hint, it will be 27 working days before the release of SU7 πŸ˜„ πŸ˜„
                                        • GaieusG
                                          And then you can start re-writing the whole script for compatibility issues πŸ˜„
                                          • T
                                            tulacong
                                            thank very much 😍
                                            • 31
                                            • 32
                                            • 7 / 32
