    Snow?
    25 Posts 17 Posters 4.7k Views 17 Watching
      CADken
      @solo said:
      I am not sure a ruby would work right, unless ut's coupled with some sort of randomizing algorithm as snow does not accumulate evenly, and on steeper surfaces it won't gather.
      I had a quick go at using sub-smooth on a few horizontal surfaces of a stock wooden fence to give an illusion of snow, I think it works fine.
      then rendered it with vue.
      WOW! very nice, I'm new to the sub-smooth thingy so I may have to mess around with that... so far that is very impressive...
      "it seems like everything I do is a work in progress..."
        thinkbuild
        Hello
        I made some snow renderings using Maxwell recently for a project I am working on in Sweden. Attached are a few "process images". I made them because the project is very far north and will often be covered with lots of snow, so I wanted to explore how the forms of the building change with Snow on them. There's a post on a (Swedish) blog about the project if anyone is curious.... http://hem.neue.feber.se/art/56379/polar-circle-house/
        [attachment=1:h7iop0t7]<!-- ia1 -->65784.jpg<!-- ia1 -->[/attachment:h7iop0t7]
        [attachment=0:h7iop0t7]<!-- ia0 -->65782.jpg<!-- ia0 -->[/attachment:h7iop0t7]
        The steps I used were more or less the following:
        1. Make the thing you want to be covered with snow, then, set it in a smooth mesh landscape. Assign the landscape a "snowy" color and/or material for external rendering if you want to...
        2. Use Fredo6's "Joint Push Pull" to create a surface - first, take the outside surface of the thing being "snowed in", copy it in place, make a new group (so it doesn't "stick"), and expand it by the amount you want the thing to be snowed in, say 12" or whatever;
        3. As suggested above, use the subdive selection script from Whaat to deform & soften the snow;
          (here, it is very useful to use "creased edges" to keep sharp corners where the snow is hitting objects..."
        4. Render! (Note I forgot to put snow on the neighbor's house πŸ˜‰ but still you get the idea...
        5. If you have time (I didn't for these) go over with P-shop and correct any "leaks" ...
          thinkbuild
          PS
          here it is with no snow, just for reference....
            silver_shadow
            http://i185.photobucket.com/albums/x165/hondsekont/snow_1.jpg
            i did this some time ago in podium using photosho to dirtmap and snow effects
            • tinanneT Offline
              tinanne
              http://www.xiberpix.net/SqirlzReflect.html
              You can make animated snow with this program. It's pretty cool.
              Executive Director : American Society of Architectural Illustrators
              AIP 30 Competition opens soon. ASAI.org
              Architectural Rendering
              • Alan FraserA Offline
                Alan Fraser
                You can't beat a bit of arial photography and some mapped textures. Here's a model from the old forum that I hope the author (Hermes?) doesn't mind me posting here.
                Alder_w040.skp
                3D Figures
                  mateo soletic
                  Alan beat me to it, I was just going to say that those are some of the best snow scenes I have seen.
                  The thread with the link to Warehouse models is here:
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=13889
                  Concept Illustrations
                    tomislavm
                    This is an interesting topic and if somebody make ruby it will be very nice!
                    • ToboboT Offline
                      Tobobo
                      If you wanted to mull some wine on you PC you could use the Component Spray tool to place white blobs over your model. but I suggest some fire suppressant precautions on stand by.
                      Joking aside it could work, will need some refining tho
                      Toby
                      Philippians 4:13
                      • soloS Offline
                        I believe sub-divide and smooth and sandbox tools is good enough for a snow scene.
                        http://img126.imageshack.us/img126/4033/snolohomelineld9.jpg
                        http://img392.imageshack.us/img392/7562/snowhomeed7ev6.jpg
                        Rendered with Vue 7inf
                          CADken
                          very nice! def inspiration!
                            Excellent work there Solo. Only one thing. You need some icicles hanging off the eaves. If you'd like you could come for a visit and see some first hand. πŸ˜„
                            • AnssiA Offline
                              Anssi
                              Icicles shouldn't be hanging from eaves at this time of the year. Signs of a badly insulated and ventilated roof, in our parts. In spring some can be tolerated courtesy of the β˜€
                              Anssi
                                Anssi
                                πŸ˜„ Anssi, you folks there in Scandinavia know how to build houses for winter conditions better than we do. I know there should be no icicles but there are. Or maybe it's because we're far enough south that we still get some sun this time of year. πŸ˜‰
                                  We haven't even had snow this winter but the sun is shining at the moment. I haven't even turned on heating yet (the adapter of the lappy is nicely warming my feet under the desk) πŸ˜„
                                  So where are those icicles? β˜€
