    RpTreeMaker - new version Dec 12, 2008
    extensions
    67 Posts 15 Posters 13.9k Views 15 Watching
      sorgesu
      Lovely. I do have a question though. It isn't readily apparent from the images.
      At the low poly count, other solutions have had a tendencay to cut accross bits of the image. that is, it lopped off bits. With a photo it may not matter, but with a drawing, some of the nuance is in the outline and if that is removed, it really takes away from the visual.
      Comment?
      Susan Sorger
      Former Seller Hand Rendered Entourage
      Former Canadian Authorized Training Centre, SketchUp
      • Al HartA Offline
        Al Hart
        I'll keep my eye open for that.
        It was my intention to not include hexagons which had only 1 or 2 pixels overlap with with the image. But I will change it to include everything. It might make the shadow slightly larger, but should still work ok.
        Al Hart
        IRender nXt from Render Plus
        • EarthMoverE Offline
          EarthMover
          Here's a quick test with Vray. I did have to add alpha mask to the trees in order to get the outline to disappear. It's odd though that the alpha map didn't seem to affect the shadow output. No worries though, as the high poly output shadow is very good as is.
          Also, shadows appear the same on all trees within Podium.
          Al, have you ever considered adding the ability to import a .png file into the treemaker, solely to utilize the shadow mask algorithm? This would be an indispensable tool for me as the time spent on cutting out shadow masks by hand is very tedious. It would be a handy tool for inserting a billboard and having the tool automatically generate an output with the shadow mask.
          Content Creator at Skapeup
            I'd expect that since Podium can handle the transparent channel of the png image so its shadow is even better than that of any of the cutouts.
            Nicely rendered trees! šŸ‘
              sepo
              Gaieus you are correct.šŸ˜„ .png trees render no problem in Podium
                Actually I have found it very useful and handy with a couple of rendering engines that they support alpha channel rather than you'd need to suffer with clip masks (although they are not very hard to make from a nice alpha channels anyway)
                  sepo
                  True , clipmaps are easy to make, but when you have a lot of them in SU file it is not as easy to navigate about (of course if those are not .png)
                  • Al HartA Offline
                    Al Hart
                    Do you add the alpha mask to the trees in SketchUp, or as a post process in V-ray.
                    If you add them in SketchUp, send me a model with a tree with an alpha-mask.
                    If you add them in V-Ray, send me a sample of the alpha-mask.
                    Al Hart
                    • Al HartA Offline
                      Al Hart
                      I see that you placed the tree in front of a window, but it wasn't reflective.
                      I forgot about reflections.
                      Would you put one of the trees in front of a reflective window or mirror to see if we get the reflection properly?
                      I only put the image on one side of the tree (since they are marked as always face camera). But I may need to put a material on both sides.
                      Mirrored trees - IRender
                      Al Hart
                        EarthMover
                        Al, Here is the alpha map I used and were I put it. Vray runs from within sketchup, but you add the alpha map in the transparency channel from within vray.
                        Also, the reflections are not working in Vray.
                        Hope that helps.
                        • Al HartA Offline
                          Al Hart
                          Hope that helps.
                          I will try putting the tree image on the back of the tree as well, and we can see if that helps with reflection.
                          If I make an alpha map, do you want me to store it on the disk somewhere, or in SketchUp somewhere?
                          Al Hart
                            EarthMover
                            I guess it would make the most sense to just output the alpha channel in the same location that the tree image is saved to. Also, there is no naming contingency in Vray, so the saved name could be anything you choose.
                            • Al HartA Offline
                              Al Hart
                              The tree textures are stored initially on the disk in your temporary folder, however they would be hard to find, and not easy to get to later if you open an older model.
                              Here is one idea.
                              a. I add a hidden edge to the tree component which has a material which is the alpha channel map.
                              b. You can go to SketchUp / Materials / Model and right click on the "dummy" material for the alpha channel
                              c. After the right click, and click Export Texture image to save the image somewhere and send it to V-ray.
                              Al Hart
                              • Al HartA Offline
                                Al Hart
                                Try this model.
                                The tree has materials on both sides - so it should work OK in the mirror.
                                The tree has the alpha clipmask stored on a material on the tree itself (the material with the tree itself white), so you should be able to select the clipmask from the materials window and save the image.
                                clipmask material saved in SketchUp model
                                tree with material on both sides and clipmask
                                Al Hart
                                  EarthMover
                                  Al,
                                  Reflections are working in Vray now. Alpha map also worked fine.
                                  Thanks again
                                  • jujuJ Offline
                                    juju
                                    Al, thanks for what seems like an extremely useful app and for free on top of that!
                                    On another note - I've tried downloading the RpTreeMaker a few times already, ZIP arrives corrupt or server is reset. I was wondering if anybody else seem to be having trouble with downloading the app?
                                    • Al HartA Offline
                                      Al Hart
                                      Give it another try at: RpTreeMaker HL12tm
                                      I was able to download it OK today.
                                      Perhaps someone else can try.
                                      Al Hart
                                        tomasz
                                        Hi Al,
                                        Thank you for a brilliant tool.
                                        I have rendered the group of trees in Kerkythea.
                                        I had to modify one thing in your model. Image map is applied to Back Face instead of Front.
                                        I have an idea. Al, would it be possible to export full 3D model from your app as well.
                                        What I am thinking of is having a 2D tree in SU and then full 3D model in a rendering application as instanced object! It would be an excellent feature.
                                        I have already implemented it in SU2KT where there is a hidden, high polygon component and a simplified proxy just for SU. Maxwell, Fryrender, Indigo, Kerkythea and other application users would be extremely happy to see it.
                                        Cheers
                                        Tomasz
                                        Trees rendered in Kerkythea. PNG applied to front faces as well.
                                        SU2KT sample - left side=proxy, right side=rendering
                                        • jujuJ Offline
                                          juju
                                          Hi Al, thanks for the reply. I was finally able to download the app, the transfer went dead a few times but I got it DL'ed and extracted fine. Seems like the trouble must have been on my end seeing that nobody else seem to be having trouble.
                                          Now, to try the app out!
                                          • Al HartA Offline
                                            Al Hart
                                            Hi Al,
                                            Cheers
                                            Tomasz
                                            Tomasz, I had attempted to put the image map on bot sides of the tree.
                                            Take the attached tree, and return it to me with any changes you needed to make to get it to work with KT.
                                            tree with texture image on both sides
                                            SKP model with two-sided face tree, and image palm tree.
                                            (The attached tree also has a palm tree created as an image, rather than a face. Let me know if that works with KT as well.)
                                            Also, send me a sample of a KT compatible proxy object. RpTools has a tool which creates proxy objects. I have attached one. Let me know what changes I need to make to make it compatible with KT.
                                            Proxy component from RpTools
                                            Sample Proxy Object created with RpTools.
                                            Currently, we use two layers - Proxy HI-POLY and Proxy LOW-POLY to let the user switch between displays. Does KY use a different scheme to store the proxy information?
                                            We are looking at an option to create 3D trees, but haven't had a chance to do it yet.
                                            Al Hart
                                            With your input, this post could be even better šŸ’—
                                            • 2 / 4
