    [Plugin] Polar line - 20110525
    63 Posts 21 Posters 38.9k Views 21 Watching
      Edson: you wrote 0 = Geom:: and 1 = Geom:: . That's not what he wanted. Just type exactly what he listed.
      First:
      a = Geom;;Point3d.new(12.5,12.5,25.2)
      Then
      a[0]
      and so on.
      • EdsonE Offline
        Edson
        is this it?
        http://www.mahfuz.arq.br
          Yes, like that. πŸ˜„
            Matt666
            Thank you Edson and Thomthom !
            I really really don't understand...
            Can someone help me for this bug, please ?
            Frenglish at its best !
            My scripts
              I can have a look on my own Mac when I get home.
              Looks very weird. Does PC SU and MacSU use the same Ruby version?
              Have you tried placing () around lg * Math.cos(ang) . (just a wild guess)
                Hey, I notice you use $lg and then lg. Is it suppose to be two different things?
                  Matt666
                  I don't know, but I often have problems...
                  Thank you !
                  I will look in the code... Thank you!
                  My scripts
                    Got it nailed!
                    It's all down to line 69:
                    case Sketchup.active_model.options[0][2]
                    On my mac it returned nil
                    Your case switch doesn't account for that value so lg is passed on as a string.
                        when 0;lg = result[0].to_f
                        when 1;lg = result[0].to_f.feet
                        when 2;lg = result[0].to_f.mm
                        when 3;lg = result[0].to_f.cm
                        when 4;lg = result[0].to_f.m
                    My fix was to add a default handler for the switch.
                        else  ;lg = result[0].to_f
                    Not sure why line 69 return nil though, didn't look into that.
                      Matt666
                      Ok cool !! Thank you for your bug research Thomthom !
                      I am pretty sure it works if you try this code below
                      Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                      can you try it please ?
                      For "pl" variable, no problem. "$pl" is used to reuse last number entered in the polarline window...
                      My scripts
                        I'll try it and report back.
                          Yes, that worked. πŸ‘
                            Matt666
                            Thank you Thomthom!
                            I've updated the first post... Can you try it on Mac please? Thank you!
                            My scripts
                            • EdsonE Offline
                              Edson
                              matt,
                              now nothing happens at all. not even the request for the first point appears.
                                Matt666
                                Can you show me the error in the ruby console please?
                                My scripts
                                • EdsonE Offline
                                  Edson
                                  the console window was filled with a lot of stuff. this is the last piece. if you need the rest, let me know.
                                    Matt666
                                    Excuse me Edson... A silly error... Shame on me !
                                    http://msnsmileys.net/p/smileys/Popo/Shame.png
                                    I updated the code...
                                    Sorry !
                                    My scripts
                                    • EdsonE Offline
                                      Edson
                                      YESSSSSS! it does work!
                                      and thanks, matt, for the great scripts you have been creating. count on me anytime to help you with testing scripts on mac.
                                        Matt666
                                        It does work, AT LAST !! Ouf... Thank you for your patience Edson!
                                        Thank you, Edson 😳
                                        Ok, cool! There is also one only script that doesn't work on Mac... I'll try to do smt on it...
                                        My scripts
                                          I got a Mac Mini at disposal on a OSX 10.4 system. Slow as heck, but works to see if it runs.
                                            Matt666
                                            Ok, Thank you Thomthom!
                                            My scripts
                                            • 3 / 4
