    [Plugin] Polar line - 20110525
    63 Posts 21 Posters 36.6k Views 21 Watching
    • EdsonE Offline
      Edson
      is this it?
      http://www.mahfuz.arq.br
        Yes, like that. πŸ˜„
          Matt666
          Thank you Edson and Thomthom !
          I really really don't understand...
          Can someone help me for this bug, please ?
          Frenglish at its best !
          My scripts
            I can have a look on my own Mac when I get home.
            Looks very weird. Does PC SU and MacSU use the same Ruby version?
            Have you tried placing () around lg * Math.cos(ang) . (just a wild guess)
              Hey, I notice you use $lg and then lg. Is it suppose to be two different things?
                Matt666
                I don't know, but I often have problems...
                Thank you !
                I will look in the code... Thank you!
                My scripts
                  Got it nailed!
                  It's all down to line 69:
                  case Sketchup.active_model.options[0][2]
                  On my mac it returned nil
                  Your case switch doesn't account for that value so lg is passed on as a string.
                      when 0;lg = result[0].to_f
                      when 1;lg = result[0].to_f.feet
                      when 2;lg = result[0].to_f.mm
                      when 3;lg = result[0].to_f.cm
                      when 4;lg = result[0].to_f.m
                  My fix was to add a default handler for the switch.
                      else  ;lg = result[0].to_f
                  Not sure why line 69 return nil though, didn't look into that.
                    Matt666
                    Ok cool !! Thank you for your bug research Thomthom !
                    I am pretty sure it works if you try this code below
                    Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                    can you try it please ?
                    For "pl" variable, no problem. "$pl" is used to reuse last number entered in the polarline window...
                    My scripts
                      I'll try it and report back.
                        Yes, that worked. πŸ‘
                          Matt666
                          Thank you Thomthom!
                          I've updated the first post... Can you try it on Mac please? Thank you!
                          My scripts
                          • EdsonE Offline
                            Edson
                            matt,
                            now nothing happens at all. not even the request for the first point appears.
                              Matt666
                              Can you show me the error in the ruby console please?
                              My scripts
                              • EdsonE Offline
                                Edson
                                the console window was filled with a lot of stuff. this is the last piece. if you need the rest, let me know.
                                  Matt666
                                  Excuse me Edson... A silly error... Shame on me !
                                  http://msnsmileys.net/p/smileys/Popo/Shame.png
                                  I updated the code...
                                  Sorry !
                                  My scripts
                                  • EdsonE Offline
                                    Edson
                                    YESSSSSS! it does work!
                                    and thanks, matt, for the great scripts you have been creating. count on me anytime to help you with testing scripts on mac.
                                      Matt666
                                      It does work, AT LAST !! Ouf... Thank you for your patience Edson!
                                      Thank you, Edson 😳
                                      Ok, cool! There is also one only script that doesn't work on Mac... I'll try to do smt on it...
                                      My scripts
                                        I got a Mac Mini at disposal on a OSX 10.4 system. Slow as heck, but works to see if it runs.
                                          Matt666
                                          Ok, Thank you Thomthom!
                                          My scripts
                                            Matt666
                                            sorry Thomthom, but can you have a Mac look on this script, please?
                                            My scripts
                                            • 3 / 4
