πŸ€‘ 30% Off | Artisan 2 on sale until April 30th Buy Now
Snow?
25 Posts 17 Posters 3.1k Views
    CADken
    Is there any type of Snow ruby? I'm trying to add about 12" of snow on a building and landscape (farmhouse and barn)...
    Is there anyway to do this?
    "it seems like everything I do is a work in progress..."
    • I Offline
      idraft
      Unsure on ruby making myself but you could use photomatch. Here is a nice pic of some snow in New Zealand that I had, mabe you can use this. I do have more pics if its helpful?
      Cheers Jeff
      Snow in NZ
        Send it here to Minnesota and wait. The snow will be here soon enough.
        Sorry, I know that's not what you're looking for but I couldn't help it. πŸ˜‰
        Maybe you could do it with SubSmooth?
          CADken
          Thanks guys!
          πŸ˜† to bringing it out to MN
          I think I'm just going to wing it...
          Perhaps if I get a chance I'll share my progress.
            I'll be interested to see what you come up with.
            If you don't want to bring it here for the snow, I'd be happy to ship the snow to you. πŸ˜‰
              scottlininger
              You might want to ask over in the Ruby forum. This is very doable with ruby... but I'm not aware of anyone who has. Maybe you'll inspire someone.
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
                I am not sure a ruby would work right, unless ut's coupled with some sort of randomizing algorithm as snow does not accumulate evenly, and on steeper surfaces it won't gather.
                I had a quick go at using sub-smooth on a few horizontal surfaces of a stock wooden fence to give an illusion of snow, I think it works fine.
                http://img339.imageshack.us/img339/663/snowfenceiw8.jpg
                then rendered it with vue.
                http://img407.imageshack.us/img407/1057/snowscene7zo4.jpg
                  boofredlay
                  Pete, awesome but I am shocked you failed to place the disappearing rabbit in the snow πŸ˜†
                  http://www.squidzone.ca/photos/uncategorized/185785.jpg
                  Owl - 1
                  Rabbit - 0
                    remus
                    No yellow snow either πŸ˜†
                      Jean Lemire
                      Hi Cadken, hi folks.
                      Maybe you can paint a surface with a photography of snow and then intersect it with a building.
                      To get the surface for the snow you could use some random numbers generated in Excel or any other spreadsheet you may use. Generate random Z coordinates for a grid of X and Y coordinates. Imports these as a cloud of points and triangulate the surface.
                      For the Z coordinate I would try something like 18 inches + a random number from 0 to 6. This will result in Z coordinates going from 18 to 24. Increase this range for a more hilly look. Decrease for a smoother one. Play with the initial number to adjust for the total snowfall.
                      Paint the resultant surface with a white color, maybe adding a touch a blue.
                      Just ideas.
                        CADken
                        WOW! very nice, I'm new to the sub-smooth thingy so I may have to mess around with that... so far that is very impressive...
                          thinkbuild
                          Hello
                          I made some snow renderings using Maxwell recently for a project I am working on in Sweden. Attached are a few "process images". I made them because the project is very far north and will often be covered with lots of snow, so I wanted to explore how the forms of the building change with Snow on them. There's a post on a (Swedish) blog about the project if anyone is curious.... http://hem.neue.feber.se/art/56379/polar-circle-house/
                          [attachment=1:h7iop0t7]<!-- ia1 -->65784.jpg<!-- ia1 -->[/attachment:h7iop0t7]
                          [attachment=0:h7iop0t7]<!-- ia0 -->65782.jpg<!-- ia0 -->[/attachment:h7iop0t7]
                          The steps I used were more or less the following:
                          1. Make the thing you want to be covered with snow, then, set it in a smooth mesh landscape. Assign the landscape a "snowy" color and/or material for external rendering if you want to...
                          2. Use Fredo6's "Joint Push Pull" to create a surface - first, take the outside surface of the thing being "snowed in", copy it in place, make a new group (so it doesn't "stick"), and expand it by the amount you want the thing to be snowed in, say 12" or whatever;
                          3. As suggested above, use the subdive selection script from Whaat to deform & soften the snow;
                            (here, it is very useful to use "creased edges" to keep sharp corners where the snow is hitting objects..."
                          4. Render! (Note I forgot to put snow on the neighbor's house πŸ˜‰ but still you get the idea...
                          5. If you have time (I didn't for these) go over with P-shop and correct any "leaks" ...
                            thinkbuild
                            PS
                            here it is with no snow, just for reference....
                              silver_shadow
                              http://i185.photobucket.com/albums/x165/hondsekont/snow_1.jpg
                              i did this some time ago in podium using photosho to dirtmap and snow effects
                                tinanne
                                Animated Water Reflection Freeware: Adding Realistic Water and Weather Effects with Sqirlz Water Reflections
                                Sqirlz Water Reflections is a versatile freeware program that enables users to add realistic water effects, such as rippling pools, raindrops, and snowfall, to both images and existing AVI video files.
                                Xiberpix (www.xiberpix.net)
                                You can make animated snow with this program. It's pretty cool.
                                Executive Director : American Society of Architectural Illustrators
                                AIP 30 Competition opens soon. ASAI.org
                                Architectural Rendering
                                • Alan FraserA Offline
                                  Alan Fraser
                                  You can't beat a bit of arial photography and some mapped textures. Here's a model from the old forum that I hope the author (Hermes?) doesn't mind me posting here.
                                  Alder_w040.skp
                                  3D Figures
                                    mateo soletic
                                    Alan beat me to it, I was just going to say that those are some of the best snow scenes I have seen.
                                    The thread with the link to Warehouse models is here:
                                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=13889
                                    [Concept Illustrations](http://concept-illustrations.com/)
                                      tomislavm
                                      This is an interesting topic and if somebody make ruby it will be very nice!
                                      • ToboboT Offline
                                        Tobobo
                                        If you wanted to mull some wine on you PC you could use the Component Spray tool to place white blobs over your model. but I suggest some fire suppressant precautions on stand by.
                                        Joking aside it could work, will need some refining tho
                                        Toby
                                        Philippians 4:13
                                          I believe sub-divide and smooth and sandbox tools is good enough for a snow scene.
                                          http://img126.imageshack.us/img126/4033/snolohomelineld9.jpg
                                          http://img392.imageshack.us/img392/7562/snowhomeed7ev6.jpg
                                          Rendered with Vue 7inf
                                          1 / 2
