    [Plugin] Polar line - 20110525
    63 Posts 21 Posters 35.8k Views 21 Watching
    • JClementsJ Offline
      JClements
      Matt:
      1st. Thanks!
      2nd. Seems to have a problem. I typed in " 100**'** " and it drew a line 8'4".
        Perhaps the  %(#FF0040)[****'****]  character is the problem?
      Regards, John
        Matt666
        @jclements said:
        Perhaps the ' character is the problem?
        Hi ! I think This plugin doesn't support Feet / Inch units... I will have a look ! πŸ˜‰
        Frenglish at its best !
        My scripts
        • EdsonE Offline
          Edson
          sorry, but it does not work for me on mac.
          i click on the icon, it asks me to specify the first point, which i do. then a dialogue box appears for me to enter the length and the angle. i do do that and click OK. nothing happens!
          what else should i do? any ideas?
          http://www.mahfuz.arq.br
            Matt666
            Hum... Another Pac problem!! Damned. I don't know what's the problem, and I've no mac... Can you copy here the error in the ruby console please ?
            Thank you...
            Matt.
            My scripts
            • EdsonE Offline
              Edson
              here you have it.
                Matt666
                I don't understand the problem... Again !! Grmbl.
                Can you try line below in the ruby console, please ?
                Math.cos(45.degrees)
                And these lines
                a = Geom;;Point3d.new(12.5,12.5,25.2)
                a[0]
                a[1]
                a[2]
                On each line, can you give me the results, please ?
                Thank you again for your patience, Edson!
                My scripts
                • EdsonE Offline
                  Edson
                  is this what you wanted?
                    Edson: you wrote 0 = Geom:: and 1 = Geom:: . That's not what he wanted. Just type exactly what he listed.
                    First:
                    Then
                    a[0]
                    and so on.
                    • EdsonE Offline
                      Edson
                      is this it?
                        Yes, like that. πŸ˜„
                          Matt666
                          Thank you Edson and Thomthom !
                          I really really don't understand...
                          Can someone help me for this bug, please ?
                          My scripts
                            I can have a look on my own Mac when I get home.
                            Looks very weird. Does PC SU and MacSU use the same Ruby version?
                            Have you tried placing () around lg * Math.cos(ang) . (just a wild guess)
                              Hey, I notice you use $lg and then lg. Is it suppose to be two different things?
                                Matt666
                                I don't know, but I often have problems...
                                Thank you !
                                I will look in the code... Thank you!
                                My scripts
                                  Got it nailed!
                                  It's all down to line 69:
                                  case Sketchup.active_model.options[0][2]
                                  On my mac it returned nil
                                  Your case switch doesn't account for that value so lg is passed on as a string.
                                      when 0;lg = result[0].to_f
                                      when 1;lg = result[0].to_f.feet
                                      when 2;lg = result[0].to_f.mm
                                      when 3;lg = result[0].to_f.cm
                                      when 4;lg = result[0].to_f.m
                                  My fix was to add a default handler for the switch.
                                      else  ;lg = result[0].to_f
                                  Not sure why line 69 return nil though, didn't look into that.
                                    Matt666
                                    Ok cool !! Thank you for your bug research Thomthom !
                                    I am pretty sure it works if you try this code below
                                    Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                                    can you try it please ?
                                    For "pl" variable, no problem. "$pl" is used to reuse last number entered in the polarline window...
                                    My scripts
                                      I'll try it and report back.
                                        Yes, that worked. πŸ‘
                                          Matt666
                                          Thank you Thomthom!
                                          I've updated the first post... Can you try it on Mac please? Thank you!
                                          My scripts
                                          • EdsonE Offline
                                            Edson
                                            matt,
                                            now nothing happens at all. not even the request for the first point appears.
                                            • 2 / 4
