    Snow?
    25 Posts 17 Posters 4.7k Views 17 Watching
    • soloS
      I am not sure a ruby would work right, unless ut's coupled with some sort of randomizing algorithm as snow does not accumulate evenly, and on steeper surfaces it won't gather.
      I had a quick go at using sub-smooth on a few horizontal surfaces of a stock wooden fence to give an illusion of snow, I think it works fine.
      http://img339.imageshack.us/img339/663/snowfenceiw8.jpg
      then rendered it with vue.
      http://img407.imageshack.us/img407/1057/snowscene7zo4.jpg
      • boofredlayB
        boofredlay
        Pete, awesome but I am shocked you failed to place the disappearing rabbit in the snow πŸ˜†
        http://www.squidzone.ca/photos/uncategorized/185785.jpg
        Owl - 1
        Rabbit - 0
          remus
          No yellow snow either πŸ˜†
          • Jean LemireJ
            Jean Lemire
            Hi Cadken, hi folks.
            Maybe you can paint a surface with a photography of snow and then intersect it with a building.
            To get the surface for the snow you could use some random numbers generated in Excel or any other spreadsheet you may use. Generate random Z coordinates for a grid of X and Y coordinates. Imports these as a cloud of points and triangulate the surface.
            For the Z coordinate I would try something like 18 inches + a random number from 0 to 6. This will result in Z coordinates going from 18 to 24. Increase this range for a more hilly look. Decrease for a smoother one. Play with the initial number to adjust for the total snowfall.
            Paint the resultant surface with a white color, maybe adding a touch a blue.
            Just ideas.
            • C
              CADken
              WOW! very nice, I'm new to the sub-smooth thingy so I may have to mess around with that... so far that is very impressive...
              "it seems like everything I do is a work in progress..."
              • T
                thinkbuild
                Hello
                I made some snow renderings using Maxwell recently for a project I am working on in Sweden. Attached are a few "process images". I made them because the project is very far north and will often be covered with lots of snow, so I wanted to explore how the forms of the building change with Snow on them. There's a post on a (Swedish) blog about the project if anyone is curious.... http://hem.neue.feber.se/art/56379/polar-circle-house/
                [attachment=1:h7iop0t7]<!-- ia1 -->65784.jpg<!-- ia1 -->[/attachment:h7iop0t7]
                [attachment=0:h7iop0t7]<!-- ia0 -->65782.jpg<!-- ia0 -->[/attachment:h7iop0t7]
                The steps I used were more or less the following:
                1. Make the thing you want to be covered with snow, then, set it in a smooth mesh landscape. Assign the landscape a "snowy" color and/or material for external rendering if you want to...
                2. Use Fredo6's "Joint Push Pull" to create a surface - first, take the outside surface of the thing being "snowed in", copy it in place, make a new group (so it doesn't "stick"), and expand it by the amount you want the thing to be snowed in, say 12" or whatever;
                3. As suggested above, use the subdive selection script from Whaat to deform & soften the snow;
                  (here, it is very useful to use "creased edges" to keep sharp corners where the snow is hitting objects..."
                4. Render! (Note I forgot to put snow on the neighbor's house πŸ˜‰ but still you get the idea...
                5. If you have time (I didn't for these) go over with P-shop and correct any "leaks" ...
                • T
                  thinkbuild
                  PS
                  here it is with no snow, just for reference....
                    silver_shadow
                    http://i185.photobucket.com/albums/x165/hondsekont/snow_1.jpg
                    i did this some time ago in podium using photosho to dirtmap and snow effects
                    • tinanneT
                      tinanne
                      http://www.xiberpix.net/SqirlzReflect.html
                      You can make animated snow with this program. It's pretty cool.
                      Executive Director : American Society of Architectural Illustrators
                      AIP 30 Competition opens soon. ASAI.org
                      Architectural Rendering
                      • Alan FraserA
                        Alan Fraser
                        You can't beat a bit of arial photography and some mapped textures. Here's a model from the old forum that I hope the author (Hermes?) doesn't mind me posting here.
                        Alder_w040.skp
                        3D Figures
                          mateo soletic
                          Alan beat me to it, I was just going to say that those are some of the best snow scenes I have seen.
                          The thread with the link to Warehouse models is here:
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=13889
                          Concept Illustrations
                          • T
                            tomislavm
                            This is an interesting topic and if somebody make ruby it will be very nice!
                            • ToboboT
                              Tobobo
                              If you wanted to mull some wine on you PC you could use the Component Spray tool to place white blobs over your model. but I suggest some fire suppressant precautions on stand by.
                              Joking aside it could work, will need some refining tho
                              Toby
                              Philippians 4:13
                              • soloS
                                I believe sub-divide and smooth and sandbox tools is good enough for a snow scene.
                                http://img126.imageshack.us/img126/4033/snolohomelineld9.jpg
                                http://img392.imageshack.us/img392/7562/snowhomeed7ev6.jpg
                                Rendered with Vue 7inf
                                • C
                                  CADken
                                  very nice! def inspiration!
                                    Excellent work there Solo. Only one thing. You need some icicles hanging off the eaves. If you'd like you could come for a visit and see some first hand. πŸ˜„
                                    • AnssiA
                                      Anssi
                                      Icicles shouldn't be hanging from eaves at this time of the year. Signs of a badly insulated and ventilated roof, in our parts. In spring some can be tolerated courtesy of the β˜€
                                      Anssi
                                        Anssi
                                        πŸ˜„ Anssi, you folks there in Scandinavia know how to build houses for winter conditions better than we do. I know there should be no icicles but there are. Or maybe it's because we're far enough south that we still get some sun this time of year. πŸ˜‰
                                        • GaieusG
                                          We haven't even had snow this winter but the sun is shining at the moment. I haven't even turned on heating yet (the adapter of the lappy is nicely warming my feet under the desk) πŸ˜„
                                          So where are those icicles? β˜€
