    [Plugin] Polar line - 20110525
    63 Posts 21 Posters 39.2k Views 21 Watching
    • C
      cyan.archnet
      THANKS A LOT Matt666, will do!
        Matt666
        Thank you 😉 😄
        @remus said:
        More update ideas: perhaps an option to draw the line on the plane of a selected face? it would make drawing weird lines a lot easier.
        Why not, but give an angle depending on what Trigonometric origin?
        Originally trigonometric drawing or side of the longest edge of the selected face ?
        @watkins said:
        Perhaps I'm being a little dense, but why would you want to rotate the line after creation?
        To creat a 3d polarline ! I think it's too complicated (not to develop, but calculate two angles in two different 2d plans). Or easier to rotate yourself after line creation.
        polar grid....
        Salut Malaise ! Qu'entends-tu par là ? what do you mean by this?
        Frenglish at its best !
        My scripts
        • MALAISEM
          MALAISE
          Salut Matt
          Je pensais aux autres systèmes de coordonnées ( cylindrique, polaire )
          Un maillage polaire au sens cartographique par exemple...
          Merci de ton attention
          Translation:
          I thought to polar grid like the one found on maps.
          MALAISE
          • Z
            zhuangsuph
            [Plugin] Polar line
            • CadFatherC
              CadFather
              wow, can't believe i missed one of Matt's plugins! 😲 😍
              • L
                linea
                Matt
                👍 Simple but powerful.
                Thanks, I'm digging a big hole in anticipation of throwing out all my cad software.
                • JClementsJ
                  JClements
                  Matt:
                  1st. Thanks!
                  2nd. Seems to have a problem. I typed in " 100**'** " and it drew a line 8'4".
                    Perhaps the  %(#FF0040)[****'****]  character is the problem?
                  Regards, John
                    Matt666
                    @jclements said:
                    Perhaps the ' character is the problem?
                    Hi ! I think This plugin doesn't support Feet / Inch units... I will have a look ! 😉
                    My scripts
                    • EdsonE
                      Edson
                      sorry, but it does not work for me on mac.
                      i click on the icon, it asks me to specify the first point, which i do. then a dialogue box appears for me to enter the length and the angle. i do do that and click OK. nothing happens!
                      what else should i do? any ideas?
                      http://www.mahfuz.arq.br
                        Matt666
                        Hum... Another Pac problem!! Damned. I don't know what's the problem, and I've no mac... Can you copy here the error in the ruby console please ?
                        Thank you...
                        Matt.
                        My scripts
                        • EdsonE
                          Edson
                          here you have it.
                            Matt666
                            I don't understand the problem... Again !! Grmbl.
                            Can you try line below in the ruby console, please ?
                            Math.cos(45.degrees)
                            And these lines
                            a = Geom;;Point3d.new(12.5,12.5,25.2)
                            a[0]
                            a[1]
                            a[2]
                            On each line, can you give me the results, please ?
                            Thank you again for your patience, Edson!
                            My scripts
                            • EdsonE
                              Edson
                              is this what you wanted?
                                Edson: you wrote 0 = Geom:: and 1 = Geom:: . That's not what he wanted. Just type exactly what he listed.
                                First:
                                Then
                                a[0]
                                and so on.
                                • EdsonE
                                  Edson
                                  is this it?
                                    Yes, like that. 😄
                                      Matt666
                                      Thank you Edson and Thomthom !
                                      I really really don't understand...
                                      Can someone help me for this bug, please ?
                                      My scripts
                                        I can have a look on my own Mac when I get home.
                                        Looks very weird. Does PC SU and MacSU use the same Ruby version?
                                        Have you tried placing () around lg * Math.cos(ang) . (just a wild guess)
                                          Hey, I notice you use $lg and then lg. Is it suppose to be two different things?
                                            Matt666
                                            I don't know, but I often have problems...
                                            Thank you !
                                            I will look in the code... Thank you!
                                            My scripts
                                            • 2 / 4
