    Snow?
    25 Posts 17 Posters 5.0k Views 17 Watching
    • C
      CADken
      Thanks guys!
      πŸ˜† to bringing it out to MN
      I think I'm just going to wing it...
      Perhaps if I get a chance I'll share my progress.
      "it seems like everything I do is a work in progress..."
        I'll be interested to see what you come up with.
        If you don't want to bring it here for the snow, I'd be happy to ship the snow to you. πŸ˜‰
        • scottliningerS
          scottlininger
          You might want to ask over in the Ruby forum. This is very doable with ruby... but I'm not aware of anyone who has. Maybe you'll inspire someone.
          • Scott Lininger
            SketchUp Software Engineer
            Have you visited the Ruby API Docs?
          • soloS
            I am not sure a ruby would work right, unless ut's coupled with some sort of randomizing algorithm as snow does not accumulate evenly, and on steeper surfaces it won't gather.
            I had a quick go at using sub-smooth on a few horizontal surfaces of a stock wooden fence to give an illusion of snow, I think it works fine.
            http://img339.imageshack.us/img339/663/snowfenceiw8.jpg
            then rendered it with vue.
            http://img407.imageshack.us/img407/1057/snowscene7zo4.jpg
            • boofredlayB
              boofredlay
              Pete, awesome but I am shocked you failed to place the disappearing rabbit in the snow πŸ˜†
              http://www.squidzone.ca/photos/uncategorized/185785.jpg
              Owl - 1
              Rabbit - 0
                remus
                No yellow snow either πŸ˜†
                • Jean LemireJ
                  Jean Lemire
                  Hi Cadken, hi folks.
                  Maybe you can paint a surface with a photography of snow and then intersect it with a building.
                  To get the surface for the snow you could use some random numbers generated in Excel or any other spreadsheet you may use. Generate random Z coordinates for a grid of X and Y coordinates. Imports these as a cloud of points and triangulate the surface.
                  For the Z coordinate I would try something like 18 inches + a random number from 0 to 6. This will result in Z coordinates going from 18 to 24. Increase this range for a more hilly look. Decrease for a smoother one. Play with the initial number to adjust for the total snowfall.
                  Paint the resultant surface with a white color, maybe adding a touch a blue.
                  Just ideas.
                  • C
                    CADken
                    WOW! very nice, I'm new to the sub-smooth thingy so I may have to mess around with that... so far that is very impressive...
                    • T
                      thinkbuild
                      Hello
                      I made some snow renderings using Maxwell recently for a project I am working on in Sweden. Attached are a few "process images". I made them because the project is very far north and will often be covered with lots of snow, so I wanted to explore how the forms of the building change with Snow on them. There's a post on a (Swedish) blog about the project if anyone is curious.... http://hem.neue.feber.se/art/56379/polar-circle-house/
                      [attachment=1:h7iop0t7]<!-- ia1 -->65784.jpg<!-- ia1 -->[/attachment:h7iop0t7]
                      [attachment=0:h7iop0t7]<!-- ia0 -->65782.jpg<!-- ia0 -->[/attachment:h7iop0t7]
                      The steps I used were more or less the following:
                      1. Make the thing you want to be covered with snow, then, set it in a smooth mesh landscape. Assign the landscape a "snowy" color and/or material for external rendering if you want to...
                      2. Use Fredo6's "Joint Push Pull" to create a surface - first, take the outside surface of the thing being "snowed in", copy it in place, make a new group (so it doesn't "stick"), and expand it by the amount you want the thing to be snowed in, say 12" or whatever;
                      3. As suggested above, use the subdive selection script from Whaat to deform & soften the snow;
                        (here, it is very useful to use "creased edges" to keep sharp corners where the snow is hitting objects..."
                      4. Render! (Note I forgot to put snow on the neighbor's house πŸ˜‰ but still you get the idea...
                      5. If you have time (I didn't for these) go over with P-shop and correct any "leaks" ...
                      • T
                        thinkbuild
                        PS
                        here it is with no snow, just for reference....
                          silver_shadow
                          http://i185.photobucket.com/albums/x165/hondsekont/snow_1.jpg
                          i did this some time ago in podium using photosho to dirtmap and snow effects
                          • tinanneT
                            tinanne
                            http://www.xiberpix.net/SqirlzReflect.html
                            You can make animated snow with this program. It's pretty cool.
                            Executive Director : American Society of Architectural Illustrators
                            AIP 30 Competition opens soon. ASAI.org
                            Architectural Rendering
                            • Alan FraserA
                              Alan Fraser
                              You can't beat a bit of arial photography and some mapped textures. Here's a model from the old forum that I hope the author (Hermes?) doesn't mind me posting here.
                              Alder_w040.skp
                              3D Figures
                                mateo soletic
                                Alan beat me to it, I was just going to say that those are some of the best snow scenes I have seen.
                                The thread with the link to Warehouse models is here:
                                http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=13889
                                Concept Illustrations
                                • T
                                  tomislavm
                                  This is an interesting topic and if somebody make ruby it will be very nice!
                                  • ToboboT
                                    Tobobo
                                    If you wanted to mull some wine on you PC you could use the Component Spray tool to place white blobs over your model. but I suggest some fire suppressant precautions on stand by.
                                    Joking aside it could work, will need some refining tho
                                    Toby
                                    Philippians 4:13
                                    • soloS
                                      I believe sub-divide and smooth and sandbox tools is good enough for a snow scene.
                                      http://img126.imageshack.us/img126/4033/snolohomelineld9.jpg
                                      http://img392.imageshack.us/img392/7562/snowhomeed7ev6.jpg
                                      Rendered with Vue 7inf
                                      • C
                                        CADken
                                        very nice! def inspiration!
                                          Excellent work there Solo. Only one thing. You need some icicles hanging off the eaves. If you'd like you could come for a visit and see some first hand. πŸ˜„
                                          • AnssiA
                                            Anssi
                                            Icicles shouldn't be hanging from eaves at this time of the year. Signs of a badly insulated and ventilated roof, in our parts. In spring some can be tolerated courtesy of the β˜€
                                            Anssi
