    [Plugin] Polar line - 20110525
    63 Posts 21 Posters 34.4k Views 21 Watching
      Matt666
      Hum... Another Pac problem!! Damned. I don't know what's the problem, and I've no mac... Can you copy here the error in the ruby console please ?
      Thank you...
      Matt.
      Frenglish at its best !
      My scripts
      • EdsonE Offline
        Edson
        here you have it.
        http://www.mahfuz.arq.br
          Matt666
          I don't understand the problem... Again !! Grmbl.
          Can you try line below in the ruby console, please ?
          Math.cos(45.degrees)
          And these lines
          a = Geom;;Point3d.new(12.5,12.5,25.2)
          a[0]
          a[1]
          a[2]
          On each line, can you give me the results, please ?
          Thank you again for your patience, Edson!
          My scripts
          • EdsonE Offline
            Edson
            is this what you wanted?
              Edson: you wrote 0 = Geom:: and 1 = Geom:: . That's not what he wanted. Just type exactly what he listed.
              First:
              Then
              a[0]
              and so on.
              • EdsonE Offline
                Edson
                is this it?
                  Yes, like that. πŸ˜„
                    Matt666
                    Thank you Edson and Thomthom !
                    I really really don't understand...
                    Can someone help me for this bug, please ?
                    My scripts
                      I can have a look on my own Mac when I get home.
                      Looks very weird. Does PC SU and MacSU use the same Ruby version?
                      Have you tried placing () around lg * Math.cos(ang) . (just a wild guess)
                        Hey, I notice you use $lg and then lg. Is it suppose to be two different things?
                          Matt666
                          I don't know, but I often have problems...
                          Thank you !
                          I will look in the code... Thank you!
                          My scripts
                            Got it nailed!
                            It's all down to line 69:
                            case Sketchup.active_model.options[0][2]
                            On my mac it returned nil
                            Your case switch doesn't account for that value so lg is passed on as a string.
                                when 0;lg = result[0].to_f
                                when 1;lg = result[0].to_f.feet
                                when 2;lg = result[0].to_f.mm
                                when 3;lg = result[0].to_f.cm
                                when 4;lg = result[0].to_f.m
                            My fix was to add a default handler for the switch.
                                else  ;lg = result[0].to_f
                            Not sure why line 69 return nil though, didn't look into that.
                              Matt666
                              Ok cool !! Thank you for your bug research Thomthom !
                              I am pretty sure it works if you try this code below
                              Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                              can you try it please ?
                              For "pl" variable, no problem. "$pl" is used to reuse last number entered in the polarline window...
                              My scripts
                                I'll try it and report back.
                                  Yes, that worked. πŸ‘
                                    Matt666
                                    Thank you Thomthom!
                                    I've updated the first post... Can you try it on Mac please? Thank you!
                                    My scripts
                                    • EdsonE Offline
                                      Edson
                                      matt,
                                      now nothing happens at all. not even the request for the first point appears.
                                        Matt666
                                        Can you show me the error in the ruby console please?
                                        My scripts
                                        • EdsonE Offline
                                          Edson
                                          the console window was filled with a lot of stuff. this is the last piece. if you need the rest, let me know.
                                            Matt666
                                            Excuse me Edson... A silly error... Shame on me !
                                            http://msnsmileys.net/p/smileys/Popo/Shame.png
                                            I updated the code...
                                            Sorry !
                                            My scripts
                                            • 2 / 4
